Washer will not stop filling - Washing Machines
    President:
  • 1,776 Answers
A machine that overfills or underfills can often have a faulty water level switch. It's a diaphragm like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level, it activates the switch to shut off the water. Make sure there is no damage to or obstruction in the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad switch. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 28, 2009
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Fills Constantly
check the drain hose. Is it in the drain below the fill line of the washer?
In other words -- the drain line should be above the level of the washer lid top and in the line about 4-6 inches
Feb 20, 2014 | GE GTWN3000MWS Washer
Won't stop filling with water, seems to fill to top and keep filling
there is a water connector that the water lines from the house connect to the washer. you will need to take the panel off. you should see a blue plastic box where the hoses connect. you will need to replace this piece. it should have wires on it and that tells the washer when to open the valve for water to come through and when to stop.
Jan 27, 2011 | Frigidaire FWS833A Top Load Washer
Kenmore serie 80.does not stop filling water in and does not star
Yeah I've seen that happen a many of times. Take the back of the control panel off and where your load size selector is you'll find a little hose that's suppoed to be attached to the side of it. just reattach it and you'll be back up and running.
Almost all washing machines use a pressure tube that tells the washer when to stop filling with water. If the tube comes off for some reason the washer will never stop filling and that's an instant flood if you don't notice it quick enough. Also a hole or puncture of any kind can be causing ti to never stop filling as well.
Hope this helps
Jason
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Water Overflow
hi there,
i would recommend checking the water level switch or lid switch and also the cable leading to it. that is what sends a signal to the machine control to stop filling with water.
Oct 10, 2008 | Whirlpool LSR7333 Top Load Washer
Maytag washer
Check to make sure your drain hose has a loop at least as high as washer top.  If the drain hose is not looped higher than tub water will continue to drain and it won't stop filling.  If it doesn'y reach the correct fill level it won't agitate.
Oct 29, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
