Question about Kenmore 43142 Front Load Washer
Maytag Neptune wash machine. Clogged detergent compartment
Maytag Neptune wash machine. When I turn it on the water comes shooting out of the detergent compartment.I took the compartment out and ran hot water slowly down the detergent passage but it is still clogged.
    President:
  • 1,937 Answers
This may not help much but here is the Maytag Neptune installation and service manual.
You may be able to better troubleshoot your problem with this.
It's a PDF document that may take a couple of minutes to load.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
Posted on Sep 28, 2009
I have a front loading Maytag Neptune washer. I am constantly gettings the "SUDS" message even when I am hardly putting any soap in. I will also get the "No Drain" message, which used...
This typically happens when you use regular detergent instead of HE detergent, which stresses the pumps. Are you using HE detergent?
Also check for blocked drain hose or clogged water filter.
Apr 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
Water does not dispense out of bleach or softner compartments but does come out of detergent compartment,changed dispense valve assy. but no luck.
Did you check to make sure your hoses weren't clogged. Also check to make sue you're getting power to your water valve solenoids. If getting power check hoses.
Dec 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune is not getting clothes clean
SPOT COULD BE DETERGENT OR SOFTNER IF YOU USE IT- TRY DISOLVING DETERGENT IN WARM WATER BEFORE ADDING IT TO THE MACHINE- THIS WILL TELL YOU IF IT IS THE FAULT.
INSUFFIENT WATER WILL ALSO CAUSE THIS PROBLEM. SO WILL OVERLOADING
Jul 08, 2009 | Washing Machines
Washer machine wont rinse or open door
did it drain after wash? there is a green pull cord hidden at front of detergent compartment to open door. if it did not drain but pump tried, then clean out hose to pump in rear of unit. remove rubber hose from tub at pump and look for obstructions.
water will come out even if tub empty
Jul 05, 2009 | Maytag Neptune MAH7500WH Front Load Washer
Clogged screen on water intake.
it should just come out with a nice firm, but gentle pull. problem is u need to be careful because if its that clogged up, its probably weak and might break. U can always just buy new ones at sears, or home depot.
Mar 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG front load Washer MAF1300AAW Water is coming out of detergent dispenser and flooding my laundry. I have tried both powdwr and liquid detergent, the same happens???
ck for blockage on inside of tub where water enters any kind of blockage there (lumpy undisolved dry detergent ,socks etc) can cause blockage and water to back up into dispenser and overflow
Jul 31, 2008 | Maytag Washing Machines
Neptune washer detergent department that is on the lid
use vinegar in cleaning it! soap, as it is made of mostly soda dissolves in vinegar.
also vinegar helps remove bad smell on the machine cause by residue dirt from clothes.
Feb 26, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 43142 Front Load Washer Logo
64 people viewed this question
fordexpert
Mike Squire
Robert Rankin
