Question about HP Compaq 6720s Notebook
Do I have a wireless connection "on/off" function on the keyboard for a Compaq6720s?
  • HP Master
  • 4,338 Answers
The wireless butyton and light is to the left of the power button, See chapter 2 page 10 in the user manual:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01401914/c01401914.pdf
Posted on Sep 28, 2009
    Guru:
  • 441 Answers
Yes, the button is to the left of the power button. It has a little antenna on it. Just press it once to turn on and once again to turn off.
Cheers
Please rate!
    Problem Solver:
  • 13 Answers
If it is red, you're OFFline, if it's the same blue as the power button, you're ONline
Disable inspiron 1525 keyboard
Step 1:
Dell sells technology such as computers, computer peripherals and consumer electronics to both consumers and businesses. Dell sells both wired and wireless keyboards and mice that are compatible with Dell and other computer systems. Dell wireless keyboards may encounter hardware, software or other problems under certain conditions.
Power Dell wireless keyboards transmit data to the Dell USB receiver, which in turn passes the data to the computer's operating system. The keyboard gets power from two AA batteries. As the batteries lose charge, the keyboard's transmissions can become intermittent. Replacing the old batteries with fresh ones will ensure consistent communication and resolve the power issue. b> Interference Dell wireless keyboards operate best and are least susceptible to interference when the user places them at the recommended distance from the USB receiver. The distance, specified in the keyboard's accompanying software or installation guide, varies by keyboard. Even if the user places the keyboard at the proper distance from the USB hub, metal objects between the keyboard and hub can create interference; moving objects that create the interference resolves the issue. b> Connection The Dell USB receiver that passes data from the keyboard to the computer requires proper and secure installation in a working USB port. If the receiver connects to the USB port improperly, or if the USB port to which the receiver is connected is faulty, the keyboard will not operate as expected. The user can reseat the receiver in the USB port, or connect to the receiver to a different, functioning USB port to resolve connection problems. b> Synchronization Dell wireless keyboards can broadcast at more than one frequency, just as their associated USB receivers do. If the two devices broadcast at different frequencies, they will not pass information to each other. The user can resolve this situation using the buttons labeled "Connect" on the top of the receiver and the bottom of the mouse. Pressing the buttons simultaneously triggers the synchronization process. b> System Dell wireless keyboards are compatible with most Dell systems. However, a keyboard may be incompatible with a given computer for reasons related to the computer rather than to the keyboard. To determine if this is the case, a user can connect the keyboard to a different computer. If the keyboard functions as expected with the second computer, the problem may reside in the first computer rather than in the keyboard.
Dell wireless keyboard problems
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=715E6659A4141AFAE040AE0AB7E10D59&doclang=en&cs= - Issue0_1
Feb 20, 2013 | Dell Inspiron 1525 Notebook
GE Wireless keyboard #98615 instructions say to turn the ON button in the bottom of my keyboard. There is no on/off button
As far as I know there is no ON button on the GE 98615 Wireless Thin-Profile Keyboard. Unless is the ON configuration for the NumPad which you will find it in the BIOS.
I Hope this might help you with your GE 98615 Wireless Thin-Profile Keyboard.
1.- Plug the USB receiver into an available USB port of your PC, no required batteries.
2.- Insert the batteries with correct orientation into the battery compartment of the keyboard
Please NOTE:
(a) This wireless keyboard provides factory preset connection channels and enables Plug and Play function. (b) This keyboard does not require changing connection ID as there is no ID button on the receiver. (c) When this wireless set encounters radio interference, keyboard will automatically change to a clean channel respectively. (d) Manually changing connection ID is not necessary.
Sep 01, 2011 | Computers & Internet
Print screen
Observe the condition to ascertain condition. For example, connect the keyboard to computer to ascertain response. usually with peripheral devices, connections to computer should display results of compartibility else mesages is malfunction missing media recogniseable. In the situation that the keyboard is malfunctioning as missing media is indicationof incompartible to computer. For example, wireless keyboards require adaptors devices attached to computer to function where the computer has to be wireless compartible. In the situation where a cables wired keyboard were attached to wireless computer would be missing the adaptor. Where a wireless keyboard were attached to a computer that least wireless with an adaptors would least produce any results. Circumpectively, the computer with wireless capabilities requires a wireless adaptor that recognies a wireless built keyboard.
Feb 22, 2011 | Dell SK-8125 Keyboard
The keyboard doesn't work, even though I just changed the batteries. Now what?
>when wireless keyboard or mouse runs out of battery, you need to re-establish the bluetooth connection in order for them to be functional again. To do so, you need to press the connect button on the keyboard and the USB dongle connected to the computer at the same time for about 8-10 seconds to establish connection. After that, you can try typing again. Same thing applies to wireless mouse.
Oct 03, 2010 | Gear Head WIRELESS keyboard/Mouse
How do i turn on my wireless keyboard
1 Follow the steps mentiond below:
•2
Leave your current wired keyboard plugged into the computer. Many computers will cease to function if their keyboard is removed.
•3
Make sure that the computer is on and is functioning properly.
•4
Plug the USB wireless adapter of the wireless keyboard into a USB port on your computer. If you don't have a USB port, then your computer is probably too old and likely won't support a wireless keyboard.
•5
Make sure that there are batteries in your wireless keyboard. Oftentimes, the consumer is responsible for putting the batteries in, and they don't come with the keyboard when it's purchased.
•6
Turn the power on for your wireless keyboard. The method of doing this varies depending on the model you've purchased, but the power switch/button is generally located on the bottom of the wireless keyboard.
•7
Wait for the keyboard to download it's driver software. If you don't have a connection to the Internet, use the software that was included with your wireless keyboard to install the driver manually.
•8
Use the wireless keyboard exactly as you would a wired keyboard.
Aug 31, 2010 | Computers & Internet
Connect wireless to acer aspier 4520
the function key if you look by the windows key it has Microsoft logo there should be a key that's says Fn which is the function key if you press and hold that down it activates the second mode on your keyboard if you look on the buttons you should see second symbol's mostly on the F1 -F12 keys which look for the wireless symbol as soon as you let go of the fn key your keyboard returns to normal hope this helps
Jul 27, 2009 | Acer Computers & Internet
How to activate wireless connection without FUNCTION key on lapto
The wireless button is required.there is no option in the softwares to turn on wireless.
Jul 06, 2009 | Computers & Internet
Wireless keyboard not functioning
I unplugged the usb connector and took out the batteries for both the keyboard and mouse for 30 seconds. Then I plugged everything back in.
Jan 09, 2009 | Kensington Computers & Internet
WIRELESS CONNECTION
check to see that your wireless antenae is on.. it is possible to turn on via your keyboard with a function key. this saves energy on the laptop. Look at your keyboard and see if you see a function key on one of your keys that is activated by teh FNC key.
Thanks!
Stan Skaggs
Jan 07, 2009 | Dell Precision T3400 375W 64bit (bwcw9z6...
Dell wireless mouse is blinking red, but functions. Problem?
try to rest the connection by pressing the connect button on the reciever and under the mouse together and relaesing them. it should work
Jan 04, 2008 | Dell Wireless Keyboard Optical Mouse w0147
HP Compaq 6720s Notebook Logo
126 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
