Misfed paper whenever i make a copy to my fax machine it has a misfed paper
  • Office Equip... Master
  • 1,297 Answers
Clean the paper feed roller and select the copy mode paper tray correctly.
Posted on Oct 01, 2009
We have a Brothers Intellifax Machine, Model 2820, the problem is with the paper feed, the roller is not grabing the paper to feed it through the machine when we are receiving fax's. I would like to...
there are several fixes to this problem 1. replace pickup asembly 2. Clean the rubber pickup band are roller with a rubber cleaning compound (not alchohol0 alcohol dries out the rubber.
This is a common problem with printers and faxes, Paper has a tendency to leave a glass glaze on the pickup rollers therefore causing the paper to slip on the rollers are to be misfed thus causing a paper jam
Sep 23, 2011 | Brother Office Equipment & Supplies
REMOVED PAPER JAM
There should be 2 switch actuators sticking up underneath of the toner cartridge, maybe one got knocked off?
Mar 30, 2010 | Panasonic PanaFax UF-8000 Laser Fax
I am having an issue with a Panafax uf-8000 printer. It grinds when starting up and says there is misfed paper. Don't see any.
Paper feeder sensor guide is open or displace ,So it said misfed paper.Clean sensor or right position set the sensor guide.
Dec 08, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Paper Jam J43
One of the switches under the toner cart is knocked off.
Aug 09, 2009 | Panasonic PanaFax UF-8000 Laser Fax
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Remove misfed paper code J93
J93 means = paper remained in adf . sounds like you have a problem with the reed point sensor in the adf door . little black plastic arm , right side should be dangling
Jan 13, 2009 | Panasonic Workio DP-190 Multifunction...
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
SPF misfeed light
hi im jules_09 if the misfed sensor is on there is no process that can restart,the light togo off.once again check which sensor is on,there are 3 misfed sensor in the machine 1st is in the bypass tray area the 2nd in inside the machine itself  the 3rd is at the fusing check which sensor is on better yet shieck all sensor,there just a piece of paper or something stock in thoose sensors
Oct 11, 2007 | Sharp AL 1631 Copier
Copy problem
ONE OF THE DOCUMENT SENSOR IS FAULTY OR DIRTY AND IS NOT RESPONDING CLEAN/REPLACE , PROBLEM WILL BE RESOLVED
Aug 22, 2007 | Samsung SF-3100 Plain Paper Inkjet Fax
74 people viewed this question
k24674
jasbo
jasbo
