Ricoh Aficio 410dn printer - color issues
I have a Ricoh Aficio SP 410dn printer that does not print colors correctly. Blues are the wrong color and red does not appear to be printing. I think i'm having issues with magenta. I replaced the toner cartridge but still have the same issues. all other toners are full and the PCUs are relatively new.
SOURCE: Ricoh Aficio CL2000N not using Magenta Toner
I will have a look and see if i have the schematic for you , it could also be one of the development clutches that is slipping and not pulling forward , if you open the front door were you install the cartridges you will see there is a switch on the right hand side , stick like a screwdriver in there to jippo the door , then make a copy and see if the magenta dev init engages(meaning that it pulls all of the colours forward to the opc belt when making a copy , if magenta is not pulled you will know it is either the clutch or the board then .
Posted on Nov 17, 2007
  • 95 Answers
SOURCE: Ricoh Aficio SP C410DN "set toner cartridge correctly"
It sounds like the part the toner bottle slides under to lock in place is broken. you could try and fold some paper and tape it to the toner to hold it down.
Posted on Apr 23, 2009
EmmettPinger
  • 63 Answers
SOURCE: toner not reseting. i installed 2
Check to see if anything is broken around where the toner fits into the machine I recently had a customer break the piece that holds the toner in place. The machine symptom was that the toner did not lock into place like the other ones did.. GOOD LUCK
Posted on May 02, 2009
  • 46 Answers
SOURCE: Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
Posted on Aug 28, 2009
  • 15 Answers
SOURCE: Ricoh SP 8100DN will not load toner
The SP 8100 is a BW printer only, it doesn't take color toner.
Posted on Apr 16, 2010
Wrong manual appears for printer Ricoh SP C232SF
Here are additional manuals to search through...not sure if your manual was original or maybe repackaged/returned with wrong copy?! Please click Helpful button below if you were happy with my Fix....Best of Luck! http://office.manualsonline.com/manuals/mfg/ricoh/ricoh_all_in_one_printer_product_list.html
Jan 07, 2016 | Ricoh Aficio SP C232SF Print/Copy/Scan/Fax...
My Ricoh Aficio SP C420DN Laser Printer shows color tone SC366 and some time SC365, any ideas?
You just have a problem with colour PCU (SC 365 - magenta, SC366 - cyan). The main reason is that toner density is abnormal. Sometimes, when you replace toners, printer receive to much toner for a short time, and after that you have an abnormal toner density (higher). You can check in service mode (hold up and down arrows for 6-7 sec, release them and press ok button) following thing :
choose 2. engine
then with arrows choose 3. process
then choose Vt display,
for each color by default there should by somewhere arround 2.4V. If you see for some colors, for example 0.02V, then this is a problem(to much toner). In this case the only thing that you can do is to restart printer and try to print enough pages, filled with problem color. Usually you can print max 3 pages. Then restart printer and try another 3 pages. Print until the you will be able to print at least 4 pages continuously.
Good luck and remember that this is a technical problem and you should ask someone qualified for the job. I am sure that 80% of service engineers can't repair this issue. But I can.
Apr 17, 2015 | Ricoh Aficio SP C420DN Laser Printer
How can I check the color counter page for Ricoh Aficio SP C210SF?
The instructions for getting the page count for the C210SF should be the same as for the C231SF:
- Press User Tools.
- Scroll down until you see Reports Print.
- Press OK.
- Scroll down to either Configuration Page (2 pages long, prints in black and white) or Maintenance Page (1 page long, prints in color).
- Press OK.
Both the configuration page and the maintenance page will show the page counts. For page count instructions on other models of copiers or printers, check out ConfigPages.Blogspot.com.
Aug 11, 2011 | Ricoh Aficio™ SP-C210SF Printer
When I print, it is all black. what is wrong?
Check your settings withing the printing properties. Black may be set as default. Change it to color.
Nov 20, 2010 | Ricoh Aficio SP C311N Color Laser Printer
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Jun 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh SP c410DN - print dots verticaly down the page - I have clean the roller as instructed.
Notice what color the dots are. Most of the time you need to replace that color photoconductor.
Oct 29, 2008 | Ricoh Aficio SP C410DN Laser Printer
287 people viewed this question
k24674
jasbo
jasbo
