Duo Therm Air Conditioner Mod. 59136.331/ Control box E 6360360
Unit is installed with 120 volts to the unit and 12 volts dc with polarity checked. However there is no readout on the thermostat.
Any suggestions?
  • 236 Answers
Something wrong with your thermostat, but if you are using a electronic thermostat and have the indication of supply like light in your control then you can replace the miniature relay that triggers the cool mode of the unit. But no indication of supply try to check the fuse, then if not works you to replace new thermostat.
Posted on Jan 03, 2008
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
Power supply polarity for Viking K-2000-DVA
The center pin of the power jack on the unit is negative (-) 12 volts DC. It is also common to all of the input common terminals. This is important when using a common power supply for other equipment such as 12 volt battery backed system for an alarm system.
on Dec 30, 2013 | Viking K-2000-dva-multi-input Voice...
What is reverse polarity
Reverse polarity means in a dc voltage scenario (boat camper anything 12 volt Dc) thatvthe positive ( red) and the negative ( black ) have been switched or reversed.In a 120 volt ac scenario (house ,garage , outlet etc.) It means the hot
( black ) and the neutral ( white) are reversed.
hope this helps.
Dec 04, 2013 | Heating & Cooling
How do I remove olp message
Its an inverter DC to AC---what since I do not understand the described problem is the unit doing or not doing?
Dec 04, 2012 | Cobra Cpi 2575 5000-watt, 12-volt Dc To...
Generac 5500XL, model#09778-7 no output. Changed the power regulator board. No luck. Flashed the 120 plug with 12-30vdc from DC board. Nothing. Excited the brushes directly with DC board. Only got 2.36VDC...
Double check your brush istallation. positive side toward rotor bearing, if you put 12 vdc directly into brush pack and check with a meter at the 120 vac outlet and have low or no voltage, you may have no resistance in your rotor slip rings, excitor & main windings also need a resistance check. 12.6-16.7 ohms (rotor) 2.26-2.80 ohms (excitation) .26-.32/.28-.35 main or power windings. Note: unit running when appling 12 volts to brush pack. 2-5 second only, ( This test tells you the rotor & stotor are ok )
Jan 22, 2010 | Coleman Powermate 5000W Home Backup...
Air conditioner not working plugged in or on generator, heat not working either--nothing 2000 jayco designer
If you have AC hydro for sure to unit, perhaps a fuse in the 12 volt DC panel has blown, or in thermostat itself. Hear any clicking at AC unit when turned on? If not, check all your fuses in 12 volt DC panel. Check breaker didn't trip also on 120 VAC.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Power Source
Are you certain the polarity of the connections to the TV are correct? If you connected them in reverse you may have damaged the TV. If there's a fuse in line check that too. BMW
Jun 01, 2006 | Ktv 9BNC 9 in. Television
Heating & Cooling Logo
448 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
