Question about HP LaserJet 1000 Printer
What is a solution when hp laserjet printer1000 series has the problem of paper jam ?
  • fmiorim Nov 24, 2009
    windows 7 nao aceita hp laserjet1000 como fazer para atualizar esse drive
    Guru:
  • 174 Answers
The solution is to check the paper very well, whether they are well placed in the tray, then allow your printer to calibrate and warm before starting any printing job. But if it has been long that you've been using the printer without servicing, then you have to service the printer because this can cause paper jam as well.
Posted on Sep 28, 2009
    President:
  • 787 Answers
Open the cover, pull out the cartridge and take a look inside for paper cuts or something.
HP Color Laserjet CM6040f MFP
Hello Desmond,
You will find all your answers regarding paper jams on this printer at the following link:
HP Color LaserJet CM6030 and CM6040 MFP Series Jams HP Customer Support
This should help you with this issue.
Good Luck!
Rich Lilja
Aug 02, 2017 | HP Office Equipment & Supplies
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
Orange light on SIDE (not top) of HP LaserJet P2015 Series printer won't go out. Have disconnected all leads and re-booted printer and computers (2) to no avail. There are no paper jams and have
Is there any text to indicate what this light refers to?
In general, you might want to remove paper trays, and use a compressed air can to spray inside the printer, especially the paper path. Oftentimes, paper dust will impede a photo-optic sensor, and keep an indicator light lit when there i no real reason for it. It can also give you a paper jam indication when there is none.
So blow out all paper dust to get the printer to work correctly now.
Cheers!
-a.
Apr 10, 2012 | HP LaserJet P2015dn Printer
13.20.00 jam insibe rear bin
Error 13.20.00 means that there is a paper jam at the back side of the printer, which can be cleared by opening the rear cover.
Click here for detailed instructions and diagrams for clearing paper jams in HP LaserJet P3005 Series Printer.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 08, 2010 | HP LaserJet P3005d Printer
HP LaserJet 1200 Series PCL 6 PAPER JAM HOW TO RESET PRINTER
IF THE PAPER JAM IS REMOVED THE PRINTER WILL RESET BY ITSELF.CHECK TO SEE IF THE PAPER SENSOR ARM IS NOT STUCK
Oct 02, 2009 | HP LaserJet 1220 Printer
My hp laserjet 1150 series stops printing after a paper jam
you probably have a piece of paper inside printer or you have damage a paper sensor path while removing jammed paper.
Jun 22, 2009 | HP LaserJet 1150 Printer
Paper out jam in hp laserjet 1020
Please visit this below mentioned link to troubleshoot your printer problem.
HP LaserJet 1020 Series Printers - Clearing Paper Jams
Thank You
Oct 20, 2008 | HP LaserJet 1020 Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
Open Questions:
See all HP LaserJet 1000 Printer Questions
HP LaserJet 1000 Printer Logo
326 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
