Question about Dryers
Whirlpool Duet Sport dryer heat tripping off
I've seen all the PF notes here, but that's not quite my problem. It runs. It sounds like it's working, but there's no heat. It will start off with heat if I reset the breaker, but at some point it trips off the heat. I have cleaned the vent hose. That seemed to work for a few days and then it happened again. I have made sure the lint trap is cleaned out for EVERY load since this started happening. The only thing I haven't done is take off the toe plate to see if there's something loose. I don't want to have to call out a repair man or an electrician if it's not necessary! Not in the budget right now, as I'm sure many of you can relate.
    President:
  • 1,776 Answers
I understand what you mean about budget completely. I would check for a blown thermal fuse or a faulty heating element.Both components can be tested using a multimeter or ohmmeter and checking for continuity. Be sure to disconnect the machine from power before attempting any repair. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. A lack of continuity would indicate a faulty component. You did the right thing in cleaning the venting, since most power failure or PF codes or a tripping electrical breaker are caused by poor venting/air circulation. Anyway, I am very sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 28, 2009
My Whirlpool duet sport dryer got hot and shut off after running 20 minutes.
Sounds like you may have a bad heating element that has grounded. You should have this looked at to make sure if you aren ot handy to open the dryer up and inspect the heating element your self. make sure the element wire has not broken and fused itself to metal inside the dryer heater housing.
Feb 02, 2017 | Whirlpool Dryers
I have a whirlpool Duet gas dryer, model ggw9200lw0. It will glow then heat up but switches off right away.
It sounds to me like your flame is not getting enough air. Make sure that ur screen is clean then clean your dryer vent. The easiest way to see if it is your dryer vent is to take the vent off the back of the dryer. If it runs good without it then you need to clean it. If the dryer heats up a couple times then wont heat up after that then you need to replace the coils
Aug 26, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
PF code on Whirlpool Duet Dryer. Tech out says its the board. replaced worked a little now doesnt. doesnt quit in mid cycle. just will not start most of time. Called electrician-everything is fine he...
Sounds like you have a loose connection somewhere.... I would try and check all plug connections to may sure you are getting a good connection....and that one of the pins has not come out of its holder in the plug .,.
May 24, 2011 | Dryers
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
I have a Whirlpool Duet sport dryer that came with the house I bought a year ago so I have no manual. What does it mean when the display says PF? Clothes were dry but display waid PF
The only PF I am aware of means power failure. Try unplugging the unit for awhile then try it again. This may reset the computer.
Feb 14, 2010 | Whirlpool Dryers
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Brand New Whirlpool Duet 9450 Error Code PF
This is a problem I've seen before, or something similar. I think you've got a bad connection on the neutral wire. Either in the plug or at the panel. Have electrician check the neutral wire back to the panel from the plug.
Jul 25, 2009 | Dryers
Whirlpool Duet Sport Dryer PF code
After ranting and raving about similar issues with my own Whirlpool Sport, with no success from a ton of repairs and technicians, I decided to check the exhaust vent from dryer to outside - thinking that the dryer must be sensing an overheating problem to trigger internal shutdowns without tripping the house breaker. Sure enough the vent flap on the outside of the house had become stuck, instead of flipping open when the dryer is working. I fixed the vent flap and the problem was solved. So check all aspects of the venting - a squashed flex hose, stuck or partially closed vent flap, something covering the vent. Sometimes the simplest solutions are the correct ones.
Mar 10, 2008 | Dryers
Dryers Logo
629 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
