Question about Lanzar SVDVDIN70 Car DVD Player
Metrik headrest DVD player
This DVD player uses FM stereo for audio but I get a lot of interference. I tried to use the built in speakers but could not get it to work. The manual does not say much about this. How can I fix this?
    New Friend:
You have a bad grounding, try to ground directly to metal chasis with a not so thin cable scratch the surface if necesary.
Posted on Apr 27, 2013
  • 30 Answers
The unit is basicaly picking up engine noise from the car, u have to geta supresser to fix the noise
Posted on Sep 25, 2008
    Scholar:
  • 143 Answers
Try manually tuning your stereo up and down one or two places either side of the suggested frequency to fine tune it.
or if the frequency modulator has several presets, select a different frequency & retune the recieving stereo.
Posted on Dec 18, 2007
Trying to hook up speakers to Pyle Pro PD1000 stereo receiver w/built-in DVD/CD player. I believe that I have speaker wires hooked up correctly but when I play CD no sound. I can actually hearing sounds...
I went thru user manual..there is no special way of wiring speakers..
pls check carefully the speaker connections again and the "speaker selector" too..
what about "MUTE" button ? it should be "OFF" ...
and try to test it on FM radio first ..
just in case ,if you need the soft USER MANUAL pls visit the URL below..
1000 Watt AM-FM Receiver w/ Built-in DVD/MP3/USB
http://www.pyleaudio.com/sku/PD1000A/1000-Watt-AM-FM-Receiver-w-Built-in-DVDMP3USB
Jul 10, 2011 | Audio Players & Recorders
Iv hade these forj dvd monitors installed but i can only get sound on the radio
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
As for why you have NO sound, press the FMTX button repeatedly till the screen displays no FM transmitting frequency. Then you should be able to turn up the volume on the DVD player headrest only.
Nov 17, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
I have a metrik mhp 900 headrest sistem but i only have the monitors wat else do i need
you need an interface module to operate the sound and the visuals, do you already have a dvd playing stereo? if not you will need a dvd player as well, any more questions about this please write back
Aug 05, 2009 | Car Audio & Video
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Audio on portable DVD player decreasing.
Could be a blown speaker or the amp circuitry driving the speaker is bad. One way you can get around this is to run the audio through the auxillary output of your dvd through either headphones, your car stereo through a line input, or hook up a pair of external speakers to the player.
A lot of times the quality of the audio in the built in speaker on portable DVD players is not of good quality to begin with. The above suggestions should correct it.
Dec 10, 2008 | Audiovox D1708 Portable DVD Player
DVD Message: Bad Disc
If not available any more, you are scr---d.
You can check with this outfit to see if they have anything that will fit in your situation. Crutchfield Car Stereo Speakers Home Theater Pro Audio 4k TV
Sep 09, 2017 | TMI Products Vizualogic Headrest Pair...
Dual DVD Headrest System
you could try an fm modulator which allows you to tune your radio to the set frequency and then gives you sound through your speakers
May 23, 2008 | Myron & Davis Myron Davis 6.0 " TFT/LCD...
Concept mobile dvd
I have a Concept DVP 500 dvd player the audio quit working through speakers, was programmed for a certain station. what could the problem be or solution to fix it
Apr 07, 2008 | Concept Slot Load Half-Din DVD Player Car...
Lots of static when playing over the stereo speakers, and the screen seems loose
sorry but what u have is called a fm modulator some are adjustable some not go to your local car audio shop to find out or take your headunit out and look behind it if so tune the fm mod to a different station one thats not being used there are three preset station on the fm mod but remember just because theres no station on that radio channel were u live dont mean there wont be one when u go into town thats the bad thing about fm mods best thing to do is get a indash cd dvd radio and as far as the lose screen just hand tighten the screws flip down the screen look up there should be 4 or 6 screws there just tighten them up a little this is normal
Dec 18, 2006 | Farenheit MDM-830CM Car DVD Player
Lanzar SVDVDIN70 Car DVD Player Logo
87 people viewed this question
Top Lanzar Car Audio & Video Experts
Morne Olivier
Chris Ward
xxxxxx xxx
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
