Question about Microsoft Office Professional 2007 Full Version for PC
In the word styles list show exactly the styles I
In Word 2007 styles list show exactly the styles I want in the Style box and no others?
    Problem Solver:
  • 15 Answers
On the Home tab click on the little box in the corner of the Styles group. This should pop open the styles pane. This is probably the option you're looking for anyway, but if not...
On the Styles Pane on the bottom right-hand corner is the word "Options..." Click on it.
This action will open up a pop-up menu which should give you options on what is displayed in the Styles Pane. This does not work for the Styles group that is displayed in the ribbon, but it will let you choose what you see as long as you keep the Styles Pane open.
Posted on Dec 02, 2009
I need to set the comment language in Word 2007 and don't know how to do that.
I found this answer at http://word.tips.net/T007248_Changing_the_Language_of_Comment_Boxes.html. I think it will answer your question, regardless of your Word version. (Word has been using Styles for interesting modifications like this since 6.0.)
Changing the Language of Comment Boxes
by Allen Wyatt (last updated February 15, 2014)
Mary Anne edits academic texts. She is Canadian, as are most of her clients. She therefore sets all documents in Canadian English. However, she discovered that in Track Changes comment boxes are still in U.S. English. Mary Anne wonders how she can change the comment boxes to Canadian English.
The solution to this question is rooted in the way in which Word uses styles. All the text that Word creates is formatted through the use of styles. The text in comment boxes is no exception. You can modify the appropriate styles related to comments by following these general steps:
1.Display either the Styles dialog box or the Styles and Formatting pane, depending on your version of Word. (How you do this has been covered many times in other issues of WordTips.) [ED: Try using help on your Word to find out how to display the Styles and Formatting Pane. Search for "how to display styles pane".]
2.Use the controls in the dialog box or the pane to display all the styles used by Word.
3.Use the controls to modify the three styles used for comments: Comment Text, Comment Reference, and Comment Subject. You can set the language used for each of these.
4.Close the Styles dialog box or the Styles and Formatting pane. That's it. Change the styles, and Word changes how it treats the text formatted with those styles. You'll particularly want to pay attention to the Comment Text style; it is this style that is used for the text shown within comment boxes.
Jan 12, 2015 | Microsoft Office Word 2007 Full Version...
Tip
TOSHIBA DVD REGION FREE HACK METHOD.
1. Power on.
2. Open tray.
3. Push the info on remote once (with supplied remote). You will see numbers.
4. Press 9 for multi-region. Keep trying until you see the number 9 appear in upper left corner.
5. Power off.
Power on.
on May 21, 2012 | Toshiba Televison & Video
Tip
Riding Mower No Start Troubleshooting
  • First check the air filter to see if it getting air and gas.
  • Check your gas cap. If your gas cap is clogged, your fuel tank can get a vapor lock, and you will have no gas flow. Loosen the gas cap to see if it will run longer.
  • Check the gas filter (if you have one on the mower) to be sure it is clean and has good gas flow.
  • Check to see if you are getting spark at the plug. Check out the video below.
If the engine clicks but will not start, the battery or solenoid is often to blame. To find the battery on a riding lawn mower:
  • The battery may be under the hood
  • The battery may be located under the seat
  • You may need to lift the hood to find the solenoid
  • Check the owner's manual for the battery or solenoid location
Check to see that all wires are securely connected and that the terminals are clean.
If the lawn mower still does not start, the problem may be with the fuel, if it was left in the mower over the winter months the fuel may have become stale or watered.. If the fuel appears dirty or contains water, you will need to drain the fuel tank and replace with fresh gasoline.
Other reasons for the mower not to starting also include:
  • Damaged or loose wiring
  • Problems in the carburetor
  • Maladjusted or damaged engine valves
  • A blown fuse
  • Ignition switch may be faulty
on Oct 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Where is the fuse box for 2004 f150 for the instrument panel lights
Under the right kick panel> on the inside in front of the passenger door under the dash>
Aug 23, 2014 | 2004 Ford F150
How to underline the text
which program ?
Underline Text in HTML b> Find or enter the text you want to underline. Place the text within a SPAN element, by adding an opening tag before the text and closing tag after. Specify underlining of the text within the SPAN by adding a STYLE attribute to it as follows:
STYLE="text-decoration; underline; " Add a CLASS attribute to the SPAN, giving the name of a CSS class which defines text underlining. This is an alternative to using the STYLE attribute as described in the preceding step. The format of the CSS class declaration is as follows:
.my-underlined-class { text-decoration: underline; } b> Underline Text Using HTML b> Find or enter the text you want to underline. Enclose the text within a U element, by placing an opening and closing tag before and after the text.
Underline Text in PowerPoint
PowerPoint includes shortcuts for adding font effects, such as strike-through, italics or subscript, to any text in your presentation. Like other products in the Microsoft Office Suite, PowerPoint also allows you to underline important words or phrases on a slide to help empha important aspects of your presentation. Microsoft's use of hot-keys makes it possible to underline text identically in all versions of PowerPoint.
View the slide that has the text you want to underline. Highlight the text you want to underline. Press "Ctrl" and "U" simultaneously to underline the highlighted text.
Underline Text In Word 2007
b> Microsoft Word 2007 makes it possible to create and edit documents for email or printed use. This word processing application allows you to add a number of formatting options that enhance your document. One of many features included in Word 2007 is the ability to underline words or sentences. You can make certain words stand out using either basic or decorative lines.
Open your Microsoft Word document and highlight the word or sentence you want to underline. Click the "Underline" icon located on the Home tab to underline the text. Select the text you want to underline, if you want to underline words, but not the spaces between them. Click the "Font" button on the "Home" tab and click the "Font" tab. Click "Words only" in the "Underline style" box. Select the text or sentence you want to underline, if you want to double underline. Click the "Home" tab and click "Font." Click the "Font" tab. Select "Double Underline" in the "Underline style" box. Select the text you want to underline, if you want to add a decorative underline. Click the "Home" tab and click "Font." Click the "Font" tab. Select the decorative underline you want to use in the " Underline style" box. Click "Underline color" and select the color you want to use for your decorative line. Click "Paragraph group" on the "Home" tab if you want to underline spaces. Click "Show/Hide" and press the "TAB" key. Select the tab characters that you want to underline. The tab character looks like an arrow. Press "CTRL," and "U" together for a basic line. Click "Font" on the "Home" tab if you want to add a decorative line to the space. Click "Underline style" and select the style you want to use. Hope this helps.
Jan 02, 2013 | Computers & Internet
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Excel 2007 spreadsheets
The most likely problem is that you (or somebody) has R1C1 reference style turned on.
In the TOOLS menu, choose OPTIONS and switch to the GENERAL tab. Look for the checkbox labeled R1C1 reference style. If it is checked, this will cause your symptoms.
Just uncheck the box and click OK.
I'm not sure what happens to existing formulas. If you (or somebody) has written formulas that rely on the R1C1 style, I don't know if they automatically get updated to the regular style or not, but that should be easy to discover.
Jan 10, 2008 | Microsoft Excel for PC
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
