Question about Canon PIXMA MP530 All-In-One InkJet Printer
Whenever I print a page on my canon mp530 printer I get a black line down the centre of the page on the back of the printed page have tried cleaning print nozzles etc but no difference any ideas please?
SOURCE: scanning from Canon MP530 to Mac Powerbook
If you;ve installed the MP Navigator software from the CD, then you should be able to press the scan button on the printer with your Mac connected and the MP navigator will open automatically on your Mac ready to scan. You can also try going into Preview (the Mac app) and from the file menu select Import... and it should open a scan window.  Hope this helps!
Posted on May 07, 2008
SOURCE: Printing problems
Same problem. Definitely NOT a leaking cartridge or head. (Replaced both with known good set)
Posted on Jun 25, 2008
SOURCE: Pixma MP530 Fax Problems
I am having a similar problem. You do have to connect your phone to the jack in the machine in the "Phone" jack slot, as well as have another line out to the jack in the wall in the "L" slot. That is all I know. I am having problems with my voicemail. Either I can received voicemail, and no faxes, or faxes, and no voicemail (fax picks up at specified number of rings). It is EXTREMELY frustrating. The machine is *supposed* to be able to discern between phone calls and faxes..and that is not happening.
Have you come across a solution? Aghhhhh!
Posted on Sep 20, 2008
  • 909 Answers
SOURCE: Thick black line on printed page
If the line runs the way that the paper does I.E. vertical on a portrait then it is dirty rollers normally.
If you open the lid and wipe the rollers this shoukd reduce or eliminate the black lines.
Posted on May 03, 2009
SOURCE: Thick black line printing on the back of every page
your printer needs to be serviced and check printer alingnment
Posted on May 21, 2009
Solid black ink line, top to bottom, on back of every printed page
The possibility of the printer roller is dirty. To clean the roller, do
1. Press the START
2. Select Printers and Faxes
3. Right click Canon PIXMA MP530, select Printing Preferences
4. Select Maintenance
5. Select Roller cleaning, and Bottom plate cleaning
Nov 02, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Ink leak?
It's not the cartridges, the waste ink is coming up thru the bottom to the exit rollers. The only fix is to have a shop open it up, clean up the ink mess and install a shield that stops the ink from coming back up when it should go to the absorbers. The new machines all have this shield and the ink tube cut back to make the ink go where it should.
Feb 21, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Faxes are printed with a line running down the
If the line is on the back you need a shop to replace the ink absorber and put in a mylar shield to keep the ink from coming back up on the rollers.
Sep 29, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 All in One Printer won't print black
Try deep cleaning the black cartridge in the Maintenance section of the printers properties. Print head might be clogged cli-8m
Sep 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
MP530 printing a black line on the bottom of page I print.
After reading the instructions for taking the printer apart from top to bottom (where the absorber is), we opted to follow someone else's advice for a quick fix. We turned the printer upside down and used a box cutter to cut a trap door in the center of the bottom, pulled out the absorber, replaced it with an equivalent sized rectangle of printer's cotton, and taped the door shut. It has been working fine for several months now.
Jul 24, 2009 | Canon PIXMA MP530 All-In-One InkJet...
May 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
May 03, 2009 | Canon PIXMA® MP530 All-In-One Printer
Black Line on back of pages
Your problem is not isolated; I read of two others on this site in mid-August 2008 and added my own post.
I contacted Canon Support and tried their solution (which you've already tried); it did not work. Given the choice of repairing a printer that I've had (and babied) for less than 2 years or buying a new Canon at a discount under their Loyalty Program, I chose to take my MP530 to a Canon Authorized Repair Facility.
According to the repair tech, there is a problem with the waste ink tank and ink absorber pads. The repair facility ordered and installed a rebuild kit; it took about 2 weeks. The printer now works beautifully again.
If your printer is still under warranty, you're in luck. If not, ask that it be handled as a warranty repair. In my opinion, Canon should recalling and offering to fix this problem free of charge.
Aug 18, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Wide black line down middle of paper
I have same problem, with new ink cartridge, also tried cleaning the print head, no luck.
Oct 20, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
26 people viewed this question
old marine
old marine
