Question about Canon SmartBase MP360 All-In-One InkJet Printer
Jag har canon smartbase 370 .jag fAr Error ## 343.
Jag har Canon SmartBase 370. Error # # 343. det gar inte att kopira. det stAr kontrolerar skrivare Error ## 343. tack
5 Suggested Answers
jonniewalker
  • 1029 Answers
SOURCE: error code printer check ** 343
the error is "Waste Ink Tank Full" error
This error occurs after a set number of nozzle activations, and it's to protect you from having ink start leaking out of your printer.
The waste ink tank is actually a large cotton pad in the bottom of the machine which absorbs the waste ink, and if this pad becomes full, the ink will pool and, like water, seek the path of least resistance, which could be where the case parts connect, and then leaking out onto your desk or carpet...
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu Copy Copy Copy Scan
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
hope it works for your model
Hope it helps.
goodluck pls dont forget to rate this
Posted on Sep 21, 2008
jonniewalker
  • 1029 Answers
SOURCE: Ckeck printer ##343
its a printer reset error press
*AF-Key = Additional Functions key = the black button with the star in a head above it.
1) Enter SERVICE MODE. (Press AF-Key, followed by "scan", "copy", "scan" -Keys)
2) Select TEST MODE (press right arrow button 13 times).
3) Hit -OK-
4) Select [8] PRINTER TEST
5) Hit -OK-
6) It'll now say "- 8-2 +" press the right arrow key once to get "- 8-3 +"
7) Hit -OK-
8) Select 0. [INK COUNT].
9) Hit -OK-
10) It should return to showing the "8: Printer Test - 8-3 +"
11) Press the [Stop/Reset]key - (black key with triangle and circle on it) - (returning to the state of 4), and then press the [ON/OFF] key.
Cleaning the print head:
At any time, DO NOT wipe the actual print head with your fingers. Use ONLY water.
-Remove print head assembly from printer.
-Remove ink tanks.
-Use running warm water, wash away the exess ink that is dried around the print head.
-Take one disposable mug, fill with hot water, drop the print head assembly in there, and let it soak for an hour, or so.
(-IF you have massaging shower head, with spray jet -function, use this to deep clean the actual print head.)
-Dry it up carefully, do not wipe actual print head, just tap gently with soft paper.
-Install ink tanks, install assembly to printer, let it settle for some time (5-30 minutes)
-Run Nozzle check, cleaning, print head alignment
hope this helps if you have further problem do let me know
pls appreciate by rating this solution
Posted on Sep 22, 2008
SOURCE: Canon smartbase Mp 390 ##343 Check printer
can you help my printer canon smartbase mp390 not working gives notice check printer ##343
Posted on Dec 03, 2008
L0rdL0ki
  • 45 Answers
SOURCE: What does ##343 mean?
##345 is jammed cartridge error. Reasons could include:
-Foreign material or dried ink in head cleaning unit (also known as "purge unit") , or waste ink pump jammed up. Make sure waste ink pump rotates freely, after cleaning. Clean the waste pump-hose too! Waste ink pump is located under head cleaning system.
Symptons are:
-Grinding noise (very loud)
-Flashes error code ##345
Short fix:
1.Take apart and wash the ink clogged mechanical parts. Use hot water.
2. Reset waste ink counter
Long fix:
The following operation takes several hours / days to complete.
-Take apart the whole printer, so there is only a metal frame left, with couple of paper-rollers, and motors, and the "Print-head cleaning" -system. Wash this cleaning-system.
-Mark all wires that look the same (especially white flat ones), take photographs when disassembling.
In detail, remove at least following items:
-Main Power lead!
-Casing (Use bright flashlight to see TWO front cover-screws under the dark plastic!)
-Scanner (BEWARE of fragile flat-wires)
-Main electronic controller board
-Metal plate, plastic cover, and some others.
-Plastic base plate
-All materials that might absorb water. (two sponges, and one rubber foam part)
The two sponges are between metal frame and base plate, they absorb excess ink. Wash these separately, and dry, or change for new. (I left the shorter one out, when assembling)
There is also one long rubber foam part that is near where paper comes out, (visible from outside the printer, when cover is opened).
To get rid of the excess ink: Wash dirty parts heavily for 10 to 15 minutes with hot water. When out-coming water is clear, then it is clean.
-Let it to dry for couple of days, but you can use your imagination - compressed air could help it dry faster.
-Assemble it back together
How to reset waste ink counter (you should clean the printer also):
3) Hit -OK-
5) Hit -OK-
7) Hit -OK-
9) Hit -OK-
-Remove ink tanks.
-Use running warm water, wash away the excess ink that is dried around the print head.
-Run Nozzle check, cleaning, print head alignment.
This should do the trick.
Answer extracted from service manual and Techimo.
Good Luck,
-LL
Posted on Feb 23, 2010
Testimonial: "Thankyou for detailed solution - appreciate it enormously. The only thing I´m still pondering on is it says: ##343. Is it equivalent to ##345? Nikita"
Hej!Jag har en CASIO EX-Z150. När jag sätter på kameran säger den att kortet är låst. Jag vet inte vad jag ska göra. Det går inte att göra nånting med...
Ibland finns det en liten str?mbrytare p? sidan av SD-kortet som g?r det m?jligt att skriva till kortet av och p?. Om det misslyckas ?r det f?rst med ett annat minneskort.
Aug 19, 2017 | Casio EXILIM Zoom EX-Z150 Digital Camera
Nearly all webcams have a control center but not
Please click here to download the latest version or firmware and drivers for the camera in your laptop.
Please let me know if you have any further questions or concerns.
Thanks.
Apr 09, 2010 | Microsoft LifeCam VX-1000 Webcam
Skrivaren skriver inte ut fast jag har satt i ny bläckpatron
Translated from Swedish:
> The printer does not print although I have put in new ...
> How can I clean my printer?
> I have Lexmark 3200
Access: http://support.lexmark.com
Enter 'clean 3200' and do a search. Read the documents.
Dec 30, 2009 | Lexmark Color JetPrinter 3200 InkJet
I have error ##343 on canon smartbase MP390
if this is a lazer printer the waste ends up back in the cartridge. if you have a refilled cartridge you can only refill once, maybe twice then you need a new cartridge
Aug 16, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Svart lcd sk??rm
jag har köpt en ny kamera.Mats
Jan 02, 2009 | Sony DCR-HC39E Mini DV Digital Camcorder
Ckeck printer ##343
3) Hit -OK-
5) Hit -OK-
7) Hit -OK-
9) Hit -OK-
-Remove ink tanks.
Aug 13, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Jul 25, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Abit BL7-RAID
Please formulate question in English, or submit to general questions
Thanks
Apr 17, 2008 | Abit BL7-RAID Motherboard
Error code ##343
We have just attempted to install an Cannon imageclass mp360 and the error message "check printer ##343" is displayed.
Can you please help.
May 14, 2007 | Canon SmartBase MP360 All-In-One InkJet...
Open Questions:
See all Canon SmartBase MP360 All-In-One InkJet Printer Questions
Canon SmartBase MP360 All-In-One InkJet Printer Logo
56 people viewed this question
old marine
old marine
