Question about Microwave Ovens
My cookworks micro wave works fine but upon cleaning the inside i noticed on the right sideof the inside a small square ''piece of card/plastic'' has a hole/burn mark-can i obtain a replacement
  • Microwave Ovens Master
  • 8,404 Answers
Look at repairclinic.com for this part. Have your make and model of couse and describe the part as clearly as you can. They are very good at sorting things out.
a
Posted on Sep 28, 2009
Smells like smoke
See on the inside of the microwave there is a wave guide , normally a square piece of plastic/fibre material. If it damaged then you would get that smell. Also if its inverter type then take it to a repair centre.
May 03, 2014 | Magic Chef Microwave Ovens
My Galaxy over-the-range micro #80009401 has a 4"
That sheet is called the Wave Guide Cover and must be replaced. It is made of Mica and protectes the magnetron and aerial.
Feb 03, 2011 | Kenmore Microwave Ovens
The inside of my micro wave has discolored and has some rust spots right through the paint. Can I use a high gloss enamel spray paint to cover this or do I need a special kind of paint for this...
Not regular enamel paint.
The area may first have to be sanded smooth, but it should at least be cleaned and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Oct 01, 2010 | Microwave Ovens
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
I'm getting a flash inside the oven and the plastic on the inside roof has a burn mark. I removed the plastic cover over the micro wave generator and it did not spark. is the oven dying? It is a 1983 0ver...
It looks like the metal part inside the oven is exposed to the high frequency rf waves. this may sound strange but try coating the metal part with fresh paint. remember no metal inside the oven will stand the waves created inside the oven the spark u see is the waves hitting the exposed metal part inside the oven
Oct 13, 2009 | Magic Chef MCD1311ST Microwave Oven
Arcing inside and there is now a small hole on the panel side. Is this fixable?
It looks like there's lightning (arcing) inside my microwave When you see arcing inside your microwave, it's because of food or liquid left in the cavity or on the wave-guide cover:
  • If the wave guide has any burn spots, replace it and clean the unit well.
  • If the cavity has any burn spots, spot-sand it smooth and touch it up with microwave interior paint.
Note… If there are any burn holes in the cavity, don't use the unit-seek help from a qualified appliance repair technician.
Thanks for contacting Fixya
Jun 20, 2009 | Microwave Ovens
GE Microwave is arcing inside
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is the plastic ceiling.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
If your waveguide cover is burned, it will need to be replaced.
If you need more specific help, please reply back with your brand and full model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Nov 13, 2008 | GE JES1384SF Microwave Oven
I have a sharp micro wave oven. Occasionally, when some foods are cooked or heated, you can see small bursts of blue flame. What I should do ? I only use microwave safe containers.
You probably have a burnt wave guide cover. Look inside the microwave either on the side or on the top, it's a square piece of mica board, and you should see a burnt spot on it. You should be able to replace it fairly easy with the model number I can check on a replacement for you.
Jul 09, 2008 | Sharp R-220HW Microwave Oven
PAINT IN MICRO WAVE OVEN
It will have to be sanded smooth and clean and dried thoroughly.
Then you can apply high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
prototech@usa.net
Apr 21, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Waveguide cover for Kenmore microwave
Try replacing the screws with larger ones. Maybe you ordered the wrong piece, if your microwave comes with a mica cover (A fine, square piece of mica) and you received a plastic one, you will need to get the right piece or adapt the one you received.
You can get the mica cover on any microwave service.
Feb 16, 2008 | Microwave Ovens
Microwave Ovens Logo
97 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
