Question about E-Machines T3504 PC Desktop
I want to add memory to my computer but do not know what brand or type to get. I have an Emachines desktop PC with the current memory of 256 mb (DDR SDRAM). I play graphic games alot.
  • 8,404 Answers
Posted on Sep 28, 2009
Testimonial: "VERY helpful! Found exactly what I needed to know! Off to buy what I need! THANK YOU!"
  • 6,831 Answers
Hello
The best way for you to upgrade your ram DDR SDRAM, is to take your current chip to your nearest dealer and they will tell you exactly what the price and brand will be. You can even try to bargain so that you do a trade in with your current chip. Really hope this can help you.
Best regards
Testimonial: "Thanks, I will give that a try."
Slow loading,game cutting off
Try adding more RAM
Adding more ram will boot applications / games quicker
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
You should always ask or get working pairs in a ram upgrade some ram modules wont work together even if they are of the same brand and type ie: DDR ,DDR 3
Checking Amount of RAM
Click on "My Computer" and select "Properties" using right-click in the Explorer window.
This will open "Systems Properties."
Click on the "General" tab.
Here you can view the physical memory installed on your computer.
The amount indicated is the total RAM installed on your computer.
RAM is usually 32 MB, 64 MB or 128 MB in older PC versions.
Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
Check the usage.
To know the currently used RAM (based on programs you are running), open the taskbar or press "Ctrl + Alt + Del" to open a pop-up window. Click on "Task Manager."
Click the "Performance" tab.
You can view the amount of memory currently used by each program running on your PC.
Mar 18, 2014 | Computers & Internet
I want upgrade my emachines t6528 hard drive and ram.i need help
Memory Upgrade for eMachines eMachines T6528 Computer, the eMachines eMachines T6528 Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T6528 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
As for the Hard Disc.... the following address will give step by step instructions on installing a new HD. http://www.manualowl.com/m/eMachines/T6528/Manual/
Thank You for using FixYa
Tom Miller
KD4DTK
Aug 19, 2012 | E-Machines T6528 PC Desktop
What brand of memory ram can I use in a t 2240 ? :) , tnx
The brand doesnt matter, you do need to be concerned with the type you use.
I looked up your computer on emachine's website and determined that you can use 184-pin DDR 266 memory.
search results from newegg (a trusted online retailer in computer/networking hardware):
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=%2040000147&Description=pc2100&bop=And&ShowDeactivatedMark=False&Order=PRICE&PageSize=20
kingston and pqi are both respectable companies for memory
That being said, I would contact emachine to determine the maximum amount of ram supported by your motherboard:
the page specific to your computer (contact info at bottom):
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T2240
if you have any questions please let me know.
Thanks,
Mike
May 16, 2010 | E-Machines T2240 PC Desktop
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Need to know mem spd...333...400 etc to add cards
Memory Installed 512 MB (2 x 256) Maximum allowed 4 GB* (4 x 1GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
Thats the sticks you need
Good luck
Nic
Feb 26, 2009 | HP Compaq Presario SR1630NX PC Desktop
Which memory ram for amilo pro v7010
http://www.fujitsu-siemens.ru/Resources/123/2080773523.pdf
Here's a link to the Data Sheet with the specifications to that Laptop in Adobe Reader format.
Looks like your Laptop came with either 256 or 512 MB of DDR SDRAM and it is upgradable to 2 GB of DDR SDRAM.
You can check to see exactly how much RAM your computer came with by going to Control Panel, double-click System and it should tell you how much RAM you currently have in the System Properties box.
The motherboard has 2 slots for RAM, you you could add a second 256 MB or a second 512 MB stick of RAM. Or if you wanted to upgrade to the 2GB of maximum RAM this computer handles, then you can take out the RAM chip(s) that is installed and install two 1G DDR SDRAM.
Jan 31, 2009 | Computers & Internet
Inspiron 6400 notebook
There are two slots for memory on that laptop and it will take a maximum of 2GB of RAM. The memory type is 1.8-V SODIMM DDR-2.
The cover ont he bottom if the laptop is easy to access and add more memory.
Dec 31, 2008 | Dell Inspiron 6400 Notebook
My name is Siavosh Eskandari. I have a desk top PC Compaq presario Desktop with Intel celeron processor 2.7 HHz Model SR1010NX, Prod. # DW25AA-ABA,Serial # MXK4180P8Y with 256 MB PC 2100 DDR SDRAM. The...
the model SR1010NX can take upto 1gb max of ddr 1 ram and must be done a 2x 512 ddr 1 chips
Memory Component Attributes Memory Installed 256 MB (1 x 256) Maximum allowed 1 GB (2 x 512 MB) requires the replacement of the installed 256MB DIMM Speed supported PC2700 MB/sec (messages at PC2100 Type 184 pin, DDR1-333 SDRAM DIMM slots Two
Nov 28, 2008 | HP Computers & Internet
Want to kow how much ram I can add and where to buy it.
Hi
Dimension 2350 Series has two memory connectors and supports non-ECC PC2100 (266-MHz) DDR SDRAM memory modules. Supported memory capacities are 128, 256, or 512MB. The maximum (total) memory is 1GB.
Regarding where you could buy? I suppose you can check you local PC store. There is always eBay if you fancy.
Mike
May 16, 2008 | Dell Dimension 2350 PC Desktop
Ram upgrades
Does'nt matter which goes where as long as they are all compatible with the motherboard.
Mar 18, 2008 | E-Machines eMachines Desktop PC
E-Machines T3504 PC Desktop Logo
155 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
