Question about Viking 31 in. VGSU101 Gas Cooktop
I have a four burners 31 inch Viking cooktop. I noticed two problems and hoping someone can shed a light on a do it yourself solutions: Problem 1 : when i strating to turn on #3 burner, I get 1, 2 ,3 all sparking at the same time. Problem #2 I smell gas leak coming out of # 1 burner when not in use.
  • sonny_11 Sep 29, 2009
    Let me be more clear on my problem #2 mentioned above. I only smell gas on #1 burner(#1 is not in use) when I turned on #3 burner. This makes no sense to me. I thought they all burners are common headed and they have seperate valve to each burner. Please advise
  • 42 Answers
Burner 1 is the tap assembley reqs., greasing with graphite grease.
ignition depending on model this is correct.
Posted on Sep 28, 2009
  • ITS THE GAS Sep 30, 2009
    each burner is fed from a main rail hence seperate tap handles, i presume that burner 1 is the one that you have used the most,it is only a small job to repair .
My DGSU100-4BSS-LP Gas Cooktop spaks but does not ignite
Check for LP leak. You also have to wait for air locks to vent out through burners to get lite the first time.
Jul 29, 2012 | Viking 31 in. DGSU100-4BSS-LP Gas Cooktop
A spark that causes a snapping noise when a burner is turned on.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 26, 2010 | Viking 31 in. VGSU101 Gas Cooktop
My VIKING 31" VGSU 101 GAS COOKTOP. All 4 burners can't ignite .If I light it will work
I have the exact same problem, same model. Read the instructions on this website for replacing the ignitors...looks complicated, also generic to all Viking cooktops. Let's see what we response we get.
Oct 23, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking stove right burners won't light
can u see the burner spark if not then ht lead at fault of electrode
Aug 21, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking Designer Series gas cooktop not cleaning well
I'm sorry to say that there is not a wonder solution for this. You try laying a damp cloth on the aluminum part to try and allow the moisture to soak in the clean it off.
Don't use anything abrasive as the aluminum will scratch.
Feb 16, 2009 | Viking 31 in. DGCU105 Gas Cooktop
Only 1 of 5 burners is working on my Viking electric cooktop
By only 1 burner working, I take you mean only 1 ignites, then it sounds as though you have an issue with the spark module being defective. There is usually an access panel on the bottom of the unit, although not on all of them. Remember to disconnect from the electric.
Dec 25, 2008 | Viking 31 in. DECU165 Electric Cooktop
Viking professional 30 inch, sparking problem
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
Nov 25, 2008 | Viking 31 in. VGSU101 Gas Cooktop
All burners are sparking
I called a professional service representative to come and fix it.
Oct 02, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Viking stove ignitor
the continues to click problem, for e it was only when my smaller burner was lit. theo others were ok. When I took the burner apart it was very dirty. I cleaned it up (a wire brush in my drill press) and it works fine now. I think it was just bad electrical conduction.
Aug 20, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Viking 31 in. VGSU101 Gas Cooktop Logo
261 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Ed Mac
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
