Question about Symphonic ST419E TV
My television has no picture just one thin line in the center. Does anyone have any suggestions as to what is wrong?
  • 700 Answers
If that thin line, mostly white line running across the center of the tv horizontally. Most likely you have a vertical deflection problem. Cold solder and problematic vertical IC and near component, usually capacitor is at fault. This is for a tube television.
Vertical IC replacement or resoldering of the pin may do the work. But if you are not inclined on electronics better not, nasty voltages might zap you.
Hope this helps.
Posted on Sep 28, 2009
    President:
  • 787 Answers
You have a problem in vertical deviation in your television.It's need to be repaired by specialist.
Someone plz help me the same thing is broke and what is ic
Posted on Dec 24, 2009
I have the Samsung 50" projection HDTV HLT5075S-
If the the thin lines you describes here, are across the screen, and it is present all around the screen, and the spacing between them is at about 1 inch apart [whit thin lines along with picture], the fault is due to some electrolytic capacitor/s at its video output supply voltage. If the screen voltage has became more than normal, this type of fault can occur too. Anyway, your TV needs a through checkup. http://electronicshelponline.blogspot.com/. Check this link. One among the posts there have details about these kind of fault. Technically, this fault is called 'vertical retrace lines', Check the link. If you wish to get any more assistance, be free to do it by comments here.
Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service center.
May 29, 2013 | Televison & Video
Thin white line on right side of tv intermittent
The only easy hope here is centering is off just slightly to the left and the line etc will show on certain scenes and or channels.
Not sure if this set has a centering in customer menu or maybe in the tech menu---a call to sharp might answer this for you.
Aug 28, 2012 | Sharp LC-32SB24U 32 in. LCD TV
Picture go into a thin line.
You have a thin horizontal line in the center of the TV. You, in this case have vertical IC that has bad grounds. Resolder the vertical IC pins and check the capacitors in the immediate area and replace these caps as necessary. If you still have a horizontal line, you will have to replace the vertical IC. Find a TV tech or someone with electronic experience to do this for you. Should be reasonable to fix. Thanks for asking and Good Luck!
May 30, 2010 | Sanyo AVM-3659S 36" TV
I get a thin line of distortion on my sony xbr 42in
Your format is wrong. Make sure that your tv is in full mode and your direct tv is in 1080i stretch mode. This should correct the problem. Also, WB is having problems. This is common on their channel. If it is happening on any other channel, try the above. Hope this helps. JOHN
Feb 27, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Dec 23, 2008 | Televison & Video
TV has a thin horizontal line across the screen
intermintence in vertical IC deflection its a job for experienced tech need to look for that circuit and do fine job resolding that IC
Apr 01, 2008 | Sanyo DS31590 31" TV
PICTURE IS ONLY FINE HORIZONTAL LINE
Hi there,it looks as if you have a frame collaps,this is the first time i have ever heard of this on an LCD tv,i take it that there is no picture at all only a thin line.
Dec 23, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
Symphonic ST419E TV Logo
1,188 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
