Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
I don't know my receiver code, i've tried putting in 1234 and 0000 but the it just keeps coming up with bad code please try again
    Brigadier General:
  • 3,006 Answers
Your question is listed under Sagem PVR6280 so I'll assume that's what you have. What follows also applies to the 6240, 6200 and 6200t.
There is another default code of 1111, if this does not work then there is a jumper switch inside the box on the main circuit board which will clear whatever code has been previously set back to the default code.
Open the box at your own risk and ensure that you physically disconnect the box from the mains and use an anti-static mat or an anti-static wrist strap. From memory, I think that when the jumper has been altered the box needs to be briefly re-powered and then turned off to allow the jumper to be reset back as it was.
If your box is a Sagem 6240/6260 then DO NOT update it yet as these models are known to be incompatible with the update and will lose some functionality afterwards. The official advice is to contact Sagem directly on 0845 0900 316 to see if they have a fix yet, but the number is clearly going to be ridiculously busy this week at least as thousands of their boxes are affected.
Cut and paste the web address below into your browser for the official line:-
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
I hope that you have found my answer to be useful and ask in return only that you take a moment to rate my answer.
Posted on Oct 02, 2009
I've forgotten my password, and keep trying but they tell me that I am to put another one in but I don't know what to use?
please try this:
Apr 29, 2013 | Facebook Social Network
VK530 Mobile phone - Vodaphone
HI,
First try these codes.
1234,0000
Sep 04, 2008 | Cell Phones
My 2007 Honda civic just had its battery replaced...So I've been trying to get my radio (and clock) to work again. The previous owner recorded a 5 digit code in the owner's manual. I've tried...
sometimes the code is put on the bottom of the ashtray just remove it and flip it upsidedown should be 4 or 5 digit number somewhere on it
Dec 09, 2012 | Cars & Trucks
Hello, I ve forgotten my nokia 6680's code and I don t know how to access to my phone... I have the master code but I don't know use it Can you help me please?
are you going to change your lock or security code?if you wish to changer it,or are you trying to put a security on your phone.(* the default code is 12345)
just go to settings > security > lock code and enter your code (there's an option if you wish to change or edit your code.
good luck...
Jun 11, 2011 | Nokia 6680 Cellular Phone
My bobbin keeps bunching up. I've changed the tension to 2, taken the bobbin case out, used a different bobbin....I don't know what to do. My machine is a month old and I've used it, maybe 4...
Put the tension back up to about 5. Rethread the machine entirely, and make sure you have the pressure foot in the up position when you rethread. If your getting bunching on the bottom, it's probably your top thread that's bunching up. After you rethread, put a small piece of fabric under the pressure foot, lower the pressure foot, and turn the handwheel in the forward direction and watch the thread as it comes around the bobbin case. If it goes around smoothly, try it with the foot control. If it hangs up as it goes around the bobbin case, you might have a burr on the black plastic bobbin case. Take it out, check for any burrs, sand them down, and try again.
May 07, 2011 | Brother SE350 Mechanical Sewing Machine
HI .I HAVE A LEXMARK PRINTER NO; P315, PUT IN A REFILL CARTRIDGE , BUT IT KEEPS COMEING UP WITH CARTRIDGE ERROR. I KEEP TAKEING IT OUT ,AND PUT IT BACK, BUT KNOW JOY , PLEASE CAN YOU HELP .
the issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again. But if you tried that and it doesn't work just call up their support number and check for replacement.
Jan 24, 2011 | Lexmark P315 InkJet Photo Printer
When i am going to on my mob set it requires security code
your mobile is unlocked to some network and you are trying to use sim of other network so its asking code.
try common codes like 1111, 1234,0000 if they work, or you need to get it unlocked from mobile technician.
Must rate me as fixya
Mar 25, 2009 | Nokia 1110 Cellular Phone
Tv /dvd sony need codes
try 100
try 300, 301,302, & 303. vcr
try 751 for the DVD player
try 801 for the Satellite receiver
Sep 03, 2008 | Sony KV-24FV12 24" TV
1934 installation problem
I have no magic solutions for this problem, and I?m guessing you?ve already tried what I?m going to suggest, but if not maybe you should try that: 1. are you using a laptop? The card you?re using might be a Cardbus, which usually isn?t supported by laptops because of BIOS settings. 2. It might also be a driver problem. Disconnect the card, remove it, remove the drivers. Restart the computer and reinstall the drivers. Turn the computer off. Reconnect the card and only then turn the computer on again. Wait a few minutes (sometimes it takes a few minutes for the computer to recognize new software). I don?t know if it would work, but it?s worth giving a shot.
Feb 22, 2006 | Artronix Technology Firewire 1394B...
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
221 people viewed this question
Top Sagem Televison & Video Experts
electracon
ka4iup
ka4iup
 Mikey
Mikey
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
