Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The light stays on for a long time although it shuts off (a lot more that 4.5 minutes). Can this be adjusted to be shortened? Where and how on the unit?
    President:
  • 3,197 Answers
If you have one of the newer models the duration can be changed by holding in the lock button until the light blinks (about 10 seconds.) A single blink indicates that the timer is reset to 1½ minutes. Repeat the procedure and the light will blink twice, resetting the timer to 2½ minutes. Repeat again for a 3½ minute interval, etc. up to a maximum of four blinks and 4½ minutes.
If your opener has the motion sensor feature and a person enters the garage and walks in front of the door control the light will come on for 5 minutes and then shut off.
Posted on Sep 28, 2009
Headlights stay on too long after motor shut off
The adjustment dial should be on the rear view mirror.
Jul 29, 2015 | 1998 Ford Explorer
I have the cooper K6107v-l motion sensor. Is there a way to adjust the time delay? The device shuts off after about 3 seconds, I want it to stay on for 5 minutes.
under the cover,of the device ,pry with a small screwdriver ,there is 3 controls side to side is the outer or wdth of range then in the center is time ,turn it clockwise you can adjust it up to 20 minutes
Jun 10, 2011 | Cooper Wiring Devices Motion Sensing...
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
D52W20BYX1 Green problem
I would go back to green tube disconnect ,unplug CRT board to green tube if set stays up playing its the tube.
Sep 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RICOH FT 7650 shuts itself off when not in use after 45 minutes
Enter in the user mode:
1.Press the Clear mode key.
2. Press the Clear/Stop key more 4 sec untill the user tool menu appears on the touch panel.
3.This copiers has more 12 user tools.You can see 5 user tools on the display at the same time.Use these keys to see the rest .
4.AUTO RESET: the copier return to the initial condition autommatically after your job is finished.(after 60 sec)
5.SCREEN SAVER :when the copier does not detect anyone operating it for selected time the display turns OFF.(60 sec).
6AUTO OFF:Whwn the machine is used after weekly timer has turned it OFF the copier will turn itself back OFF after the selected time.The auto OFF time can be set from 1 to 999 minute or the function can be turned.(I recomanded setting level OFF).
Aug 31, 2009 | Ricoh Aficio 450 Copier
2005 Lincoln Aviator
On my 2004 Aviator, the indicator was lit all the time, and it did kill the battery if I didn't drive it every day. The dealer stated it should only remain lit for 20 minutes, and replaced the shift assembly. Sounds like they shortened the illumination time to 10 minutes.
Mar 10, 2009 | 2005 Lincoln Aviator
06 Ram interior lights shut off quickly
I maybe wrong, but there should be a proceedure in the owners manual to adjust the interior light timing. If this proceedure is unsuccessful check your dealer for more info.
Dec 05, 2008 | 2002 Dodge Ram Maxi
How to adjust brakes on mongoose overide bike
You may need to shorten the brake cable by loosening the thumbscrew locknut, extending the adjuster and re-tightening the locknut. If there isn't enough adjustment, you'll have to shorten the cable by loosening its locknut, shorten the cable by about 1/4" at a time, and re-adjusting your thumbscrew adjustments until the brakes are effective. Also make sure your new shoes are lined up with the sides of the wheels and you may want to lightly sand the surface of the new shoes, just to roughen them a bit so that they seat faster.
Hope this will FixYa!!!
Jun 01, 2008 | Computers & Internet
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,954 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
