Question about Kenmore Sewing Machines
I just need a new bulb for my sewing machine. Model 13453
You can get one at any sewing center that handles your brand
Posted on Sep 28, 2009
I would like to know the secret to installing a new light bulb in my machine - I cannot for the life of me get it in! Please help
Depends on your model machine. If it is a bayonet light bulb, you need to push up and then twist. The other is simply a screw-in bulb.
Dec 22, 2016 | Bernina Sewing Machines
How to get the light bulb out of new home 605 sewing machine
A manual may be helpful:
New Home Sewing Machine Manuals Instruction and Repair Manuals
New Home Model 605 Sewing Machine Instruction Manual
Janome New Home sewing machine instruction manuals
http://www.sewusa.com/Sewing_Machine_Manuals/New_Home_Sewing_Machines.htm
If it is bayonet type bulb, you may have to push in on the bulb and twist simultaneously. (Rubber fingertips are very helpful!)
Other bulbs simply unscrew.
However, there are also some machines (mostly newer models) which require the bulbs to be replaced by a technician.
Nov 19, 2016 | New Home Sewing Machines
How do I replace light bulbs in a Bernina sewing machine model 1080?
Check the bulb model number old versus new and make sure you have the same number bulb. The bulb number should be on the base of the bulb somewhere. If the bulb has tabs sticking out of the base, check to see that they are placed such that both tabs are on the same plane on the bulb base. Some bulbs have offset tabs that only go in one way to the socket. Try rotating the bulb 180 degrees and insert it again to the socket before trying to rotate it. Check your manual for bulb replacement procedure. Make sure also that you didn't rotate the glass bulb out of its base when you pulled the old one out, leaving the old base still stuck in the bulb socket. If this is the case, unplug the machine and use needle-nose pliers to remove the old bulb base before trying to replace the bulb.
Jan 14, 2015 | Bernina Sewing Machines
How do I get to the light bulb on euro pro model 6131 sewing machine
hi
check this out
hope this will work
http://www.ebay.com/itm/Sewing-Machine-Light-Bulb-395722-99-/161215484502?pt=LH_DefaultDomain_0&hash=item2589311256
Dec 17, 2014 | Sewing Machines
How do i change the light bulb on singer model 7426 ?
You have to unscrew the cover of your sewing machine on the left top and once it is unscrewed you take the cover off and insert a new bulb and then replace the cover.
Jul 08, 2014 | Singer 7426 Mechanical Sewing Machine
Bulb replacement
Make sure power is turned off. Get a pair of pointy nose pliers (may need to try a couple of sizes to get correct one). Use these to get hold of the metal light base and remove. Will probably need to turn base to release. Then insert new bulb.
Jan 18, 2014 | Elna 945 Computerized Sewing Machine
Stitch selector knob turns but doesnt change stitch from a straight stitch on kenmore ultra stitch eight, model 13453
when a part on the sewing machine does not respond like it's suppose to ,,then it would be a good idea to have the sewing machine checked
Nov 15, 2012 | Kenmore Sewing Machines
I bought a new sewing machine light bulb to replace the one that burned out but can't get it ot screw in the socket. Are all sewing machines bulbs universal?
your bulb part number is X53061020 and no the blubs are not universal I would suggest taking the old bulb with you along with the part number I gave you in order to get the right bulb when you go to the store.
Sep 21, 2009 | Brother LS-1217 Mechanical Sewing Machine
Bulb is fused
There is no problem if the bulb was busted,just dismatle it replace a new one.Open face cover plate where the bulb was socket.turn bulb in left drection from the socket to pull out.Be sure the power was off no power supply). replaced a new one.
Feb 23, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
22 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
