Question about Brother MFC 7420 All-In-One Laser Printer
The printer is set on TAD and will not allow me to opperate.
The printer is set on TAD and will not allow me to print/fax/copy/or scan anything. What do I have to do to get it back to its correct setting?
Soulvisitor
  • 1113 Answers
SOURCE: Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Posted on Oct 27, 2007
  • 121 Answers
SOURCE: wont print anything
Move the ink cartridge carriage (the printhead) to the middle of the printer like you're going to change cartridges.  Take out all the ink cartridges.  There should be two black springs on either side of the printhead.  Remove these and the printhead should pop out.  Clean the nozzels (the little parts that squirt out ink) and reassemble.
If this doesn't work, then you'll have to replace the printhead.
Posted on Oct 28, 2007
leroyal
  • 2120 Answers
SOURCE: Black line while scanning and copying
Open up the document feeder and clean the scanner glass
Posted on Jan 25, 2009
komguy
  • 2306 Answers
SOURCE: fax only mode and will not make copies
Press the mode switch until fax only goes off.
Posted on Jul 20, 2009
qwertyisone
  • 6 Answers
SOURCE: Bold black lines across the paper when printing,scan or copy not on faxing
I realise this is probably too late for you Janet and you will have bought a new drum unit by now or replaced the printer! The three lines appeared on my print-out from a new drum I installed and after investigation it transpired that there was some toner residue that had dried on the drum (from testing at manufacture stage probably) and reprinted three bold lines on a sheet of A4. The solution is to use a soft piece of cloth and rub the lines off the drum through the gap at the front of the drum unit. The drum can be rotated by turning the gear cog on the side, then once the reside has been removed from the drum and it is clean, the lines will have disappeared. I wouldn't use any solution on the drum, just gentle rubbing should suffice.
Posted on Aug 19, 2010
Printer will not print black copies
When you choose print & pick your printer you can then press the option of properties. That will allow you to chnage to black only for printing
Jul 15, 2014 | HP Officejet 4620 e-All-in-One Printer,...
How should i set my printer
Copy & fax not working?
Does it print & scan?
Mar 20, 2014 | HP Officejet 4500 Wireless All-in-One...
When receiving fax, it won't print
make sure the property settings for the fax are not on the Microsoft printer make sure it is set to the local usb printer
Jan 28, 2014 | Brother MFC-J625DW Wireless All-in-One...
My fax machine says enternal tad.
TAD stands for telephone answering device. you have to change mode to either fax or phone/fax.
Auto answer is also another option on some faxes
Jun 22, 2009 | Brother FAX-575 Plain Paper Thermal
Can't manually make copies or manually fax.
hi i need 4110 scan 7copy &printer
sofeware driver pl arrange me
Mar 05, 2008 | HP Officejet 4110 All-In-One InkJet...
Brother MFC8840D only 4 rings before fax pickup?
The TAD (TELPHONE ANSWERING DEVICE) must answer within four rings (the recommended setting is two rings). The MFC cannot hear CNG tones until the TAD has answered the call, and with four rings there are only 8 to 10 seconds of CNG tones left for the fax ?handshake?. message. do not recommend using the toll saver feature on your external answering machine if it exceeds five rings.
Sep 15, 2007 | Lexmark X8350 Print, Scan, Copy and Fax...
Samsung 3160fn
This is a multifunctional unit: it copies, prints, faxes and scans. There are three green buttons listed as "FAX", "COPY" and "SCAN". You need to press COPY if you want to make copies, since the default setting is FAX. The user's manual contained in the CD will show you how to change the default setting to COPY.
Sep 06, 2007 | Samsung CLX 3160fn All-In-One Printer
Brother MFC 7420 All-In-One Laser Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
