Question about Maxxima EGF 7221 3 Led Crank Flashlight with Built in Compass
After cranking for a minute or so, the light dims to an almost unusable brightness with in 10 seconds.
  • 8,404 Answers
They dont last forever regardless of the name on them.
Posted on Sep 28, 2009
1996 Toyota Corolla cranks will not start. Has spark, fuel pressure at rail, no injector pulse with noid light when cranking. MIL light very dim. Unable to retrieve fault codes
Check distributor rotation to ensure good timing belt. If good, check crank and cam position sensors. The computer fires the plugs and injectors based on many factors but most importantly the crankshaft and camshaft position.
Jan 24, 2017 | Toyota Corolla Cars & Trucks
Why are my headlights dimming for 5 to 10 seconds and then getting brighter
sorry I disagree, your battery is fine a relay/circuit breaker is bad in your lighting circuit
Jun 03, 2014 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
2007 Hyosung Avitar GV 650 the headlight keeps getting bright then it dims
Hi, Oliver if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lightling coil.
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Why does my headlight go dim get bright
Headlights bright then dim ELD or
HYOSUNG Aquil GV650 Service Manual
HYOSUNG AQUILA GV650 PARTS CATALOGUE Manuals
HYOSUNG GV 650 EFI Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 13, 2017 | 2007 Hyosung Avitar GV650
My engine misses and loses fuel pressure, and engine surges when switching between brights and dims. Can this happen because of a bad battery?
Check altenator to see if charging.
Check fuel pump, replace if needed.Check Throttle positioning sensor, replace if needed.
Jan 21, 2013 | Cars & Trucks
My 1993 nissan sentra 1.6 wont run and check engine light wont turn on,bulb is ok
Could be any of several things. If the crank sensor is marginal and not sending pulses, the fuel pump is shut off. This is for safety. The pump is energized for a few seconds as key is turned in preparation for starting then engine must rotate normally to keep the pump on. If it stops, in a few seconds the fuel is cut off.
Aug 17, 2012 | 1993 Nissan Sentra 4 Door
When high beams turn on both headlights turn off
Relay may be crapping out. Try swapping it for another relay in the box.
Aug 20, 2017 | GMC Vandura Cars & Trucks
Screen dims when lights in room are off
Look in the owner manual or call LG (brand listed here) as I suspect the set has a light sensor that tries to adjust brightness as light in the room changes----this feature has been on many sets for nearly 50 years---on a lot of the very old ones we would remove that part as it just created issues.
May 01, 2012 | LG Televison & Video
Black screen. Power light binking from dim to bright
I have exact same problem but mine happened to 2 of my x2gen monitors at the same time,really strange.
One was purchased 01/07 and the second 04/07
Took my PC in, no problems
Took one of the x2gen in,was told monitor is bad
How could both monitors go bad at the same time???????
Mar 20, 2009 | X2Gen MW22U Monitor
Lights go out
Dimmer switch is going bad. If you rapid fire the switch they will switch from bright to dim or dim to bright. replace the colum switch.
Feb 08, 2009 | 2001 Dodge Ram 3500 Truck
Maxxima EGF 7221 3 Led Crank Flashlight with Built in Compass Logo
80 people viewed this question
Top Maxxima Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Maxxima Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
