Question about Proview PL913S 19" Flat Panel LCD Monitor
No power power one day, none the next. Replaced power cord still nothing. No light on front of tv indicating on or standby.
    Guru:
  • 513 Answers
If you are technically able, you could replace the power supply capacitors on the power supply circuit board in the monitor. This takes a little skill with a soldering iron and purchasing 105 degree capacitors of the right value. Do be cautious of the capacitor direction, and be careful of the 160 volt supply and the 1000v supply to the backlight. Don't void your OWN warranty.
Very cheap to do to see if the monitor can be saved.
Posted on Apr 16, 2010
My westinghouse tv does not turn on at all. It worked one day, then the next it never turned on again. It has a little orange light on in the front. What should I do?
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 17, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My Sony Trinitron TV 1999 (KV-32V42) made a strange popping sound and I lost both the sound & picture. When I turn it back on, the two red lights on the front of the TV(standby/Timer light & Stereo...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Feb 04, 2011 | Sony FD Trinitron WEGA KV-32FS100 32" TV
My TV will not pwer on, I have replaced the ac power cord and made sure the switch was in the on position that is next to where the power cable gets plugged into the tv. The blue led lite in the front is...
This is common problem with the PLTV-3250, the power supply DC filter caps go bad, 5vdc standby transistor and diode shorted out.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Jul 12, 2010 | Protron PLTV-32 Television
I just replaced the lamp on my sony wega 42WE655 tv and the lamp replacement indicator light onthe front no longer indicates that it is bad, but the standby light keeps flashing red. when i try to turn it...
If you just replaced the lamp then there's something wrong in the power circuit or you have a bad lamp. If you can I would take the back cover off and look at the board where the power cord connects and lok around it for swollen capacitors. Let me know if you find anything.
Oct 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
No powerr
If the led comes on for an instant and then faints quickly, leaving the TV with no led, no blink code, and no power at all, then the fault is usually concerning the PSU board, or the power connection. If you already replaced the cable, the next step is looking for bad solder joints on power cord connector, and then testing and eventually replacing PSU board.
Jul 07, 2009 | Televison & Video
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Vizio vx32L hdtv:tv does not power up
First: Check the power outlet. Check it with a good lamp so you know you are getting power to the set.
Secondly: Check the power cord. Wiggle it around the molded ends to make sure it is not open inside the molded portion of the plugs.
Thirdly: If you know for sure the set is getting power and still no indication at all (you should be getting some little light on the front panel; standby indication) then there may be a fuse on the back panel or just inside the back cover (you will have to remove it; after unplugging the power cord) that needs replaced.
Fourthly: After all these checks if you are getting nothing, you may have some failure inside that is very serious. Normally we do not recommend serious repairs to a set over 4 years of age. This is because the set is likely to develop some other problem soon after the repair is made; further, the repairs are getting more expensive day by day while the price of new sets is coming down dramatically. Lastly, the new sets have better picture, longer lasting circuits and better features.
Hope this is a good solution for you.
thanks for your questions.
Oct 15, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
No picture, no sound, power light steady green
Aug 25, 2008 | RCA HD52W56 52" Rear Projection HDTV
My tv wont power up
Jun 18, 2008 | Quasar SP-3235 32" TV
Proview PL913S 19" Flat Panel LCD Monitor Logo
111 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Diego Zenizo
Diego Zenizo
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
