Question about Maytag Ovens
The oven touch bottoms are starting to not work acouple at a time do you think the control panel is going or is it the control box be hind it . Model mew5527ddw maytag wall oven
  • Maytag Master
  • 2,605 Answers
it certainly sounds like it's just the touch pad/membraine that may be going and not the timer/control by your description. does the touch pad visually look worn, i.e.cracking, discolored etc. ? there is a method to check those membranes with an ohm meter and about half a dozen hands, ha ha. (just a side note, on the control where this component plugs in can become contaminated with dirt and grease as well as other debris, at times I've been able to successfully clean the "ribbon connector" with some alcohol and a pencil eraser). but I'd suggest you call a tech if it comes to that.
the panel itself should be part # 5765M482-60. that is again based on info you provided, specifically the model number. also it will likely be packaged indicating it is a "whirlpool" item, don't worry, maytag is now under the whirlpool juggernaut.
hope that helps,
good luck
Posted on Sep 28, 2009
CAN NOT CONTROL BOTTOM OVEN
I assume yiu had the electronic oven control repaired. Sometimes the touch pad also goes bad. I have had to replace them at the same time. If the oven indicator lights showing the oven being on shows up on the display it could be that the thermal fuse behind the oven has gone out. this in in the common line and will shut down both ovens at the same time but you will get the control panel to respond to the touch pad.
Nov 23, 2013 | Whirlpool RBD305PDS Electric Double Oven
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Whirlpool electric range ygy398lxpq00. The start button on the front keypad will not work. I can set temperature etc. but when I press the start button nothing happens. Shut off power for considerable...
sounds like the touch pad is bad from what you're discribing,i looked up your model on the sears site and it looks like the whole front panel comes all together,part number W10122300 and it's around 230.00 dollars.you can call your parts store and see if you can just get the touch pad and hopefully you can.i've seen this happen before,the start button is pushed alot of times and it can damage the touch pad by pressing it to hard or just from using it alot of times.http://www.repairclinic.com/PartDetail/Touchpad-and-Control-Panel/W10122300/1372156 copy and paste this,this is the repair clinic,if you buy a part from them and it doesn't fix your problem they will take it back no matter what part it is and i think it's free shipping.it's a good thing to know when the parts are so expensive,also here's the sears site so you can look up your machine.good luck with it.http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Range-Parts/Model-YGY398LXPQ00/1198/0124160/W0703148/00002?blt=06&prst=0&shdMod=YGY398LXPQ00
Aug 15, 2011 | Whirlpool RBS275PD Electric Single Oven
Double wall oven broiler goes off by itself f7 comes on light bottom oven goes on and off by itself whole panel will not operate and then will--serviceman was in said it is the panel ya think??
it could be the touch panel or the computer board,the model number you gave isn't the full model number like 10 different models came up,next time get the number off of the machine not the book,if this is a newer machine you can push the clear/off pad, unplug the touch panel ribbon for a minute or two,if the code comes back it's the computer board,if it doesn't come back it's the touch panel.he must have pulled out the tech sheet and showed you what it said for an f7 error code and if he said it's the panel he must have done this test.
Apr 18, 2011 | GE JRP24 Electric Double Oven
No response to touch pad. No display or lighting. Check breaker and replaced circuit breaker.
Inside the control panel is a bullet fuse. This thing melts when temp inside control exceeds safe levels to keep from harming electronics.
I have a Whirlpool double oven service manual with
repair photos that shows how to get into the controls:
Whirlpool Double Oven Service Manual and more
Dec 26, 2010 | Whirlpool RBD276PD Electric Double Oven
Bottom oven is not working even though the top one is 720EF model
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Sep 17, 2010 | Stoves 720EF Electric Double Oven
Jenn air wall oven control panel not working properly
You will need to replace the front control board and the touch panel
Mar 28, 2017 | Ovens
F7 Error on GE Profile electric oven. No response from keypad.
The F7 error code on your oven indicates the touch pad has failed. To repair it, you will need to replace the touch pad which is listed as a control panel.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that holds the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touch pad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
Hope this helps.
Thanks for using Fixya.
Dec 15, 2009 | GE Ovens
Oven comes on for no reason followed by the start beep
yes you can kill the power and lock out the box with a pad lock for safety. the panel is attached by screws usually on the bottom of panel. lower and seperate the control panel ribbon from the erc (electronic range control). without removing any other components leave ribbon loose and replace panel. turn power back on. if the beeping does not recur, the control panel probably has a stuck key. if it does resume the erc is faulty
May 17, 2009 | GE JKP20 Electric Single Oven
Instructions required
I have a GE double oven. JKP44G with touch pad controls
Top oven door will not lock for cleaning cycle. I think I need a new motor for that.
Bottom oven will work sometimes and other times when I turn it on and select the temperature, thinking it is coming on - all of a sudden the temp light goes out like the oven is off and the oven does not heat. Sometimes I touch the clear button and then turn it on. Sometimes it works and other times not.
Could the connections in the control panel be dirty and not making connection at times?
Main question. How do I get to the control panel. How can I pull the oven out to clean the circuit or connectors and change the door motor. If I could just get into the panel I feel I could fix it.
Nov 14, 2008 | Ovens
Ovens Logo
204 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
