Hi, my twf tv sometimes would not turn on at the switch, turning it off and on a couple times solved the problem, unfortunately that doesn't work now and it wont come on at all. any suggestions
5 Suggested Answers
SOURCE: Olevia 42"
Olevia LCD 542I - Had the same issue for a week until the tv would not turn on anymore, after several attempts it came back on. A few days later the tv turned off then only the standby light was on, then lost the standby light as well. After researching the problem it could be in two areas, either the power supply or main board. Removed the back and found the power supply had several capacitors that were bulging on the top and appeared the fluid was leaking, all signs of a failed part, removed the PS and replaced four capacitorst that had shown some issues. If you can removed the PS and check for a number on the board, mine was FSP271-4F02, and find someone who has some electronic circuit capablilty, the issue may be resolved at a fraction on the cost of a new power supply.
Posted on Apr 23, 2009
SOURCE: Hi I bought a reconditioned TWF 26
there is a little fuse inside the tv change that but make sure u change it for the right 1 tho or u can blow the main board up
Posted on Jul 18, 2009
  • 231 Answers
SOURCE: Hi my plasma tv doesn`t switch on?
could b flyback transformer, hard to tell with out benc testing , no power is cheaper to fix than picture problems and normally a lot less God Bless
Posted on Apr 15, 2010
rustym62
  • 201 Answers
SOURCE: my tv clicks but wont turn on. it used to click
Your power supply most likely is the problem, its happening to a lot of samsung tvs. If you know how to solder it is usually an easy fix. There are capacitors that are unable to hold voltage. Instead of being flat on top like the others they will be rounded on top. Replace those caps usually no more than 2 of them. The value of cap will be written on side of it. Using a cap with a larger voltage rating ( example of cap has 10v written on a higher number will handle more voltage and therfore last longer. A repair service may want to replace entire power supply instead, greatly increasing repair cost.
Posted on Jul 04, 2010
Can anyone help me with a code for twf tv model number lcd3261id so it works with my sky q remote
all i know is they made by Siemssen, made for sainsburys. and i don't think there is a code, sometimes technika codes work
Feb 08, 2018 | Televison & Video
32" toshiba 36a60 plays DVDs but not cable TV
Did you switch video inputs from the remote, each input has its own menu item.
May 19, 2017 | Toshiba 32DF46 32" TV
My AT&T U-Verse remote control is not responding anytime I click it. Does anyone have a solution?
Hi Yoav! The AT&T remote control from U-Verse can be quite buggy sometimes-- trust me when I say you're not alone.
Thankfully, the fix is quite simple and should only take you a couple of minutes. If this doesn't work you need to get a replacement remote.
All you have to do is turn your receiver off, keep it off for about a minute, and turn it back on again. For whatever reason the U-Verse remote and your cable box will intermittently lose the ability to interact with one another, but going through this type of "soft reset" will usually solve the problem.
I know AT&T has had this issue for awhile but it looks like they haven't been able to solve it yet. Big surprise right?!?!
Mar 01, 2012 | AT&T UVerse
Daytek 46" LCD TV.. When
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck in solving the problem....
Jun 09, 2011 | Televison & Video
My twf does not turn on, all that happens is the little red light on the front just flashes, its model twf 4117wd
On the TWF-4117WD when you have just the flashing red light when you press the power button,the fault is a dry joint on an smd link near to the connector at the top left of the mainboard,the first one for the power button etc.
Once re soldered all should be fine,be careful though its only a couple of mm in length.
Oct 04, 2010 | Televison & Video
Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Feb 24, 2009 | Samsung Televison & Video
Plasma TV keeps turning off and blinks 5 times
Bad capacitors on the power board. If they look swollen or enlarged then they are most likely not holding enough charge.
May 17, 2017 | Televison & Video
PS3 No signal to the TV
I'm having similar problems. I had my PS3 on pause, whent out for a couple hours, came back to find a weird fuzzy screen. My PS3 had froze, so I turned it off. I turned it on a couple minutes later, and the green light came on, however, my controllers would not connect, no image was popping up and it also wouldnt turn off unless I flicked the switch on the back. After contacting Sony, they told me it could be an overheating issue. If it has been less than a year, they will replace it, NOT FIX IT. Which is great and all, but unfortunately I am about to lose the countless hours I've put into assassins creed, skate, call of duty 4 and motorstorm.
HOWEVER. If your PS3 is still "functioning properly" except for no signal, turn the power off on the back, turn it back on, press and hold the power button on the front untill you hear the second beep, let go, give it a couple seconds, turn it off from the back and then back on, hold it till the second beep again. Good luck.
P.S. I recomend getting the extra cooling fan for it, and saving game data on another card (SD) incase crap like this happens.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Whirlpool LTE5243D Top Load Stacked Dryer heats sometimes and not others
couple things this could be lets start obvious
faulty door switch even though door latches doesnt mean its working properly
bad guages easy to check dont have to run dryer just guages
turn on setting let run threw cycle if it stops on cycle and dont move for a length of time this will be the problem
these 2 things are main causes of why a machine wont work or partcially works at times everything else is easy
Nov 27, 2007 | Whirlpool LTE5243D Top Load Stacked...
Televison & Video Logo
450 people viewed this question
Top Televison & Video Experts
