Question about Goodman GMS90703BXA Heater
Heater won't stay on more than a few minutes before tripping the breaker.
I turn the heater on and it works for about 15 minutes then trips the breaker and stops.
  • rahnee Dec 19, 2007
    I had a proffessional come over and I have a bad breaker. Also the insulation was loose so whenever the fan started it was sucking the insulation to the fan input and blocking the airflow. I found an independant contractor who only charges $20 to tell you what is wrong and how to fix it yourself.
  • Anonymous Mar 12, 2014
    PRODUCT # 5310052
  • 625 Answers
Blower motor is overloading. check and oil the bearings or you may need to replace the motor. check grainger supply.
Posted on Dec 18, 2007
Holmes hch6150 will not produce heat
Without having the heater to tear apart to see what is not working, you may try the following. Your heater is a 1500 watt heater and pulls about 13 amps of current. If you plug it into a recepticle that is already have load turned on, most recepticle circuits are rated for 15 amps and you have probably tripped the breaker for this circuit. Check your breaker panel to see if a breaker is tripped. If it has tripped, this will tell you your pulling to much current. Try another circuit that allows the heater to operate or find the other load on the circuit that is causing the breaker to trip. By the way to reset the breaker take the breaker to full off, this resets the trip, and then turn it back to on.
Hope this helps
Feb 13, 2015 | Heating & Cooling
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
P3RA-060K heater side blows breaker after 10-15 minutes
wire too small, breaker too small, loose connection, over amperage
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Dec 27, 2017 | Intertherm P3RA-060K Air Conditioner
I have a bfh5000 bionaire electric heater and it wont turn on and the red light blinks ???????
First turn the heater off using the On/Off switch. Then unplug the heater for 12 - 15 minutes. This will allow it time to reset itself if possible. Then plug the heater back in and turn it ON. If it didn't reset itself, check the receptacle its plugged in to to make sure that it's still working. If it's not, the circuit breaker for that receptacle has been tripped and will need to be reset in your home's circuit breaker panel. If the heater trips it again, there is a short somewhere in the wiring of the heater, which will have to be repaired.
Hope this helps you Troubleshoot the problem. Please let me know.
Mar 15, 2011 | Heating & Cooling
One of the breakers assigned to our Hot wtr htr has been tripping recently leading to loss of hot water. This has happened twice in the last month. After resetting the breaker things have worked fine,...
Breaker could be bad.
Let's do a quick check and save you money.
Open top cover on water heater and push in red reset button that might be tripped.
If reset is tripped, water heater should turn ON.
If reset will not reset, then replace upper thermostat:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If reset is not tripped out, then it is OK, so test two top wires on upper thermostat.
Use cheap multimeter from home center, and set dial to 240-250-277 VAC.
Test across top two screws on upper thermostat to see if you have 240Volts.
To do full troubleshoot on ordinary tank electric water heater takes 30 minutes and multimeter
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
If water heater is not receiving 240V, then the breaker is suspect, or a wire between breaker and water heater is loose.
See basic water heater circuit
http://waterheatertimer.org/240-v-water-heater-circuit.html
Now let's look at circuit breaker:
Mark suspect 240V breaker.
Identify all your breakers, and also mark another 240 Volt breaker that is same amperage as water heater 240V breaker.
Turn off main breaker.
Take front panel off breaker box.
The wires and lugs on main breaker are HOT, so stay away from that area.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Suspect breaker has 2 wires coming from breaker.
See if one or both wires are loose, and then tighten.
If wires are tight, then move these wires to the other 240V breaker that is rated for same amps as water heater.
Now turn on main breaker.
Put ear against water heater tank to hear bubbly fizzing sound.
This will identify if circuit breaker is bad, or if water heater needs a full troubleshoot.
It is not a good idea to run two 240V appliances on same 240V circuit breaker, so you may have to decide one or the other appliance until you can replace breaker.
Instructions to replace circuit breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater circuit.
Jan 07, 2011 | Water Heaters
My oil filled radiator trips the mains after a few
Try changing circuits (plug into one not protected by the same breaker.)
While the heater element can fail in your heater, I have had to replace several breakers after only a few years use after they became overly sensitive.
May 24, 2010 | DCS Heating & Cooling
My gas pool heater works for about 15 minutes then the breaker seems to trip. How can I fix this problem?
so how do you know is the heater ?the breaker trip when the pump is working w out heater? must of the times is the pump not the heater
Oct 13, 2009 | Hayward H-series Electronic Gas Pool...
Gfci breaker keeps tripping
sometimes gfi outlets go bad and trip try testing with a heavy draw machine in it or just replace it and see if this fixes the problem
Jun 22, 2009 | Balboa Instruments Duplex Digital Panel 2...
Water heater trip circuit breaker
I would say you have a bad element in the bottom.If the water is cold and heat until the top thermostat reach it tempture,then switch the bottom element and then the breaker trip.So replace the bottom element.
Mar 09, 2009 | Rheem 81VP6S/430126 Water Heater
Goodman GMS90703BXA Heater Logo
87 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Dennis Boxerman
vance jones
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
