Question about Dell Wireless Keyboard Optical Mouse w0147
Wireless part 830822 shows red light for low battery. What to do?
Shows red light for low battery. What to do?
    President:
  • 2,923 Answers
Change the battery with fresh ones. But if same problem occurs after changing the battery, contact the manufacturer for repair.
Have a great day!
Posted on Sep 28, 2009
If U Charger The Jam 2 When It's On Low Battery In The Outlet and And The Red Light Doesn't Show What Should I do?
Doesn't sound like it's charging. Have you checked the charging pin to Mack sure it's intact. Try another micro usb charging cord too,!
Jan 16, 2015 | Jam Classic Bluetooth Wireless Speaker
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
MPlantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset red light flashing problems
The red flashing indicates a low (or check) battery. The instructions on page 4 in the link below for the Plantronics Backbeat 903/906 will show you how to charge it up. On page 8 you'll see how to power down and then up the headset to reset it.
Plantronics Backbeat 903/906 User's Guide
Good luck from Headsets Direct!
Aug 02, 2011 | Plantronics Backbeat 903 Bluetooth...
Pheonix plus batery flat,charged up,now it is mobile but all i have on dial is single red flashing led.
John the red flashing light indicates a low battery When you charge the battery your charger should be showing a red light for power and a yellow light. When the batteries are fully charged you should show a red and green light on the charger. Now if you have a voltmeter plug the leads into the two outter holes of the charger port located under the front of the joystick.Without the charger plugged in you will be reading the battery voltage. Fully charged it should read 27-30 volts if you are only reading 20-24 volts then the batteries are low. If you have an onboard charger plug it in and you should read the charger voltage of 29-32 + volts If you aren't getting that voltage then you have a bad charger if you are getting the charger voltage then you have bad batteries and they need to be replaced Hope this helps you
Apr 18, 2011 | Health & Beauty
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
I own a Lenovo Mini Wireless Mouse (Model number N30). It has been working fine since the last 4 months I have owned it. However, I noticed today that the small light on the top of the mouse is blinking...
It's indeed the low batteries indicator. I have a Lenovo N30 myself.
I suggest you use a good pair of rechargeable AAA batteries.
They last longer than regular alkaline.
Best regards.
Source: Lenovo N30 User's Manual. Own experience.
Feb 17, 2011 | Lenovo Mini Wireless Laser N10 Mouse
I have changed the batteris, the mouse shows low battery, usb showing red light, ultimately mouse is not connecting and not working ? what is the solution
hi r_sreedasyam
before your mouse run out of battery, it can still be used?
if it can still be used, try to open the battery cover. positive and negative metal rubbing with sandpaper or any tespen.
re-insert the battery.
(Insert really new)
please call again for more information
thanks and regards
Dec 08, 2010 | AVENUES The SPYDER SwissGear Wireless...
Where do I find the meaning of various lights on the dashboard?
hi, all lights the first and important battery light this shows RED when the alternator NOT carging:
the oil light shows ORANGE LOW on oil:
the engine managment light shows when engine sensors detect faults shaped like an engine ORANGE light
head main beam BLUE when ON MAIN BEAM
indicator FLASHING GREEN light
hazard warning RED light
brake fluid low light RED looks like this ( )
brake handbrake ON RED light looks like this ( )
side light GREEN looks like a star
most of the important lights are RED or ORONGE gerry
Sep 10, 2010 | 2007 Toyota Sienna
How do you replace the battery for the vista 15pmt system. I have the low battery light
Open the control box and the 12V 4AH battery is inside. Buty new battery connect black and red wires to black and red terminals on the battery
AlarmProfessor.net
Nov 08, 2009 | GE Security Simon 3 Wireless Home Security...
HP wireless mouse
Try replacing the batteries. Wireless mice do funky things when the batteries are low.
May 18, 2009 | HP Wireless Optical Mouse
Dell Wireless Keyboard Optical Mouse w0147 Logo
257 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
