Question about HP Compaq d530 SFF PC Desktop
CPU fan how do I remove the cpu fan on a d530?
  • 103 Answers
There are metal clips install on heat sink. so press them down and turn them to up. fan will be unlocked.
regards,
Posted on Sep 28, 2009
How do i repair green blinking light in motherboard and not powering up?
Is the CPU fan running ? Check power plug to cpu fan could be a spot on motherboard that has to be plugged into with power.
Feb 12, 2015 | HP Compaq d530 SFF PC Desktop
Hp disktop erreur 920-fan command 2 pin connector
The CPU Fan is not working. Contact Compaq or go on Ebay and see if you can find a replacement fan. If you continue using your PC without the CPU fan operating, you will burn out the CPU. I hope this helps. Good luck and have a pleasent day.
Apr 30, 2011 | HP Compaq d530 SFF PC Desktop
My cpu fan spins very fast than normal and makes a lot of noise. I use hp d530 cmt- 3.06GHz
Most fans are "temperature-sensitive" -- if it is sensed that your computer is close to over-heating, the fan will run at full speed, very noisily, to try to cool it.
So, shut it down, and disconnect the AC power.
Remove the side-panel.
Purchase a can of compressed-air.
Give the computer a "blow-job", to remove excess dust,
since the layer of dust is acting like a blanket,
keeping heat inside your computer.
Sep 20, 2010 | HP Compaq d530 CMT PC Desktop
What cause error code 511 cpu fan not detected
3 wire conductor fan. The 3RD WIRE IS THE fan sensor located in the fan's electronics this is malfinctioning come in tthe construction of the fan itself.
Aug 23, 2010 | HP Compaq d530 SFF PC Desktop
Dear Sir sir i have hp desktiop pc and i have
You need to remove the Heatsink from the CPU and re apply heatsink compound to both the CPU and the heatsink then replace the heatsink onto the CPU. the reason for the overheating and shutdown is that the connection between the heatsink and the CPU has become "Aged" and no longer transfers the heat like it should
Jul 20, 2010 | HP Compaq d530 SFF PC Desktop
Hp d530s problem restarts by itself (Windows XP Pro. I tried different hard drive, still same. The CPU and the power supply are very hot. The fan makes noise sometimes. What could be the problem? Thanks!
Scan the system for viruses. If no virus found check ur power options settings in control panel. Still u experience the same problem just uninstall anti-virus program from ur pc. This will fix ur problem mostly.
Jul 21, 2010 | HP Compaq Evo d530 PC Desktop
512 Chassy Fan Error
Hi friend,
Your CPU FAN is not working right now so you are facing this type of problem....you need change your CPU fan...
Dec 24, 2009 | HP Compaq d530 PC Desktop
All computer fans starts ok but trips with notice,
You may hear the case fans running. Remove PC cover and check CPU fan and replace, it may not be running at full speed.
Sep 23, 2009 | HP Compaq d530 SFF PC Desktop
HP D530 SFF CHASIS FAN NOT DETECTED
tell me the wright way to remove 512 chassis fan error i am very depressed on this
Mar 17, 2009 | HP Compaq d530 SFF PC Desktop
MLTIPEL PROECESS EROOR
sounds like your fan on your cpu is almost taken a dump common prombelm you better change it before it over heats and takes your cpu out ... lala linda
May 14, 2008 | Dell Delta Electronics CPU Processor Fan...
HP Compaq d530 SFF PC Desktop Logo
556 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
