Question about HP DESIGNJET 500 InkJet Plotter Printer
Why want my hp 500 plus plotter turn on, no power to it what so ever
    President:
  • 787 Answers
First check the power cable and change the plug. If don't help you have a problem in power supply module in your plotter.
Posted on Sep 28, 2009
Designjet 500 plus 42" issues
System error 56:10 Explanation
Drive roller encoder sensor error.
Recommended action
Turn the printer off and allow a few minutes for printer to cool. Turn the printer on and attempt to verify functionality.
If the problem persists, click on Support at the top of the page for additional HP support and contact options.
top
System error 56:13 Explanation
An error in the drive roller encoder sensor quadrature has occurred.
Recommended action
top
Jul 27, 2015 | Office Equipment & Supplies
I am still having a problem with HP designjet 500 Plus showing error 86:01 then writing so:Severe error: 0 x 8010003 task: tMech file: sequence.c line: 636
sounds like the printer is broken pretty badly. Is it still in warranty? Contact HP for a replacement, or else it's time to buy a new one.
Nov 11, 2014 | HP DESIGNJET 500 InkJet Plotter Printer
I need solution on this Problem, HP DesignJet 500 Plus Error: Severe Error: 0x8010003, Thanks Biar R
Turn off the power ->open the cover and manually move the Cartridge carrier to the middle of slider bar that's all , it will fix your problem. Most of the time it is due to friction in the slider rod so lubricate the slider rod if necessary. If the carriage is stuck at the right hand side of the printer and cannot be moved out to the center of the print platen it is because the service station cannot uncap the print heads. in this case replace the service station/aerosol fan assembly.
Feb 13, 2013 | HP DESIGNJET 500 InkJet Plotter Printer
My hp designjet 500 doesn't recognize the I/O Card
By I/O card I assume you are referring to your JetDirect or the optional HP/GL2 formatter board, your EIO devices?
If you have them installed and the plotter does not recognize them.
Shut down the plotter then remove the power cord from the plotter or the wall and wait 5 mins.
Remove ALL EIO devices (JetDirect / formatter).
Plug the plotter back in and restart the plotter.
Test functions of the plotter.
Shut down the plotter and then add back only the JetDirect.
Start the plotter and check the function, and check if the menu will allow you to setup the JetDirect.
If successful, shutdown again and reinstall the Formatter Card (if you use one).
Test functions and check the I/O setup in the menu.
The idea in a nutshell, remove the cards and add them back one at a time to see which one if any is bad and causing the I/O to shut off.
If this does not help, you may need to replace the plotters Electronics module
Aug 16, 2012 | HP DesignJet 500 InkJet Printer
HP DESINJET 500 PLUS THE ERROR MESSAGE IS 01 : 12
System Error: 01:12
Problem Description:
The EEROM is not configured correctly (the product number may be missing).
Corrective Action: Configure the EEROM correctly using the EEROM setup utility
Aug 30, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
86:01 error in designjet 500 plus Paper jam...
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
Corrective Action:
If this error code appeared but was NOT caused by a paper jam, then try the following:
  • Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
  • The Carriage is bumping into the Service Station. If the carriage is stuck at the right hand side of the Printer and cannot be moved out to the center of the Print Platen it is because the Service Station cannot uncap the Printheads. In this case replace the Service Station/Aerosol Fan Assembly
  • Perform the Carriage Movement test
Aug 26, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
Hp designjet 500 plus 24"
HEYA
This error indicates that there is a problem in the Service Station Assembly (SVS). Either you have a paper left-over after a paper jam thats blocking the movement of the mechanism of the SVS or sometimes ink mounds around the Station if yes try cleaning it, or it could be a transient error that entails to turn the plotter off for a while and then turn it back on. If problem reappears and you are familiar in this plotter disassembly, check manually while the plotter is OFF the motion of the SVS gears; you can figure out the smooth movement.
In worst cases if problem persists i have to tell you that replacement of the SVS might solve your problem.
Hope this fixes your problem if not please reply
LONG LIVE THE GEEKS!!
Dec 08, 2010 | Computers & Internet
Why my HP designject 500 PLU can't turn on, no power after lunch, before lunch is ok.
This sounds like a heat related problem. Try running the plotter with the back cover removed. Also, try turning the plotter off before lunch and back on after lunch to see if it works ok. If it does, you may be looking at a power supply replacement.
Oct 06, 2009 | HP DESIGNJET 500 InkJet Plotter Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
HP DESIGNJET 500 InkJet Plotter Printer Logo
268 people viewed this question
Seeker5211
Seeker5211
