Question about Ryobi Garden
I don't know which tube goes where. The lines fell apart when I started repair.
  • 770 Answers
I assume you are speaking of the gas lines that come out of the primer bulb...these tend to get brittle and fall apart. Am I correct?
Posted on Sep 28, 2009
  • Hal Hallman Sep 29, 2009
    I haven't heard back from you for clarification, so here is the solution to what I assume the problem to be. There are 3 separate lines. Usually one is a bit smaller than the others. One line goes from the primer bulb to the tank..Usually the small one. Another goes from the tank to the carb...usually an inline filter in this line. There are 2 connections on the carburator...connect to the lower one, if you have 2 different sizes of tubing, this will be the larger of the 2. The 3rd line goes from the primer bulb to the upper carb connection...this is also a small line (if your model has 2 sizes of tubing). Good luck.
HOW DO I PUT SEAT BELT BUCKLE BACK TOGETHER
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem Mazda Protege
Oct 10, 2014 | Mazda Protege Cars & Trucks
I have a whirlpool wfx9050xw00 it seems to have eaten a credit card and drivers licence....found part of card in the cleanout tube under the front ..but , how do you take machine apart to find other
Sounds like a case of identity theft! :)
Remove the hose from the tub to the pump and check there. Also, reach up into the tub to see if you can fell anything.
Dec 02, 2012 | Whirlpool Washing Machines
Remote for appollo 1996 fell apart need to know how to reassemble
Replace it, they don't provide repair instructions for this type of device.
Nov 05, 2012 | Cars & Trucks
Schematic diagram to repair a STIHL FS 45 trimmer
hello, need a operators,parts manual for a stihl,echo chainsaw,hedge trimmer,line trimmer,edger,pole saws,concrete saw, as far as i know thay don't post any of these on line for the consumer,if i had a dealer number than i would be able to provide you with one,these manuals are available through the dealer only,hope this helps.``
Jan 11, 2012 | Garden
I unscrewed the part over the light bulb, than the smaller part that holds the thread tension bit and a small coil fell off, I don't know where it goes back, can I find anywhere a diagram of the machi
I cannot help and doubt a diagram could be found with that much detail but you could try the manufacturer. I suspect that the coil had been around the screw you removed or in the screw hole.
Dec 01, 2011 | Janome Harmony 2039 Mechanical Sewing...
I took my Dell wireless mouse apart to clean the wheel. The spring fell out. I don't know where it goes back ( I didn't see where it fell from). I put it back together without the spring and now...
i beliece it is very fiddly to put that certain spring back in cus it is hard to see where they go back, my advice is to go to a local PC store and get them to use the right tools to place it back in for you.
Jul 15, 2011 | Computers & Internet
The chrome tubes will not come apart
It's a tight fit to start with, and it's nothing unusual about that if you don't take them apart regularly.
One way to loosen them is to tap the tube that goes in and near the union, with something that won't damage the metal.
Just keep turning the tubes and tapping.
They won''t come apart immediately, but with a little patience they will come apart.
Likely you'll see some rust inside as well.
May 30, 2011 | Henry Numatic "" Canister Vacuum
Vaccum line fell off rear end not sure where it belongs
the vent tube for the ring and pinion housing is the only tubing made of rubber for the axle
Feb 14, 2010 | 1997 Dodge Ram 2500 Club Cab
Gas lines fell apart and I have new ones for a ryobi 790r trimer but do not know what line goes where there are 3 hoses could some one show me or tell how to fix this trimmer??? warren9@hotmail.com
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 30, 2009 | Garden
My filter queen fell apart!!
http://geeksquad.fixya.com/ThreadView.aspx?prdid=20821&thid=780805
Posted by julieartlit on Jul 14, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Not knowing what actually fell apart is to contact your local vacuum cleaner dealer in your area or to call the Filter Queen factory cust serv or tech serv @ the phone # listed below, you can also request a new owner’s manual so that you might see what actual fell apart and you might be able to fix it yourself. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.filterqueen.com/
Customer Service 1-800-344-1840
custserv@filterqueen.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Filter Queen Majestic Canister Vacuum
Garden Logo
35 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
