HP Deskjet F2290, unable to print after paper jam
I am far from an expert on computers and gently removed jammed paper from my printer. However, after having done so, and putting a request to print, nothing happened. No error message, just nothing. Help!!!
    President:
  • 787 Answers
Try to reset the computer and printer.In last case reinstall the driver.
Posted on Sep 28, 2009
  • 138 Answers
Just On it twice and then off,, check you have removed paper jam and installed drivers.. aall
HP deskjet D2520 does unable to print. paper jams all the time.
Put less paper in the bottom, they jam if there are too many pieces. They don't hold as much pieces as some older models of printers.
Jul 03, 2011 | HP DeskJet D2560 InkJet Printer
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    A sheet of paper had remain in the cylinder
    1. Remove the rear cleanout from the printer.
    2. Gently remove any jammed paper or bits of paper.
    3. Close the HP Paper Feed Cleaning Kit software on the computer.
    4. Load plain paper in the printer paper tray.
    5. Press the Power button to turn the printer off.
    6. Press the Power button to turn the printer on.
    7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
    Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
    Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
    I am unable to print because of a "paper jam". I have removed the paper from the printer, unhooked the printer from the computer, etc. and continue to get this message. Can you help?
    A "paper jam" means that there is some paper or a piece of paper somewhere inside the printer, in the paper rollers. Turn the printer OFF. Open the printer and carefully look for a piece of paper or a paper page half-folded inside. SLOWLY pull the paper out. Replace the cover and turn on again.
    Apr 01, 2010 | HP DeskJet 3650 InkJet Printer
    My printer deskjet f2100 is showing a paper jam (red light showing on control panel) how do i fix it?
    folow the steps below 1. Check for and remove any paper stuck in the paper in tray
    2. clear the paper jam from the back of the printer
    a. unplug the AIO
    b. Press in the tab on the left side of the rear door to release the door. remove the door by pulling it away from the AIO
    c. gently pull the paper out fo the rollers
    d. clean the rollers with a lint free cloth that is moist with distilled water
    3. Lift the front cover and slowly remove any jammed paper
    a. unplug the power cable
    b. if necessary pull the input tray down to open it. then lower the print cartridge door
    c. gently pull the paper out of the rollers
    d. close the print cartridge door
    e. plug the power cable
    4. Verify that the print cartridge carriage can move freely
    b. check to see if the print cartridge carriage can move freely from one side to the other.
    c. remove the print cartridges
    d. gently move the print cartridge to tyhe far right of the printer
    e. remove the paper from the paper in tray, but do not remove the drawer
    f. remove the rear acces door
    g. with your fingers rotate the rollers "up" three full rotations
    h. close the rear access door
    i. replace the print cartridges
    j. plug the power cable
    k. turn the power on
    5. reload and test the printer
    hope this helps
    Nov 14, 2008 | HP Office Equipment & Supplies
    Hp deskjet 5150 paper jam
    u have to need to do change the printer roller
    Sep 01, 2008 | HP DeskJet 5150 InkJet Printer
    Deskjet F380 printer unable to print claims paper jammed cheched printer no paper jammed all other ptinter functions ok
    Hi
    Seems to be problem in sensors for that you need to open the printer and clean the sensor, If you are not expert in that then please check service centres for servicing.
    Boopathy.T
    Aug 17, 2008 | HP Office Equipment & Supplies
    Paper Jam in HP Deskjet F2100 All in One
    a. unplug the AIO
    Aug 06, 2008 | HP Office Equipment & Supplies
    Paper Jam
    I have exactly the same printer, here's how to remove jammed paper.
    1. Unplug printer from mains and your computer. 2. Turn Printer around 3. There is a darker-grey panel with a knob in the middle of it. Turn the knob anti-clockwise to release the panel 4. The jammed paper should loop around the roller. Gently pull on the loop slowly until it has released fully. 5. Put the panel back on the printer and turn knob anti-clockwise to lock it into place.
    Hope this helps.
    BurntLime
    Oct 29, 2007 | HP DeskJet 960c InkJet Printer
    387 people viewed this question
    jasbo
    jasbo
