Question about Welding Tools
MY CEBORA S21 MIG 190L KEEPS BLOWING FUSE,I HAVE REPLACED TORCH AND LEAD ETC CAN YOU HELP
    Problem Solver:
  • 18 Answers
Does it blow when the trigger is pressed or as soon as the mains power is applied??? If it blows when first turned on it could be the cooling fan or the main transformer or auxillary transformer if it has one. If it blows when triggered it could be the pcb or the wire feed motor ,diode bank or main transformer .
Posted on Oct 07, 2009
Cebora mini mig on trigger no wire feed ,power on?
Cebora mini mig on trigger no wire feed ,power on? - Fixya
www.fixya.com/.../t25810314-cebora_mini_mig_trigger_no_wire_feed
3 hours ago - Question about MIG Welders ... Weld corp mig 100 turn machine on andwire keeps feeding without ... Welder running but wont feed wire etc.
Aug 05, 2015 | Welding Tools
After owners manual for a Cebora Revolution Combi mig welder
try here: http://www.cebora.com/download_uk.html#manuali_di_istruzioni
Mar 22, 2015 | Microwave Ovens
216 mig no feed no fire maybe selonoid problem please help seloniod does not click
It could be just the simple problem of the trigger not working. Disconnect the trigger wires from the machine at the plug at the front of the machine. See if you can manually trigger the machine by placing a piece of bent over mig wire onto the contacts. If the machine does trigger from this then your fault is in the torch somewhere. It could be the trigger (which commonly does fault from a dusty environment) which is easily replaced by going into any welding store with the torch model number (magnum 250L), or it could possibly be that a trigger wire has broken from the torch being damaged
May 29, 2011 | Lincoln Electric Lincoln Power MIG 216...
I have a problem with a jerking motion while Im trying to weld. the wire feeds out good without the tip on. I replace the tip but I havent replaced the cup but Im using flux core wire also. What could be...
I have found that keeping the gun lead as straight as possible fixes this problem. Also it is sometimes recommended to use one tip size bigger when welding with flux core wire. My last spool was radnor flux core wire .030, and a .035 tip keeping the lead as straight as possible and it welded extremely well. If that doesn't solve it you should take everything apart and clean it / blow it out with compressed air.
Oct 27, 2010 | Hobart Handler 140 Mig Welder
Can you find a manual for a Cebora or Snap-on 130 MIG Welder
Contact Cebora or snap-on, simplessssssssssssssss
Sep 30, 2009 | Welding Tools
I need to know if you can replace a clarke lead with a tweco or some other brand and make it work. If not then if anyone knows where I can get replacment parts for a 130EN that would help. Since Clarke...
There are many different welding leads available. Usually leads in machines like the Clarke are generic Italian made. Check with www.weldingdirect.com they have a buch of different leads. The part you need to be concerned with is insode the welder, where it connects to the machine. If you have other questions email me at stevestoolrepair@yahoo.com
www.stevestoolrepair.vpweb.com
May 06, 2009 | Clarke Power Products Clarke 130EN Mig 110...
Kawasai z750, keeps blowing main fuse
To my knowledge, there are no onboard electrical/electronic components capable of shorting and blowing the fuse with out blowing any of the secondary fuse. The main fuse could possibly blow due to a short in the wiring or an exposed/frayed wire touching the body. The three most likely areas would be:
  • wire harness leading to the regulator;
  • wire harness leading to the fusebox; and/or
  • wire harness leading to the ignition switch.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 19, 2008 | 2005 kawasaki EL 125 Eliminator
Welding Tools Logo
344 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
