Question about Brother FAX T104 Plain Paper Thermal
T104 states reset or ribbon empty this is a new machine so i dont think the ribbon is empty how do i reset, or how can i download a manual
2 Suggested Answers
SOURCE: ribbon empty
WHERE IS THE CARTRIDGE HOUSING
Posted on May 08, 2008
Delonghi Magnifica Light B12 in manual states that
I had a problem where the machine would not operate and the water and grounds lights were on steady (red). After contacting customer support, they directed me to do a reset. This is done by disconnecting the power and holding down the ground coffee and decalcification buttons while reconnecting power. Then release the buttons and power on the unit. This revived my Magnifica from the dead, maybe it will work for you...
Nov 25, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Hey Jack, we currently have 3 Zebra s600's, 2 in use and 1 spare. I've recently added some zp550 printers on the 2 computers that have the s600's and screwed up the drivers for the s600s. I...
1. Reset the printer - to return the printer configuration to factory default values,pressFEED and PAUSE at the same time while turning the power On (l).
2. Download this Maintenance Manual for Zebra S600 and follow the troubleshooting steps from page # 66.(table 3-2) Printer stops, pause and paper/ribbon LEDs both on / Printer stops, pause LED on and paper/ribbon LED flashing.
3.Uninstall / Re-install the zebra printer driver .Use this revouninstaller to remove the driverClick here to download the driver for Zebra S600 .
Oct 14, 2011 | Zebra Stripe S600 Thermal Label Printer
How do I program this timer?
T104R3 is ordinary 240V T104 timer mechanism inside a beige metal weathertight enclosure.
Put ON-OFF trippers on dial, lift and rotate dial until current time lines up with silver pointer.
Reset current time after power outage.
Open following links for T104 Instructions:
http://waterheatertimer.org/pdf/Intermatic-t104-240V.pdf
http://waterheatertimer.org/How-to-operate-and-set-T104-timer.pdf
Open following link if you have T104R201 with fireman's switch
http://waterheatertimer.org/pdf/Intermatic-T104R201-instruction-manual.pdf
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Jun 23, 2011 | RTO Intermatic T104R3 Timer Switch 220V -...
It says ribbon needs to be replaced or reset can i just reset and still use that ribbon
i got a new ribbon and it keeps saying ribbon empty reset or replace. i unplugged it for 30 seconds didnt do any good how can i fix this? it is a brand new ribbon
Jun 17, 2011 | Brother FAX-575 Plain Paper Thermal
I have tried umpteen times to change the ribbon and have by now undone white + blue plastic roll ends, maybe they're now no longer in the original position, I've tried in every possible way and I can't get...
Download the manual for your machine and check the title "Changing the ribbon" under section 13 - Troubleshooting and routine maintenance and sub-section Routine maintenance.
Although the manual is also black & white, the images are clear and the colours are signalled.
http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000343/T8_UG_UK.pdf
Aug 30, 2009 | Brother FAX T104 Plain Paper Thermal...
Can I reset the used ribbon to recieve a fax ready to print
You can rewind the ribbon. But the areas that has ben transferred from past fax's will be blank.
Jan 28, 2009 | Brother FAX-575 Plain Paper Thermal
Delstar DS 4327 shows "disk empty" after downloading songs
how do you reset mp3 player? will not charge or power on?
Dec 28, 2008 | Delstar DS-3512 MP3 Player
Sony UP-DR150 4x6 "ribbon error"
The black spool of the ribbon has a built in chip, If that chip is damaged it renders the ribbon unuseable. Be very careful if you take out party used ribbons and re insert them later.
Dec 15, 2008 | Sony UPDR150 Thermal Photo Printer
Ribbon empty
Winding technique:
To wind a new ribbon, take the cartridge housing apart and remove the old ribbon and two cardboard cores. The new ribbon is fitted with the larger roll (the ink ribbon supply spool) at the rear side of the cartridge (as the housing is viewed when it is normally installed into the machine). The ribbon winds over the topside of the rear spool (the supply side) and feeds into the underside of the front spool (the take-up side). Make sure the ribbon is wound neatly, evenly and is tight. If the ink film has become detached or is too loose on the front spool it will not wind on and cause a machine error. If required, use a small amount of sticky tape to secure the ink film to the front cardboard spool and then neatly wind it on to the take-up spool a minimum of five turns, making sure the film does not overhang at the edges. Now reassemble the housing and refit into the machine.
If it’s still not fixed:
If problems persist after fitting a new ribbon, try replacing the entire ink ribbon unit (cartridge housing + a new ink ribbon) using a new, genuine Brother unit before requesting a service; this will be less expensive as the actual housing may have been damaged and is causing the problem and this unit is readily available as a consumable item through sales outlets. If the machine still has problems, book your machine in to be repaired with an authorised Brother Service Centre.
Feb 17, 2008 | Brother FAX-575 Plain Paper Thermal
Brother FAX T104 Plain Paper Thermal Logo
309 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
