Question about GE Spectra JBP78 Electric Kitchen Range
Need top burner for model number jbp76g 2vww - GE Spectra JBP78 Electric Kitchen Range
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You can get the burner from this link--
GE jbp76g2vww Range Top Burner
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Sep 28, 2009
A burner on my ceramic stove top doesn't work
Without the brand and model number, it is difficult to answer your question. There should be a reference number somewhere in your stove top. That would be your starting point, and from there, seek the needed info using the model number and make. Try a new ceramic burner assembly at that location....it's plug and play.
Jan 08, 2015 | Kitchen Ranges
Burners on 1972 model Magic Chef stove top
You need to know the model number for your unit. You can go to searspartsdirect.com or to repairclinic.com and if any info is still available for that model, you should be able to pull up technical drawings and parts lists.
Jan 27, 2013 | Kitchen Ranges
HOW TO CONVERT FROM NATURAL GAS T PROPANE
Their are 2 types of ranges. Ones with sealed burners and ones that do not have sealed burners. The sealed burner ranges must have a kit to replace the orifices. The none seal burner models are simply called crank down and flip models. That means you flip the screw on top of the regulator to where it reads LP. and then you tighten down the spuds on the top burners and the oven valve and then you adjust the air shutters.
Note: Some stoves with sealed burners cannot be converted to LP. The model number you posted is not a correct model number.
Nov 19, 2010 | Kenmore 72002 / 72004 Kitchen Range
Broken glass top inset ''burner ring''
If you are referring to the bakelight material, this is an insulating compound and the burner still may work. I would not use this long term in this manner however. This material insulates as well as helping maintain an even heat transfer of the burner. Long term use, may cause damage to the cooktop. The burners are replaceable, but the prices vary depending on the size of the burner. The part numbers are as follows:
6" radiant heat burner - WB30T10129
8" radiant heat burner - WB30T10132
9" radiant dual heat burner - WB30T10133
You can view these parts at searspartsdirect.com under the "Cooktop" heading. You may find the parts cheaper at these other websites, by searching for them using the part numbers provided:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary at the other websites. Sometimes they may not carry the model number, but the part numbers are still listed.
If you have further questions, please post back and let me know. I hope this helps you.
Dec 22, 2009 | GE JBP65 Electric Kitchen Range
Need to know the BTUs on stovetop Burners
BTU ratings are usually the Model Number plate which is located in one of three places for Maytag:
1-Underneath burner top if top lifts up easily
2-On left lower front edge of frame with door open
3-Left edge of front oven frame with drawer open
Aug 23, 2009 | Kitchen Ranges
How can I tell the model number on a magic chef gas stove (with ''T'' clock) that is about 15 years old. I actually have the user manual, which tells me that the model # is located unde the left top on the...
most of the time the top will lift straight up with a few clips that let it just pop up and there is a prop rod under the top. also you can look in the bottom drawer area that is usually where the model # is if it has sealed burners.
Jun 22, 2009 | Magic Chef 31000 Gas Kitchen Range
I meant to push broil, but pushed clean and my food is locked inside. How do you cancel the clean?
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Get me the model ,number for your oven and I will be able to help you better, Thanks, Sea Breeze
Mar 29, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Need Manual For Electrolux Oven Model EOB 985GR
Having trouble locating the correct model number. Look at following areas for the model number
  • Let me know, Sea Breeze
Mar 27, 2009 | Electrolux Ovens
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
GE Spectra JBP78 Electric Kitchen Range Logo
83 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
