I need the specs for venting a 125,000 btu 80% up draft furnace
  • 22 Answers
Do you mean the air flow distribution or gas exaust vent pipe right back for answer
Posted on Sep 29, 2009
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
New goodman 80% gas furnace leaking condesation down exhaust vent
it could be condensation. or poor seal at roof. probably the seal at roof. also check the larger copper line is it sealed good? if any spot is not this will cause leaking when in cooling mode. maybe dripping from line onto vent.
Jan 28, 2014 | Goodman Manufacturing Goodman 60,000 btu...
Fault 3 B9 Low Airflow / E8 PS2 Closed
You are shutting down on a pressure switch safety lockout tied to the exhaust system. You need to check your vent system for obstruction at the ends of the pipe also clear pressure tube ports that attach to the exhaust motor
Jan 04, 2014 | Amana AMVC81005CN - 115,000 Btu 80% Afue...
Rheem rgpe won't ignite. cleaned flame sensor - still won't light.
check to see if the hot surface igniter is coming on or if direct spark see if it is sparking to light if this is working then you are not getting gas from your gas valve. The board should be giving you code by blinking light. If you will count the blinks there should be a chart on the door to tell you what it means. HOPE THIS HELPS
Oct 25, 2013 | Rheem Gas Furnace 125,000 BTU 80 AFUE....
How many gallons of propane will I use per month?
Go on to google and use BTU per gallon calculator at Irving energy this will give you the price between them both
Mar 06, 2017 | Heating & Cooling
I'm getting the 2 flashing light indicator, says the combustion air switch is stuck what do i need to do? I tapped on it and the heater comes on, but will only run one cycle.
first thing i would do is follow the short rubber tub from the draft switch to the furnace. pull the hose off the furnace body and run a paper clip, or such, into the hole. replace the hose and see if that helps. check the vent ing for blockage and then replace the switch
Feb 09, 2011 | Coleman Propane Forced Air Heater...
I have the Model number and serial number but am unable to find the BTU's on mty furnace...Help please?
if you have the model number of the furnace, then you have the btu input of the furnace. The model number usually starts with letters, then the three numbers following the letters are usually the btu input of the furnace.
For instance if it said 075 then it would have an input rating of 75,000 btu/hr or if it said 125 then it would have an input rating of 125,000 btu/hr.
Hope this helps
Nov 16, 2010 | Heating & Cooling
Janitrol furnace-circuit board code giving 3 blinks vent pressure switch or vent blockage where do i check on system / furnace was running fine up to this point /turned it off for about 1hr. and when i...
f this is a metal vent 80% furnace,Turn Furnace off
and remove the vent that connects to furnace and see if it is plugged.
If this is a High Eff furnace witrh pvc vents for
exhaust and intake air make sure they are not plugged on the outside.
Turn thermostat all the way up,turn furnace off and
wait a few minutes.This should reset any control
board fualt.
Turn the furnace back on, if you have a glow coil
ignitor it should glow red and then the burners should
ignite. If this doesnt happen then:
On High Eff Furnace if the glow coil does not glow red, remove the combustion door to the burners,
turn furnace back on, if the glow coil glows and
burner ignites, you have an obstruction in the intake
air side. If it still does nothing then:
Use caution and remove the exhaust vent from furnace, start furnace, if furnace runs then you
have a problem with the vent system
Feb 13, 2010 | Heating & Cooling
I have a coleman evcon gas furnace in a 95 trailer the draft fan stays on until you tap on furnace
Most Coleman units in a trailer dont have a draft fan. Are you talking about the fan that blows air through the floor registers? If yes, then you will probably need a new fan/limit control. If you do have a draft motor, you would probably need a new circuit board or draft fan relay.
Jan 02, 2010 | Coleman Propane Forced Air Heater...
What type furnace is a GUJ125V20-3A
It is a 125,000 btu furnace are you looking for a brand as well?
Dec 13, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
