Question about Ovens
I have a Kenwood ckb200 model which is not yet two years old. My oven is no longer warming. The fan is working but only producing cold air. Can you advise what may be the problem
vest6
  • 196 Answers
SOURCE: smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Posted on Jan 26, 2008
SOURCE: Bosch fan oven not working
This does not mean your element is broken. Although it could be. Call Bosch and ask them if the unit has a pressure switch (you will need the model number). Pressure switches are more common on Gas ovens, but it might have one. If the pressure switch is not being activated by the fan, that could be the problem. It could be a contactor, it could be your power switch. It could be a break in the wiring. Or it could be your thermostat, or it could be the element. Service companies usually charge you for the cost of traveling to your place and around here hourly rates from $65-125 per hour for labor. It could take up to two hours to find out what the cause (or causes of the problem are) depending on how thorough they are. There could be a return trip charge as well if they need to order parts. And the cost of parts as well. you could be looking at anywhere from $300 to $1200 dollars depending on how many components might be damaged and the cost of the parts. If you want to save some money in the future, always check your fan blade to make sure it is free of debris (especially tin foil) and make sure the motor on the back of the oven has some clearance from the wall so it can cool itself.
Posted on Jun 17, 2008
barkencoa
  • 3463 Answers
SOURCE: smeg oven
Sounds like you need a new oven element fitting.
Posted on Dec 08, 2008
  • 244 Answers
SOURCE: door does not seal, hinge looks fractured
you'll probably need to replace the whole door and hinges. the internal springs (inside the door) may have failed and allowed the door to drop and damage the hinges. don't believe it's fixable, but is replaceable.
at what cost, i can't guess- even if the parts are still available! compare the cost of fixing to the cost of replacing!
good luck!
Posted on Oct 04, 2009
barkencoa
  • 3463 Answers
SOURCE: Oven blowing out cold air
You need to replace the oven element This is located at thr rear of the oven compartment.
If there are no screws securing cover at rear of oven compartment, then you are going to have access it from the rear of the oven cabinet, on the outside.
Hope this helps.
Posted on Dec 20, 2009
The fan in main oven only blow out cold air
The fan does not produce hot air. It just circulates it. The thermostat turns on the heating element and the fan moves the hot air around. Unless you have an odd working machine. Baked bread for years an it only moves air for even heat.
Jan 31, 2015 | Ovens
My kenwood CKB200 oven tripped my mains circuit. When I put the power back on the Oven did not heat up as well as before. I am assuming that one of the elements has gone. There is less heat at the bottom...
ISOLATE THE MAINS POWER BEFORE OPENING ANY PANEL ON YOUR APPLIANCE
There are sometimes up to three heating elements in simular types of ovens.
A Visual inspection is required to accertain which is the element not working, remove rear panel, there is odd types that have the element to the side of the fan assisted oven, have a good look when panels removed. The blow element usually has a blow out hole with Black Gray at the point it will feel rough not smooth like the rest of the element case, the second way is a bulge on the surface skin, it should be easy to identify. Part could be obtained through www.whitegoods.co.uk you will need the model and serial numbers. Some models you have to remove the fan or fans if twin, some models have top fan usually no element in the top except grill.
Hope this has been helpful please send me info if more tech is required.
John
May 20, 2011 | Ovens
Hi, I have a Electrolux EOG 900 builtin gas oven & gas grill, fan very noisy. Its 10 years old, willl the grill & oven pack in if the fan gives up altogether. Would it cost alot to fix. Hope to...
They won't pack up.. The fan is there to circulate the warm air. It might not heat up or cook as quickly as it used too. It will not cost much to fix though, labor will usually cost more than the part itself.
Good Luck
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | Electrolux Ovens
Main oven not heating up but fan is working on kenwood ck405 oven
Kenwood Oven not heating? How to replace a Kenwood fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 13, 2010 | Ovens
Electric main oven fan blows out only cold air
For all Free appliance repair videos visit our VIDEOTUTORIALS Nefffan oven element video1, If the fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Dec 07, 2009 | Neff Ovens
Door does not seal, hinge looks fractured. the door looks like it has dropped and does not seal at the top, also when lowing the door there is no resistance and it wants to just flop down. Both hinges look...
good luck!
Oct 04, 2009 | Ovens
Convection oven blowing cold air
If your fan is blowing cold air, it's the air inside the oven that circulates. It has nothing to do with the fan. Convection circulates the existing air in the oven. Sounds like you might deselect the convection setting if this continues to happen. We have parts, so please let us know if we can help any further. :>)
Aug 24, 2009 | Ovens
Electronic touch panel unresponsive. Clock blinks, but no other commands produce any activity. Model#:JMW8330DAS Serial #:13679516JN Jenn-Air oven. About 2 years old.
Unplug and let sit for 5 min. Replug and set clock time first. Then see if the other buttons work. Electronics sometime need to reboot if it freezes like your computer does sometimes.
Apr 29, 2009 | Jenn-Air JMW8330DAS Stainless Steel...
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
Smeg oven
Jan 24, 2008 | Ovens
Ovens Logo
118 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
