Question about Maytag Washing Machines
I have a Maytag MAH7550AGW can you tell me how to access the motor control board in order to change the 10 amp fuse?
  • Maytag Master
  • 19,396 Answers
You have to remove the back lower cover to access motor. Motor control board is near to the motor. See diagram below:
Here all diagrams and parts for your appliance.
Posted on Sep 28, 2009
What is the wiring and winding?
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak Maytag Neptune washer motor/motor control circuit board ...much this is very helpful, my machine is coming up with a "Lr"code which I believe .
Aug 20, 2015 | Maytag Neptune Washing Machines
I know fuse is gone on Maytag MAH7550AGW but how do I access the motor control board? Which screws do I need to remove etc?
8 screws inside lip of dryer door including door hinge screws the hold front panel will come off the control board will be bottom right front.
Sep 28, 2009 | Maytag Neptune MAH7500A Front Load Washer
My Maytag Neptune washing machine won't spin in the spin cycle
it may be the carbon brushes on the motor worn down, may need to replace, ideally the black carbon brush needs to more than 10mm if less the brush are struggling to have contact with the armature of the motor
Apr 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Machine will start and then stop
It sounds like the motor control board is shot. Inspect the MCB for burnt components or a blown 10 amp fuse. This board is located down by the floor on the right side. See www.neptunehelp.com for disassembly pictures.
If you have a blown 10 amp fuse or there are burnt components then the MCB will need to be replaced along with the motor as Maytag has redesigned them to be more reliable. The new part number is 12002039, which is a motor conversion kit. It takes about an hour to install.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new 12002039 motor conversion kit which includes the motor, motor control board and the wire harness.
See http://www.neptunehelp.com/index_files/Page667.htm.
This kit takes about an hour to install.
Don't forget to replace your door latch wax motor. See www.neptunehelpsong.com to hear a funny song explaining the faulty door latch failure.
Feb 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag 5500 AWW Turns off randomly shortly after starting
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt electronic components. If you have either... then you will need the the new motor conversion kit which includes the new motor, new motor control board and the wire harness. What you describe are signs the motor control board is nearing its end of life...
The kit takes about an hour to install. See www.neptunewaxmotor.com for disassembly photos so you can inspect the motor control board.
Sep 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new motor conversion kit which includes the motor, motor control board and the wire harness.
See www.neptunewaxmotor.com for disassembly photos and other Neptune information.
Sep 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
F1 fuse in Motor control board??
Dear wash boardn,
ngfam at you service!
need to clean your clothes????????
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
Aug 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer model #MAH4000AWW, Press start botton starts filling then shuts off after a few seconds. Move to spin it begins draining then shuts off after a few seconds
Check out your motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new motor conversion kit which includes the motor, motor control board and the wire harness.
These kits are offered on the www.neptunewaxmotor.com order form and they ship UPS Ground.
Don't forget to see the info on the website regarding the defective door latch wax motor that will eventually fail and damage your machine control board.
Jul 14, 2008 | Washing Machines
MAH5500BWW model fuse blown
You probably need the motor conversion kit 12002039. This Neptune motor / motor control board has a high failure rate. To determine this you need to remove the front cover and inspect the motor control board near the floor on right side for burnt components or a blown 10 amp fuse. If you have burnt components or a blown fuse then your motor control board has failed and needs to be replaced. See www.neptunewaxmotor.com for Neptune disassembly pictures and other neptune information.
Dec 31, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
