Question about Western Digital Protege WD400EB 40 GB Hard Drive
Hard drive turning on and off repeatedly
Hello. After running windows live update from the windows website, my computer worked. the next morning when i turned it on, the hard drive turns on and off immediately, repeatedly. The drive is no longer detected by the BIOS. All of this just after downloading all my digital photos!
  • 790 Answers
Just restore ur system to previous date so that everything may go fine ...
Posted on Dec 18, 2007
Windows vista crapped out after service pack update. How do I restore my hard drive?
Start your computer, during bios loading press F8 repeatedly. You'll gone see in next screen few option to start your computer. Choose "Last known good configuration" and press enter, from next screen choose a restore point before service pack update was installed and follow the steps from that window, after that you'll gone have your computer restored. This in case you don't have system restore closed. If this is not work write a message and i'll give you another method to repair your computer a litlle bit heavier.
Apr 28, 2011 | Everex StepNote NC1500 Notebook
When I originally formatted my LaCie Petit hard drive, it was on a laptop computer with windows vista. I often have trouble accessing the information on the hard drive on other computers, specifically,...
The reason 7 sees it properly and XP has trouble is because XP is running on an older revision of NTFS and both Vista and 7 use a newer version. Try running windows update on the XP computer, when the Express and Custom buttons come up select custom. If the next screen offers a service pack skip it and continue to the custom list the first time. Once in the custom list you will see the Critical updates list in the center frame, look down the left frame and select Software Updates, then check all of the boxes in the software list in the center frame. Repeat this with the hardware list.
Select review and install, then select install from the install page.
Once the updating process completes, reboot the XP computer if it doesn't force you to. Once up again, rerun the update process and if it offers you a service pack accept it and then take a nap or go for a long walk as it will take quite a bit of time to complete. Again when done reboot, wether you needed the service pack or not repeat the first set of instructions for custom updates until none are left. Some only show up after others are installed.
When this process is complete, try the drive out on the XP computer, the service pack should have resolved the issue but if not you can always copy the data off the drive to any one of your computers then format the external using your XP computer and then copy the data back as the XP format will work fine on Vista and 7 but you will have to deal with a pop up almost every time you plug the drive into the two newer computers asking to scan and repair the drive, ALWAYS SAY NO as this reformats the drive without backing up.
Hope this helps FixYa,
Chris
Jan 11, 2011 | LaCie Petit (301894) 320 GB USB Hard Drive
Ok basically my brothers computer was working fine with the 32bit version of windows 7, that is until the other day. you see what happened is, he turned it off, then in the morning it turned on, went to...
clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit and your keyboard making VERY sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems if this does not fix the problem
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 25, 2010 | Computers & Internet
I need to uninstall Micosoft Intrnet Explorer so that I can reinstall IE7. I keep getting s message that a more recent one is on my computer but I cannot find it to ubinstall it.
Click "Start" then "Control Panel" --> "Add/Remove Programs" --> "Add/Remove Windows Components" --> click the "Internet Explorer" and uncheck it, click "Next" wait for few seconds until the uninstallation is finished and click "finish" when done. Close the windows and now open, "My Computer" -- > "C:" drive --> then "Program Files" and locate "Internet Explorer" and delete the folder. Now restart your computer and repeat the same procedure from "Start" then "Control Panel" --> "Add/Remove Programs" --> "Add/Remove Windows Components" --> click the "Internet Explorer" and uncheck it, click "Next" wait for few seconds until the uninstallation is finished and click "finish" when done. That should work. Even if you don't repeat the steps, by default, windows Xp has the Internet Explorer 7 with it.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 19, 2010 | Microsoft Windows XP Professional
Hard Drive not accessible, now not recognised by computer
Do you have another computer you can plug it into? The problem could be with your USB. If it is, see what updates you installed and then removed that may have affected that. You can also go to the manufacturers web site and download the original firmware or updated firmware files.
Dec 12, 2009 | Maxtor Hard Drive
Sony didital player wount turn on
Hello and Welcome to FixYa!
I will suggest to reinstall the firmware (the operational software) on your MP3 Player.
Follow the following procedure to upgrade firmware:
  1. Connect the unit to the computer.
  2. Set up a folder on the computer hard drive. Copy all the music tracks and data from the unit into the folder.
  3. Quit all software applications running on Windows and disconnect the unit from the computer.
    * If other Digital Music Players are connected to the computer, disconnect all of them from the computer.
  4. Download this firmware file (http://walkman.update.sony.net/fw/pc/DB100/NWD-B100F_V1_3.exe)
  5. Windows Vista users: Click right click the downloaded file and select RUN AS ADMINISTRATOR.
    Windows XP/Windows 2000 users: Simply open the downloaded file by double clicking it.
