Question about Refrigerators
Control Board Programming Code
Amana AFB2534DES- freezer is cold, fresh food section not working. Appliance repair guy says the Electronic Temp Assure unit control board needs to be replaced. Two days to order and receive the part. Calls back next day and claims supplier doesn't have in stock and part is backordered for two weeks. I call Amana direct and they tell me part #67006740 is in stock. I order part directly from Amana Next Day Air, part arrives with no receipt or instructions. Call Amana for instructions and they tell me the part does not come with instructions and only an authorized technician has the code. The part is installed but I'm stuck because I don't have the code.
  • 2 more comments
  • davelk Dec 19, 2007
    Found the plastic bag, thank you.
    The old board was JAZZ11, new board is JAZZ14. The code on the label inside the fridge is 12. Would there be a change in the code because of the different board?
    The fridge has been off for a couple of days, is there something that has to be done after the code is programmed into the unit to start it back up?
    -davelk
  • davelk Dec 20, 2007
    Installed the new board, programmed the code, started her up and....... same problem- cold freezer, warm upper section.
    Help!
    no cold air in the refridg- damper is open. A very thin layer of frost on the back wall.
    Service Test 1- Defrost Thermostat & Defrost Circuit Test
    Result- Defrost Thermostat Shorted (Closed)
    Service Test 2- Compressor/Condenser Fan- On
    Service Test 3- Evaporator/Freezer Fan- I hear it go off and on.No direct observation.
    Service Test 4- Fresh Food Thermistor- Pass
    Service Test 5- Freezer Thermistor Test- Pass
    Service Test 6- Open Damper Test- Damper Open
    -davelk
    One last thing- what is the significance of  Service Test 1- Defrost Thermostat & Defrost Circuit Test Result- Defrost Thermostat Shorted (Closed)
    -Dave
  • 410 Answers
The code is most likely printed on your model number label located inside the refrig compartment and entering the code instructions are on your tech sheet that is taped to the underside of your refrig.
remove the toe grille and feel under the cabinet for a plastic bag/envelope taped to it. just follow the instr for entering the code..
ps if the code isnt on the model label it may be on the tech sheet..
Posted on Dec 19, 2007
  • 3 more comments
  • peyton thompson
    peyton thompson Dec 19, 2007
    the only way the code would change is if they put a new code in with the new jazz board. once you get the board programmed its ready to go.
  • peyton thompson
    peyton thompson Dec 20, 2007
    ok lets start from beginning!
    is the fan in the freezer section blowing? if not most likely its a bad fan motor.
    so the motor works, lets see if you are getting cold air in the refrig section. in the top of the refrig section in the center is a vent. fell for cold air. the damper that is located behind this vent cover could be bad just remove the vent cover and see if the damper door is closed or open. the cover just pulls off with a little force.
    fan is working and damper is open. leaves only 1 thing i can think of. that would be something wrong in defrost system. look for frost build up on the back wall of freezer compartment. if there is frost just follow the instructions on the tech sheet for forcing a def cycle. if the heater comes on then you have a bad jazz board (which shouldnt be now that youve changed it out). no heater then most likely you have a bad def thermostat.
    I know thats a lot of stuff to check but if you can replace a jazz board then this is easy stuff.
    good luck and let me know how it works out for you
  • peyton thompson
    WOW! You checked everything! Without actually looking aat it at this point i'm not sure what to tell you to do next. My advice at this point is to call a good service comapny..
    sorry,
    Peyton
  • peyton thompson
    Dave, One other thing you might do since all systems are working. unload the refrig and freezer and let it defrost for 4-5 hours and then restart the unit. this would eliminate the possibility of a frozen cooling coil.
    Again I'm sorry I cant help you more.
    Peyton
  • peyton thompson
    that test determines if the defrost system is ok.
How To enter programing mode The W10312695 Control Board
Open the fresh food door and hold the fresh food light switch closed while pressing the freezer temperature down key three times in a row. This must be done within 10 seconds.
Release the door switch.
The control will display PE to confirm entry into programming mode.
You need to confirm entry into programming mode by pressing the freezer down key once more.
The control should display zero on both led's.
Set the control to the correct code as shown on the model and serial number sticker in the fresh food section.
This is done by pressing the fresh food up and freezer up buttons until the correct code is displayed.
Once the desired program code is displayed, press the freezer down key until the program code begins flashing.
Once the programming code has been saved the programming mode can be exited by closing the fresh food door.
Sep 11, 2014 | Whirlpool Refrigerators
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
Side-by-Side: Refrigerator will not maintain temp below 50 Deg. Freezer works fine - where is the problem? Model Number MSD2757AE
Your problem may be with:
* the "damper control assembly", which is located in the upper left side of the fresh food compartment. This control regulates the amount of cold air originating from the freezer compartment that enters the fresh food compartment.
* there may be an issue with the "fresh food temperature control assembly"
Check the temperature settings in the fresh food compartment (should be located up front). I recommend the "one-half way mark" for both freezer and fresh food compartments.
Contact an appliance service company.
Feb 19, 2010 | Refrigerators
Freezer and fresh food section are both at room temperature.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Sep 09, 2009 | Refrigerators
My side by side freezer is working fridge wont get cold,compressor is working.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require a service technician to check and repair these components.
Hope this was helpful. Good Luck.
Aug 29, 2009 | Frigidaire FRS26R4A Side by Side...
Bottom of fridge not cooling
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Aug 29, 2009 | Estate Model: TT16DKXSQ Top Freezer...
Maytag bottom freezer Model MBF2254HEB not blowing cold air into freezer or fridge, blows warm air if blowing at all, starts and stops. Any suggestions? Possibly a reset button somewhere? Thanks - Kurt
Aug 29, 2009 | Refrigerators
Fridg is not working right
Aug 28, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Working fridge, warm freezer.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Aug 28, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Fridge doesnt stay cold
Aug 28, 2009 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
603 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
