Question about Quinny Buzz Jogger
I need two side wheels and one front wheel assembly for the quinny buzz pushchair
  • 20 Answers
For what you want ebay is the best and cheapest place or if you want barnd new check with dorel.co.uk the only quinny importers and spares stockist in the uk hope this helps x
Posted on Dec 30, 2009
Quinny buzz pushchair.
Yes you can, you need to get in touch with Dorel UK 01842 763 281 (Mon – Fri, 8:30 am to 4:30 pm) They supply all the spare parts and servicing for the Quinny range.
Jun 19, 2010 | Quinny Buzz Three Wheel Stroller
How do i fit the footmuff on my quinny buzz pram?
Hi, to fit the footmuff, you need to undo the straps which can be done right at the top shoulder bit. Once this done you then thread the harness through the side holes on each side of the footmuff, then through the top hole & re-attatch harness to pushchair. All that is left to do it push the **** strap though the bottom of the footmuff. Hope this is of help to you. Regards Marie
Apr 27, 2010 | Quinny Buzz Three Wheel Stroller
How to open and close quinny buzz pushchairs
If you lock the front wheel and lower the handle bar to the lowest postition first, this will make the chassis as small as it can be. Remove the seat/car seat or carry cot if this is on the chassis.
Then, stand in front of the chassis, with the front wheel between your legs.
Push down the grey rectangle button on the left hand side, then pull toward you the right hand rectangular button then push this button downwards,
Then, withnthe two buttons still pushed in, with your full body weight, push the chassis downwards the floor until fully folded.
I hope this helps.
Feb 18, 2010 | Quinny Buzz Three Wheel Stroller
Problem with the front wheel Quinny buzz 3
This does sound like you have got a build up of dirt within the wheel assembly unit. I would suggest that you remove the entire wheel (push the two black buttons either side of the axle and pull) then clean the entire wheel in warm water. Lubricate the moving parts with a thick lubricant (something like vaseline, not DW40 as this attracts dust) then pop it back on, that should sort it out.
If the wheel is still not working, then contact your retailier if still within warranty (two years chassis and one year fabrics). If this is out of warranty, contact www.quinny.com who will be able to sell you a replacement wheel assembly.
I hope this helps.
Oct 10, 2009 | Quinny BUZZ 3 Capri Stroller
I have lost one off my quinny buzz 3 pop on back WHEEL
Found this on the last page of user manual
Front wheel assembly
Rear wheels
Rainshield
Bug net
Shopping basket
Car seat adapters
• XL Seat Pad
To order parts call (800) 951-4113.
Include the model number and manufacture date (found on the bottom rail of stroller) and a brief description of the part.
Aug 20, 2009 | Baby Gear
I need front replacement wheels for quinny buzz 3 wagtail design pushchair
If you are in the UK, the following website is much cheaper than the others listed...
https://www.lesters-nurseryworld.co.uk
Jun 22, 2009 | Quinny Buzz Jogger
Main frame and worn wheels of the quinny buzz
This happened to my wife the other day, I found that the main pivot bolt had pulled through the plastic pivot/collapse assembly. This part is rivoted to the frame so without drilling it out and replacing with an ugly nut and bolt you will have to source a new frame. I got mine from Ebay, I found someone selling lots of quinny buzz bits and asked if he still has the frame he said yes but the handle bar no longer extends (Hence im on here looking how to swap the two), Problem solved!
I also found out from Quinny that the Buzz has a 2 year manufacturers warranty, where Motercare insisted it was 1 year, so dont let them fob you off.
Hope this helps
Chris.
May 18, 2009 | Quinny Buzz Jogger
My quinny buzz front wheel keeps getting stuck half way and i end up trying to push the chair with the front wheel sideways which is impossible. i have been advised to clean the front wheel out as it gets...
First remove the front wheel assembly from the pushchair by pressing in the two buttons on the sides and pulling it out.
Now look more closely at the assembly - on one side, just where it bends at an angle you will find a small hole, a couple of millimetres across. Take a small screwdriver or some other thin object and push it into the hole a little way, which presses a metal catch inwards, releasing the swivel assembly. While continuing to push this in pull the swivel assembly apart - grasp the wheels in one hand and the L-shaped plastic housing in the other and pull them apart.
Now clean all the surfaces with a piece of strong cloth.
When all the surfaces are very clean, take a can of TEFLON SPRAY and spray it onto all surfaces that rub against each other, before reassembling the wheel unit. Silicon grease is a cheaper alternative, but the teflon spray is supposed to be the best for lubricating all moving parts on the Buzz. Whatever you do, don't use WD40.
Hope this helps! Dan.
Nov 11, 2008 | Quinny Buzz Jogger
Attaching the basket underneath the pushchair
try removing the front wheel by pressing the two black dots either side of the tubular frame and sliding the wheel out. then slide the metal end of the basket up the groove under the front tubing.the two velcro straps fasten to each end of the back axle. (the basket should have the quinny symbol on the underside)
Hi I got a nearly new frame off ebay for a bargain! There are loads of spare parts to be had on there.
Aug 03, 2008 | Quinny Buzz 3 Sulphur Jogger
Quinny Buzz Jogger Logo
160 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