  6. The program will be started.
  7. Connect the unit to the computer.
  8. If Format Data Area is selected in Download options, the unit will be formatted and all music tracks and data are deleted during the update. Make sure to backup the necessary files into the computer before proceeding to next step.
  9. Click Start.
  10. Please do not disconnect the unit from the computer during updating.
  11. When the message of completing updating is displayed, click Close.
  12. Transfer all music tracks and data to the unit that was previously backed up.
You are done. I hope this works for you.
Source: Sony Official Website
Kindly rate me if i was helpful.
Regards,
Waqar
Aug 20, 2009 | Sony Audio Players & Recorders
Dell 1501 Inspiron w/Vista won't boot up -- virus?
Hi Erika,
have you tried pressing F8 when it starts booting (keep pressing it before dell bios screen fully loads)
you should get a black screen with options,
scroll up to with arrow keys>> "last known good configeration"
let me know if that works?
also have you installed any programs or hardware befor this happened?
Apr 13, 2009 | Dell Inspiron 1501 Notebook
Cannot start up my laptop since in done an update
Try booting into "Last known good configuration" it is on the same screen as Safe Mode, if that does not work, you can try to run CHKDSK /r from the windows install CD, just choose "Repair" in the option, if this does not work I suggest removing that hard drive and slaving it into another computer to get your data off and then reload Windows onto it. It is missing a .dll
Nov 28, 2008 | Acer Aspire 1642WLMi Notebook
Replaced my hard drive on my hp lap top and i cannot load the restore disk it is hp ze4800 i dont know how to get it load error code pxe e61
HP and Compaq Desktop PCs - Error: PXE-E61: Media Test Failure s.gif s.gif
This document pertains to HP or Compaq desktop computers with Windows XP. The following error message appears: PXE-E61: Media Test Failure This error is probably occurring because the main bootable hard drive is no longer "connected" to the computer and the next usable bootable device in the boot path is the network card. Use the following steps to resolve the error: NOTE: If the computer was recently moved or bumped, make sure the hard drive cables are firmly attached to the motherboard and the hard drive before using the steps in this document. Step 1: Remove all removable storage devices Remove connected devices, remove power, and restart the computer:
  1. Disconnect any, personal media drives, pocket media drives, USB or 1394 (Firewire) devices that are attached to the computer, especially USB thumb drives.
  2. Remove any CD and DVD discs from their drives.
  3. If the computer has a floppy disk drive, remove any floppy disks from the drive.
  4. Press and hold the Power button for 5 Seconds to turn off the computer.
  5. Disconnect the power cable to the computer.
  6. With the power cable disconnected, press the power button again for five seconds. This may reset the firmware for the hard drive to its defaults .
  7. Plug in the power cable only and turn on the computer.
  8. If the error persists, go to the next step. If the computer starts without the error, one of the removable storage volumes may be preventing the computer from starting or the hard drive was not reponding. Do not leave the removable device in the computer when shutting the computer off. You are done.
Step 2: Make sure a network device is not selected as the first boot device in BIOS The computer may be attempting to boot from the network device.
  1. Turn on the computer by pressing the power button on the PC and press the F1 key repeatedly when the first screen opens.
  2. Use the arrow keys to select the BOOT screen (from the menu at the top of the screen).
  3. Use the arrow keys to select the BOOT Device Priority (or similar).
  4. Press Enter .
  5. Read the instructions on the page to move any reference to a netwrok device to the bottom of the list. You should also move the optical drive (ODD) to the top of the list.
  6. Once the selections have been made, press F10 to Save settings and exit.
Step 3: Test the Hard Drive Test the hard drive using the SMART hard drive test:
  1. Press and hold the Power button for 5 Seconds to turn off the computer.
  2. Press the F1 key repeatedly after the computer is turned on. A BIOS setup utility should appear.
  3. After the BIOS Setup Utility is displayed, use the Down Arrow key to select the hard disk drive name and press Enter .
  4. Select SMART Extended Self-Test , press Enter , and wait for the test to complete.
  5. If the test fails, the hard drive should be replaced. If the test passes, go to the next step to update the BIOS.
Step 4: Update the BIOS Download and install the latest BIOS for your computer . If, after updating the BIOS and restarting the computer, the error goes away, you are done. If the error persists or a BIOS update is unavailable, go to the next step to recover the computer. Step 5: Recover the operating system To reinstall the Windows XP operating system, perform a system recovery (or reinstall Windows if the computer was upgraded to XP). You may need to start the computer from a set of recovery discs (or from a Windows Installation disc if Windows was upgraded to XP). For more information about how to recover the computer, refer to the HP support article Performing a System Recovery in Windows XP . Step 6: Repair the computer If the preceding steps do not resolve the error, the hard drive or BIOS may have failed and the computer should be serviced. if this service info does not work contact me.
Oct 13, 2008 | Computers & Internet
Western Digital Protege WD400EB 40 GB Hard Drive Logo
98 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
