Question about Canon PowerShot G2 Digital Camera
Unable to get CF card to work. Keeps saying CF card error. Camera is a Canon Powershot G2.
  • 130 Answers
SOURCE: CF Card Error
Well there is a known problem witht eh CF memory design, i hope this is not your problem but it may be. Take your camera into a well lit area or get a small flash light. Open the memory door and peek down inside the camera and look at the pins inside the camera. Are they all uniform? does any look bent or out of place? there should be 2 uniform rows no pins should be missing or out of place. If they are you have a connection problem. This is one of the issues with this memory format and its why they have changed the design to SD. This is common with people who remove the cards alot and use a reader over time the card and the slot becomes warn and its very easy to bend pins because the card isnt sliding in smooth. If this is your problem (a few bent pins) you may have to take it in for service or try and fix it yourself. Ive read about people using a mechanical pencil. Remove the lead and the pin slips right into the top and you can carefuly move it back. Hope this helps!
Posted on Mar 30, 2006
  • 3 Answers
SOURCE: Canon powershot G2
I just repaired my Canon G2 with the same symptom.  The internal PCB that you plug the external AC adapter is defective.  The numbers on the board are:
GCMK-M1X
Posted on Oct 30, 2007
Check your memory card to see if its locked!
Posted on Aug 02, 2008
t00nz
  • 4738 Answers
SOURCE: memory card error for my canon powershot a95 keeps showing up.
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Posted on May 10, 2009
  • 11967 Answers
SOURCE: In my canon G2 camera I put 8GB CF card. camera
Your camera may not be able to take a card that big...check your owner's manual.
Posted on Dec 08, 2009
I recently received a Canon Powershot S200 Digital Elph, and When I put the CF card into the slot, every time it is turned on it says CF error. Any way I can fix this?
Did you ever format the card in the camera before trying to use it? This will erase the card so download any pics first using a card reader if necessary. Formatting will get your card working.
Apr 03, 2011 | Canon PowerShot S200 / IXUS 178 Digital...
CF corrupt with a big question mark. All of my pictures have disappeared and my camera will no longer read my CF card
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see this link.
Feb 28, 2011 | Canon PowerShot G2 Digital Camera
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Canon A10 - "CF card error" with new 4GB card
You need to format new cards in the camera before using.
Apr 05, 2010 | Canon PowerShot A10 Digital Camera
Dec 08, 2009 | Canon PowerShot G2 Digital Camera
Unable to load cf card in slot
The pinholder inside the camera has a bend pin or broken pins. You must let it repair. Ask Canon for an proforma invoice. Rotronica in the Netherlands can repair it for you, the cost is approx. 75,00 Euro.
regards,
Rob
Apr 30, 2009 | Canon PowerShot G2 Digital Camera
CF Card Error
Jan 03, 2008 | Vivitar ViviCam 3915 Digital Camera
Canon powershot G2
GCMK-M1X
Oct 21, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Memory card not reading in canon a75
So as not to spoil your vacation, go buy yourself a new compact flash card locally. They should sell them anywhere electronics are sold, including WalMart, etc. See if you can get this new card to work in your camera. If so, then you can work on trying to get your current CF to work, by trying to format it in the camera. If you can't get a new CF to work in the camera, then you likely damaged either the pins in the CF socket in the camera, or some switch that is pushed when the card is inserted (to tell the camera there is a card in it). It is unlikely you will be able to have this fixed during your vacation, unfortunately.
Mar 05, 2007 | Canon PowerShot A75 Digital Camera
CF Card Error
Sep 14, 2005 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot G2 Digital Camera Logo
91 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
