Question about HP OfficeJet 6110 All-In-One InkJet Printer
Nois from the scannermecanism under initalizing
Under initialization the scanner head is moving ok until it reached the right end, the scanner-head is mechanically stopped but the step-motor is running very noisy until I unplug the power cord from the unit.
maybe it is malfunction of the stop sensor, how can I check it?
    President:
  • 787 Answers
The problem is not in stop sensor.It's in scanner section.The scanner is not initialization couse inside in section has a to much ash on mirrors and the scanner lamp.Replace the scanner section or clean up it.
Posted on Sep 28, 2009
Init unable 50
Solution 1:
  • Lift the scanner cover using the plastic tabs, located on the left and right side of the machine until it locks securely into the open position.
  • Slide the print head to the middle.
  • Check for any pieces of paper or staple , paper clip...
Solution 2:
  • Slide the print head over to the right side under the cover to make sure you clean the entire encoder strip.
  • With the lint free cloth, firmly grab the encoder strip on both sides and rub the cloth down the strip from one end to the other (left to right then right to left) at least three times.
Jul 13, 2016 | Office Equipment & Supplies
Hp leserjet printer error.
Service-mode functions NVRAM initialization
An NVRAM initialization will return the following device settings to the factory-set defaults:
All menu settings, including the fax header and company name
Fax numbers and names that are associated with one-touch keys and speed-dial codes
Additionally, all faxes stored in memory are cleared.
Perform an NVRAM initialization
1.
Turn off the product.
2.
Simultaneously press and hold the
the product.
3.
Wait until the message Permanent storage init. appears, and then release the
arrow buttons.
When the NVRAM initialization process has been completed, the device control panel shows the
Ready message.
Super NVRAM initialization
A Super NVRAM initialization will return all of the device settings to the factory-set defaults (generic
product mode).
NOTE:
When the product is turned on, you will be prompted to select the language and country/region
setting before the product will initialize.
1.
2.
the product.
3.
arrow buttons.
Service menu
NOTE:
An asterisk (*) symbol next to a service submenu option indicates that this is the current setting
for that option.
For more information about using the service menu, see
Access the service menu
1.
Press the
2.
Use the arrow buttons to select Main Menu Service, and then press OK.
3.
Use the arrow buttons to select the desired secondary-service option, and then press the
button.
4.
Use the arrow buttons to select the desired submenu option, and then press
ENWW
Setup
button.
Cancel
button and the right arrow button
Cancel
button and the left arrow button
Service menu on page
), and then turn on
Cancel
and right
), and then turn on
Cancel
and left
241.
OK
OK
directly from service manual
Sep 15, 2015 | HP LaserJet M1005 Printer
Solution for unable to Init.43 repair
To clear the message, you need to disconnect the Brother machine from the power outlet to check the machine. Follow the steps listed below: Check for foreign objects, such as a paper clip or scrap of paper, inside the machine. Disconnect the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely. If the error continues to appear, move the print head and examine under the print head. NOTE : The images shown below are from the representative product and may differ from your Brother machine. 2-1.Disconnect the Brother machine from the poweroutlet. 2-2.Open the scanner cover by pulling up on the lower right corner of the cover. 2-3.Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area. 2-4.Gently move the print head to the center. Caution Be careful not to force the print head to move. If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us". 2-5.Examine under the print head. If anything is found, remove it. Hint Use a flashlight if necessary to check thoroughly. 2-6.Close the cover and reconnect the machine to the power outlet. If the message continues to appear on the LCD, the machine will require repair as the print head has failed and will need to be replaced.
May 29, 2014 | Brother Sealed Mfc-j430w Wireless Printer...
Unable to init see troubleshooting and routine maintenance chapter in user's guide. Please help me!!!
1. Check for foreign objects, such as a paper clip or scrap of paper, inside the machine.
2. If the error continues to appear, move the print head and examine under the print head.
Feb 20, 2014 | Brother DCP 115C All-In-One InkJet Printer
Can,t get scanner off all channels locked mode
Please try this!!
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works.. Happy Scanning
Nov 20, 2012 | Radio Shack Pro-96 Scanner
Dell a920, problem; does nothing, powelight keeps
Hi there You can try this not realy know if work on your printer it for a dell, it worth a go. How to clear NVRAM under maintenance:
· Press Menu.
· Press down until "Configure" appears, then press right.
· Press down until "Maintenance" appears, press right.
· Press down until "Init NVRAM" appears, and press right.
· "Init NVRAM Are you sure?": press "enter" in the center.
· Follow instruction and restart the printer (turn off the printer, and then on).
How to clear NVRAM under Network
· Press "Menu".
· Press down until "Configure" appears, and press right.
· Press down until "Network" appears, and press right.
Default username = admin
Default password = password
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 03, 2010 | Dell A920 InkJet Printer
How to scan
start from top  look from left to right until reached centre of book when reached centre return to leftside tilt head down 1degree then repeat until end of page at end of page tilt head back to start position turn head to page on right side and repeat process
Apr 19, 2009 | Epson Office Equipment & Supplies
Hp officejet 7410 fax failure
Had the same problem as everyone else here - would copy fine but faxing or scanning resulted in the "whizzzzzz" sound (with or without the sheet feeder) and a mandatory reboot.
I followed the suggestion of moving the scanner head to a different part of the drive belt and it works fine now (at least until that part of the belt wears down!). Here was the procedure - it took about 10 minutes.
  1. Remove all T8 screws from the top of the scanner bed - there are two hidden on the left side under the removable flap and two more hidden behind the front control panel cover, which just snaps off.
  2. There is a bundle of wires that prevents the entire top from lifting completely off, so lift it high enough to clear the plastic parts, then rotate it 180 degrees around and set it on something to support it.
  3. Lift the scanner head until it comes off the guide rod and disengages from the drive belt.
  4. Move the scanner head to the other end of the bed and reingage it onto the belt and guide rod - this is a little tricky to get the belt to pop back into the scanner head, but I got it to go by holding the belt firmly on either side of the head and squeezing both together.
  5. Replace top and all screws, pop control panel cover back into place.
  6. Rejoice in saving yourself lots of $$ and preventing more junk from entering the landfill!
Feb 29, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Drum Full of Waste Toner
Try clearning the NVRAM most cases the drum fill count is baised on a setting and not if its really full.
  1. Press Menu.
  2. Press d_bottonb.gif until Configure appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  3. Press d_bottonb.gif until Maintenance appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  4. Press d_bottonb.gif until Init NVRAM appears, and then press r_bottona.gif or arrowbutton_sa.gif .
  5. The Init NVRAM Are you sure? message appears on the operator panel. Press arrowbutton_sa.gif .
  6. Turn off the printer, and then on again.
Nov 16, 2007 | Dell 3000cn Laser Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
162 people viewed this question
Seeker5211
Seeker5211
