Question about Sony KP-46WT510 46" Rear Projection HDTV
Everything is green
I am assuming that one of the bulbs has gone bad but I was just checking to see if there is any other possibilities. I read another persons with a similar problem but his said he still had red, blue and yellow on the menu screen I only have green all the time and you can not make out the picture. any help would be greatly appreciated
  • cuzzinbri Dec 19, 2007
    i have a 60" sony sxrd. it is only about 18 mo. old and pretty soon
    after connecting my xbox 360, there if a heavy green tint on cable,
    dvd's and of course the xbox always seemed to have a green tint due to
    the lobby areas are all green. now what i don't understand is if it is
    the xbox that screwed it up, wouldn't the green bulb be out? by the
    way, sony support won't even talk to you if you don't have a warranty
    and i have sony everything!!!! time to change brands i think.
    President:
  • 4,402 Answers
Do any of the little red light on the front of the TV blinks
Posted on Dec 18, 2007
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
My projector has lines on the screen. new bulb didn't help
If this projector is connected by Component Video (3 or 5 wires) instead of HDMI, the most common color related problems are caused by having one of the 3 video cables (Red, Blue or Green) with a bad connector. If everyone is a green smurf the problem is with the red cable. If everyone is a red smurf the problem is the blue cable. If the green was bad you wouldn't see anything.
Another possibility is if the green is plugged into the yellow jack instead of green jack on the projector, you could see what you are describing.
If everything checks out, take the projector to a repair facility.
If you are connected by an HDMI cable, (combined with the fact you mentioned vertical lines not horizontal) then take the projector to a repair facility.
All of this assumes that you don't just have a bad Cable Box or Blu-ray player or Home Theater Receiver. (The source)
Oct 01, 2014 | Dell 1210S Projector
Light doesn't go off and microwave doesn't work
follow this steps and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 14, 2013 | Sharp R305KS Microwave Oven
Tail lights don't work on 83 cutlass supreme
I assume you checked the bulbs and they were good? It's possible that the sockets have gone bad and need replacing. The tail lights are fused through the instrument panel lights. that fuse should be in the middle of your fuse box, marked "instr". If the fuse is good check to see if the dash lights come on when you turn the headlight switch on. If they don't then change the headlight switch. hope this helps.
Mar 12, 2012 | 1983 Oldsmobile Cutlass Supreme
When I tried to turn my Bernina Virtuosa 150 on, a light colored smoke came out of the top left side of my machine. What happened?
When you say the 'top left side' do you mean behind the takeup arm or are you talking about the handwheel end ? I assume you replaced the bulb because it had gone out ... if so, it's possible that the power supply unit ('L'-print) has gone faulty - this is on the back of the machine, but its possible that smoke has found its way to the openings around the takeup arm and foot lifter. Best thing is to have it checked-out by a Bernina service agent.
Jan 04, 2012 | Bernina Virtuosa 150
Rear running lights on 99 cherokee
possibility of a bad ground or a corroded wire
Apr 28, 2009 | 1996 Jeep Cherokee Country
Green screen projection
This is the exact same issue as I described for an Epson user. So I'll repeat it here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the green color has gone out. The image is made up of red, green and blue images layered upon the screen. If the green panel has gone out then there is nothing filtering out the green light in the image. This causes a nice green hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Apr 01, 2009 | Sony Office Equipment & Supplies
Lamp will not light
At first i was thinking the ballast had gone bad but after reading a few other post i think it would be best to call pannasonic..
others forums read:
ballast had gone bad. Panasonic no longer makes these ballasts so mine needed to be rebuilt at the tune of $400.00.
With the ballast in place still nothing so now they claim that they need to order a "kit" from Panasonic which basically is all the components of my tv.
Jan 28, 2008 | Panasonic PT-40LC12 40" Rear Projection...
SONY KV2565AS
There are 4 trnsistors,4 resistors, they're alike in size and value on a small board attached to the neck of the tube check them out and caps too.
Aug 21, 2006 | Sony KV-32S26 32" TV
Sony KP-46WT510 46" Rear Projection HDTV Logo
43 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
