Question about Samsung LN-T4053H 40 in. LCD Television
The tv will not turn on
The tv will attempt to power on but then shuts itself off immediately and will repeat the process several times before finally turning on. This morning, it never got enough power to actually turn on and kept doing this repeatedly.
  • 11,361 Answers
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 14, 2009
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Samsung LE Televison & Video
My Samsung TV HLS4288W shuts off by itself. When I turn it on it repeats with the same, shuts off. I have to repeat this process several times before the TV finally stays on.
There's a loose connection in the power supply of your television.Try to fix this problem.If you want to do the repair,just open the back cover of your TV and look the power supply.Try to resolder the board of the power supply and check the connector to power supply from the board supply.You can power on the televisions while the back cover is open to see that the power supply is working. Thanks!!
Aug 21, 2011 | Samsung Televison & Video
I have a 50inch LG Plasma which is around 3-4 years old and no longer under warranty. When first switching on it immediately switches itself back into standby mode making a loud click whilst doing soon....
You need to remove the back and check the power supply board for bulged electrolytic caps that will need to be replace, or just replace the power supply board.
Nov 29, 2010 | LG Televison & Video
Stupid tv!
Sounds power supply board is bad in your TV and most probably replacement of all electrolytic capacitors in power supply board will solve the issue.
Take TV to local TV repair shop for repair.
Thanks.
Aug 30, 2009 | Akai LCT3201TD 32 in. LCD Television
Multiple attempts to Turn on the TV
It's common for capacitors on the power supply board to go bad (tops will swell up) and cause the same problem. these new LCD tv's are all very bad when it comes to power surges.
Jul 21, 2009 | Akai LCT3201TD 32 in. LCD Television
Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 04, 2009 | Philips Magnavox 27MS343S 27" TV
Samsung TV will turn on and off several times, then stay on.
First, need to check the power bar(if you use).
then. if don't use power bar, need to check the power board.
Dec 12, 2008 | Samsung HL-R7178W 71" HDTV
Magnavox # 37MF231D
that depends on the value of the television and the cost of replacing the power supply and connections.
Most likely you have a short in your power supply or other connections causing the tv to protect itself by shutting down. You can check with our Repair Service lookup icon for a repair service near you.
Before you call them you may try unplugging your unit for 30 minutes or so and plugging it back in.
Jun 26, 2008 | Philips Magnavox 27MS343S 27" TV
T.v. ejecting vcr tape and turning self off after being turned on
If VCR mechanism doesn't load or unload properly, TV will shut off. VCR machnisam in your TV requires cleaning/ service. Spacialy belts and pulleys.
Jun 22, 2008 | Philips Magnavox DVD/VCR Dual Player
Samsung LN-T4053H 40 in. LCD Television Logo
290 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
