Question about Pentax K100D Digital Camera
Dropped camera with lenses. Lost the automatic focus. Is the problem with the add on lenses? Repairable with new lenses?
My 70-300mm AF G will not manual or auto focus
It is probably repairable. I would go to the Nikon USA website and go to the Service and Support tab. Don't try to fix it yourself. You will only increase the repair bill.
Jan 08, 2014 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
New out of the box Cannon 550 with a 18-55mm 3.5 - 5.6 lens and I can only focus in the wide angle shot. The zoom to 55mm is out of focus even when set to AF and an automatic setting. Am I doing...
In automatic mode and automatic focus - The camera should focus onto the subject given that there's enough contrast between your subject and the background. If it not focusing at all even in broad day light conditions - You lens is faulty.
Also - Do you or your friend have another lens to test if the camera is faulty?
Feb 28, 2011 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Damaged Lense
does the camera recognize it? I mean when it is attached, does the camera show the Fstop etc?
Jul 11, 2010 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
Lense only focuses manually
its not junk, prob too expensive to fix. but makes a nice fixed focus lens. Quantray were on the same level as vivitar, sigma. So they are now that expensive to replace
Jan 18, 2010 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
My camera lense will not focus automatically or manually.
There is no battery in the lens.  The lens receives power from the camera. Whether or not the lens is getting power, though, you should be able to focus manually.
When you say you can't focus manually, do you mean that you can't turn the focusing ring on the lens, or that when you turn the ring the image does not come into focus?
If you decide the lens needs to be repaired, I recommend sending it to Canon.  You can go to their website (canonusa.com if you're in the US), click on support, and follow the links.
Dec 20, 2008 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Camera lense
May not be repairable, but try this, put a block of wood ( approx. 2in X 6in ) on the end that is pushed in, on a angle and while holding steady tap it out with a light hammer. It should pop the lens back to orig. position. Turn the focus ring and it should turn smoothly.
I have used this method many times with about 80% success rate.
Nov 18, 2008 | Photography
Focus error displayed after a drop its one of the finepix range there basicaly all the same
have you tried to gently pull and twist the end of the lense when it is extended?
unfortunatley when these cameras are dropped they can cause the lense to become unaligned and create a focus error if twissting dosent help it would need to be sent away for repair to have the lenses realligned but it wont be covered by warrenty
Sep 11, 2008 | Cameras
Locked lens
your camera needs a new lens assembly.These lenses are not repairable .They can only be replaced.
Jun 23, 2008 | Toshiba PDR-3320 Digital Camera
Epson 3000Z in "sports" mode
With the telephote lens, I am assuming that the camera is a bit more sensitive to any form of camera shake. My suggestion, when using the telephoto lens, is to manually set the shutter speed to its fastest setting (that, or set it to "sports mode"). Also, experiment with the telephote lens using your tripod. Set the camera up on a table and use the timer so that the camera will snap the image automatically. See if the picture is still blurry. If you don't have a tripod, just place it flat on the table.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Pentax K100D Digital Camera Logo
21 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
