Question about Microsoft Xbox 360 Console
One red light and E68 code?
When switched on and middle button on controller is pressed one red light appears and the code e68 appears at bottom of screen?
    Novelist:
  • 168 Answers
This behavior occurs when an Xbox 360 Hard Drive hardware failure occurs.
1. Turn off the console.
2. Remove the hard drive. For more information about how to attach or remove the Xbox 360 Hard Drive
3. Reattach the hard drive, and then turn on the console.
4. Obtain the latest automatic update for the Xbox 360. To do this, connect to Xbox Live.
5. If you continue to experience this behavior, contact Xbox Customer Service.
http://www.xbox.com
020 7365 9792
or 0800 587 1102
Hearing Impaired (TTY device):
0800 587 1103
Above UK offices
US office below:
  • Toll free: (800) 4MY-XBOX
  • Direct dial: (425) 635-7180
  • Hearing impaired (TDD device): (866) 740-9269 or (425) 635-7102
Posted on Sep 28, 2009
What is Frigidaire gallery dryer code e68
I appreciate your post, friend!
From what you have described your Frigidaire dryer is showing a "E68" error code. "E68" usually indicates that one of the keys (buttons) is stuck closed (active). You may enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps! -Matt
Feb 13, 2015 | Frigidaire Dryers
How do I fix the code E68?
Hello Anne, thank you for your post!
From what you have described your Frigidaire dryer is displaying an error code of "E68". An "E68" code stands for a key (button) is stuck I would suggest pressing each button to see which one releases. If that does not work I would recommend performing a reset on your control panel and you can do that by flipping the household circuit breaker off for roughly ten minutes. If you restore power and continue to have issues it is possible that you could have a faulty control panel or keypad. In order to replace any electrical components I would consult with a professional for proper disassembly of your dryer and replacement of parts. -Matt
Feb 04, 2015 | Frigidaire Dryers
Frigidaire affinity LEQ6000ES2 error code e68...dryer will not start
Good Afternoon David,
I understand that your Frigidaire Affinity dryer, model# LEQ6000ES2, is showing you an error code of E68 and will not start. I also see that you have changed the thermal limiter. Looking at what the E68 error code means, a key or button stuck, there could be something else causing the code to come up. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the E68, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire Dryers
Aeq6700fso dryer dryness button won't change the
E68 is a stuck button on th control panel
Nov 06, 2012 | Dryers
Frigidare AEQ600es2 does not heat. Reports error code E68, but all buttons seem to work.
You will nee The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Apr 17, 2012 | Frigidaire AEQ6000ES Electric Dryer
Was receiving E68 code on Frigidaire GLEQ2152ES1, replaced circuit board and am still receiving the e68 error code. What else will cause this error?
Hi yoyosam66...
Your e68 error code means:
Please take time to rate me
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel. Solution:
Press buttons lightly and release.
Disengage button.
Aug 17, 2011 | Frigidaire GLEQ2152ES Electric Dryer
What is E68 and how do i fix it? when i switched on my xbox 360 a red light appeared in the bottom left of the power switch and a system error appeared on the screen with E 68 what is this and how do...
The E68 error means that your hard drive is either broken or not connected propperly. Turn the xbox off and take out your hard drive and put it back in. When you put it back in make sure that you hear it click at the back of the xbox. then turn it on. if it still doesent work your hdd is ruined and youll have to get microsoft to fix it.
Dec 29, 2009 | Microsoft Xbox Console
The dryer gives E68 it starts running dor 30
the code 68 on the aeq7000es series is indicative of stuck buttons [your control buttons on the front]They sometimes stick in the closed position or go open [fail] and I have found the bad switch and replaced just the bad switch[ there should be a series of test to determine which switch button is bad] and if the switch buttons are testing good ,then it's control panel time. The control panels are about $150.00 on ebay ,sometimes you can find a "make offer" deal,but their few and far between.
Nov 18, 2009 | Frigidaire AEQ7000ES Dryer
The e68 keeps popping up on my time window. Have
You can contact this guy...seems others have had the same problem with some frequency..send him your contact information...model and serial number...he's THE guy to talk to with Frigidaire. Chris Polk
Escalation Specialist
electrolux Major Appliances
chris.polk@electrolux.com Another tech had this information to share: 6 beeps / E68 - Push button does not function
Cause:
Solution:
Disengage button.
Try doing that first if the error code still shows up, then you'll likely need a new control board assembly.
Here's the one for your model:
Manufacturer part#134523200 is RepairClinic item#1154933
May 02, 2009 | Frigidaire Dryers
Frigidaire dryer giving E68 code
E68 means one of the buttons is stuck. Try pressing the buttons lightly, or disengaging them with a small tip.
Sep 14, 2008 | Frigidaire Dryers
Microsoft Xbox 360 Console Logo
218 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
