Question about Maytag Neptune MAH7500A Front Load Washer
I know fuse is gone on Maytag MAH7550AGW but how do I access the motor control board? Which screws do I need to remove etc?
  • 61 Answers
8 screws inside lip of dryer door including door hinge screws the hold front panel will come off the control board will be bottom right front.
Posted on Sep 28, 2009
Maytag frig model no mfi2569vem2 control panel not lit up and not coolong or freezing. light inside is on but dont here the motor running. we did have a power outage when issue occured
Sounds like the power outage took out your high voltage control board. This control board is located on the back of the fridge. Roll the fridge out of its position so you can get behind it. Once you have pulled out the fridge you will need to UNPLUG it. There will be a couple 1/4" screws securing the metal cover to the back left side of the fridge (if you are facing the back of it). Remove these screws to find another plastic cover which will need to be removed. This control board controls the fans and the compressor. You can take the control board out and look for a burn mark or a blown soldered fuse. According to your model number the control board part number is W10310240.
Nov 02, 2016 | Maytag Refrigerators
Maytag model MVWC200BW0 one year and 12 days old starts to fill and then drains before finished filling.of course Maytag was not helpful since warranty expired 12 days after one year. What could be t
You will need to replace the control board. Here is that part to order. Electronic Control Board
To replace the board you will need to remove the screws on the back of the console to access the control board. It is an easy repair.
Oct 28, 2014 | Maytag Washing Machines
My Maytag Neptune washer is not spinning and I tried only Spin cycle for 12 minutes and gave LR error message. Pl help?
Hi, the Maytag Neptune front load washer LR or Locked Rotor error indicates and issue with the motor drive system. The motor control board is located near the floor on the right side. See Neptune Disassembly help to remove the door and front panel to get access, if needed.
I would unplug machine, remove all connectors and reinstall a few times and retry machine in case of any oxidation on the connectors. Also, check the belt and make sure it has not popped off. There is a rear access cover you can remove to take a peek.
In addition, there is a motor drive test you can perform to see if the inner tub will rotate at 50 rpms. You should have a document with your machine that instructs how to perform this simple test and it could be located in the top console.
Depending on which machine you have... If the motor control board has failed then you may have to replace the motor and motor control board since Maytag redesigned them because they were having reliability issues with them and they decided to change the motor technology they were using. See maytag maytag Neptune motor conversion kit for more info.
I hope this helps...
Apr 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washing machine keeps triping the breaker. reset breaker but wont turn on at all now. how can i access the electrial wiring to see if anythings shorted out
Most of these Top-Load Maytag machines, allow access to the controls, by removing two screws on the top of the top control panel--
Remember to pull the plug from the wall before getting inside the control panel section.
When you remove the two outer screw, the panel itself will tilt forward, giving you access to the insides.
Most models have a control fuse inside, that may have blown-- Can you see it toward the back, and the middle. Does it look blown?-- can you replace it.
Note: I found on my machine, that the 2 switches that are connected to the lid get sluggish, and can result in blowing the control fuse, with the dropping of the lid!--
I found that I had to make sure the Control knob was always IN whenever we move the lid up or down.
Let me know if this helped-- or if we need to dig deeper.
Mack B
Jan 27, 2011 | Maytag Legacy Series Top Load Washer
Washer not spinning or spinning slow during spin cycle
chance are the motor control board has gone bad,to get to it you need to remove the door and then take a putty knife and go around the top and side and pop the clips by just pushing in and pulling back to you! after the top is lifted the are a couple screws holding the front on remove them and take front off, The motor control board is on the front right hand side. and you can see the motor in the rear left.you will need to order the replacement motor kit which has a motor and a board with instructions on how to replace these parts. any online parts store can help I use searspartsdirect.com
Nov 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag washer stoped during the cycle with 8
You may have blown the internal fuse located in the lid switch. Could be you over loaded the washer and blew the fuse.
Unplug the washer and remove the four screws holding the control panel front in place. Two screws on top and two screws under control panel.
Remove the control panel and tilt forward.
Locate the lid switch assemble and remove glass fuse and inspect.
Door switch assembly should be replaced. When you order the proper fuse it should come with the door switch assembly.
Replace assembly. Reinstall the front control panel and four screws.
Plug machine in and test.
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Soap dispenser door doesn't open for the second cycle.
Hi, the soap dispenser has a motor / solenoid which controls the latch that opens the door. This has gone bad and needs to be replaced. It is located inside the dishwasher door panel. Remove the screws around the inside of the door to gain access to the solenoid. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 18, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
I am doing a load of laundry the washing machine maytag neptune
This means locked rotor. you have a bad motor control unit. take the door off by removing the 4 screws also take the side/front panel off. You will see the motor control board. Do you have a delay wash cycle? If you do set it to delay wash remove the jp4 connector if the unit tumbles on it's own then the motor controller is fine but if it does not then you have a bad motor control board. Check it out and let me know. also there is a fuse on that board if you can locate it and check for continuity that will also help diagnose it. MAKE SURE YOU UNPLUG IT FIRST THOUGH!!!!
Jun 04, 2009 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH7500A Front Load Washer Logo
135 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
