Question about Mag Innovision lt456s 14" Flat Panel LCD Monitor
Lt 456 s
Might there be a driver for Vista? I used the monitor under xp with no problem, but when I put it on a Vista machine, it is using a default driver that has minimum settings....
tissot@mindspring.com
  • 102 Answers
U will get it on download.com
yeah it is driver problem nothing more
it happened to me too.
Posted on May 17, 2009
Does a vista driver exist for sony SDM HS75P?
No but you can attempt to use the default driver or the windows 2000 one. I have found that a few of the windows 2000 and xp drivers do work for things that vista doesn't have a driver for
Feb 12, 2010 | Sony SDM-HS75P/S 17" LCD Monitor
Windows 7 drivers for minolta magicolor 2300dl?
Two Minolta 2300DL windows 7 64-bit solutions(choose oneoption): 1) Download the XP 64-bit driver and extract to a folder: ftp://ftp.minolta-qms.com/pub/crc/out_going/windows/2300d_64b.exe then Control Panel>Devices and Printers>Add aprinter> Add a local printer>choose USB printer port>select the "HaveDisk" button(do not select a printer) and browse navigate to where you savedthe XP 64-bit driver "MLUU_DRV.inf" driver file which installs and worksfine. Only issue is now have a 3 minutewait delay for each print job using the universal driver compared to no delaywhen printing with XP. OR 2) Follow the Vista USB port(not network) install guide butstill use the XP 64-bit driver. ftp://ftp.minolta-qms.com/pub/crc/out_going/manuals/misc/km_vista_instruct.pdf 3) 32-bit option use the Vista 32-bit driver first as thatshould work.
Nov 06, 2009 | Konica Minolta magicolor 2300DL Laser...
Using Windows Vista, documents remain in the print queue after printing necessitating that the computer be restareted between every print job. Is there a fix?
Hi jonty143, you can try these steps.
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
Oct 13, 2009 | Dell A940 All-In-One InkJet Printer
Can you help me install my dell 720 printer with the drivers download from dell? My 720 dell printer installation disk was lost and I have had NO success reinstalling the printer with the drivers download...
you can follow these steps:
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
12. Make sure the driver you downloaded from support.dell.com is compatible with the operating system that you're using, for example windows xp or windows vista.
Oct 01, 2009 | Dell Inkjet 720 Printer
Need driver for xp
There are no drivers needed for Windows XP, the default monitor driver will work fine.You may need to update your video card drivers if you are unable to use the recommended resolution.
May 01, 2009 | Computers & Internet
Vista doesn't detect hp laserjet 3030 as usb device
6 - Yes. Your product is supported. Drivers for HP printers are included with the Microsoft Windows Vista Operating System. Additional software will be available soon. HP has a driver solution available for your product. HP is committed to providing the best experience for HP products in the Windows Vista operating environment. Currently, a full-solution driver is not available for your product. However, we do have an alternative driver solution that you can conveniently find in Microsoft Windows Vista. This driver will enable your product's basic functions to work and can be used until the full driver solution is available. Full-solutions will be available as early as January 2007. HP expects to complete the certification process for applicable software by July 2007. Solutions will be posted as they become available. Click here to recieve e-mail updates from HP when a solution is available. HP aspires to provide the most up-to-date information on HP drivers and software. Please check back soon for updates.
NOTE: If your printer currently uses either a PCL5, PCL6 or PostScript XP driver you may download the current XP driver from HP to provide printing functionality. Windows Vista printing is very similar to Windows XP and most print drivers supported in XP environment for LaserJet printers may also work in the Windows Vista operating system.
Jan 04, 2009 | HP LaserJet 3030 All-In-One Printer
Can't print from Vista to networked printer
the software that u are using is not copatible with the prenter. try to set up a pier to pier conection by using other ip address. use MSHOME in your work group then try to put 10.0.0.01 then put 10.0.0.2 as DNS ang default gateway. then do it to the vista notebook just change the ip address by using 10.0.0.3. let me knoew if its ok
Nov 28, 2008 | Konica Minolta magicolor 5430 DL Laser...
Cannot find drivers for product.
Hannspree said that there is no need for a separate driver for XP and suggested I check for an updated driver for my old NVIDIA Video card... That was the answer. I now get the full 1400X900 resolution.
Mar 30, 2008 | Hannspree HW191D LCD Monitor
Monitor in default
I think the first problem was that you did not load the drivers for the on-board video. And the problems you are having now may also be due to not loading drivers - in this case the chipset drivers for the motherboard. If you go to the vendors web site for the machine or motherboard, they should have all the drivers you need to get your machine running properly. If you give us some info on the brand of machine or mobo, we can then tell you where to get them.
Feb 06, 2008 | Gateway FPD2275W LCD Monitor
Windows Vista problem
You need to download the driver, go to the web site and find the download
http://www.norcent.net/main/support_product.asp
Nov 26, 2007 | Microsoft Windows XP Professional With...
Mag Innovision lt456s 14" Flat Panel LCD Monitor Logo
130 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
