Question about Diasonic DDR-3000 128MB Handheld Digital Voice Recorder
I have a DDR 5000 and it is impossible to get it to communicate with the computer. Unknown unit is the message on every computer I have tryed?
Ddr ram sdram
If you mean you want to replace DDR RAM with DDR2 or DDR3 RAM, that is impossible. MBs are designed for one type and the sockets themselves are keyed differently and use different voltages.
Nov 08, 2013 | Intel D915GAV Motherboard
Staple unit impossible to open
Has to be empty to open. At bottom there should be a small black lever that moves down to indicate staples are present. This sometimes falls out giving a false replace staples message. Cartridge itself must be replaced. This is the cartridge where you insert the staples into. Clear plastic with spring.
May 18, 2010 | Canon imageRUNNER 5000 Copier
Have hp dc 5000 microtower, has ddr 166 ram, what's the most i can put in it?
HP DC 5000 series of business desktop computers;
(All models),
Uses DDR Sdram that operates at a frequency rate of 333MegaHertz. (333MHz)
Also stated as PC2700.
Total Maximum Amount of Ram Memory is 4GB.
EACH ram memory slot's Maximum Amount is 1GB.
There are Four ram memory slots.
(DDR is double pumped ram memory. Has a basic clock rate of 166Mhz, which is double pumped to show up as 332. This is rounded off to 333.
http://www.crucial.com/store/listparts.aspx?model=dc5000%20Series%20All%20Form%20Factors
Mar 02, 2010 | HP Compaq dc5000 PC Desktop
When I want to transfer my photos from my PC to the picture frame using the mini USB cable connexion,the PC leaves this message ''unknown device'' so this is impossible to transfer my pictures.Is there a...
"Unknown Device" This means that computer can't recognize the device that your connecting
If the photos is from a Digital Camera you should install a program that works with your device in order to transfer the photos
If the program of driver is already installed but still not working try to use another usb cable instead.
Jan 08, 2010 | Computers & Internet
No battery communications
You will get that message when the communications cable is not hooked up. It looks like a phone line and daisy chains from one battery to another and ends at the Matrix Control unit. If you have those installed and it still says no communication the system need service.
If you have a volt meter you can check the voltage from each battery at the plug. It should be 48 volts or more, usually on a fresh battery pack it will read 54.0+ volts.
Hope this helps,
Dean
Dec 09, 2008 | APC Matrix-UPS 5000 UPS System
Ram issue with compaq presario 5000 G1 Series
as you can see from the information below there are different requirements for RAM to work stable in your system . Most importand are the RAM VOLTAGE , SPEED , and Configuration of chips. you will need to consult the manual for qualified RAM requirements. Some RAM will work but not very stable. make sure the voltage supplied by your system is enough for the RAM. If you are running DDR RAM in dual channel mode, the ram needs to be the same size also. DIMM modules for the HP computer must meet the following requirements
  • The number of pins on the DIMM must match the socket type.
  • DDR memory requires a 184-pin slot and 1.8 operating voltage.
  • DDR2 memory is not compatible with DDR1 memory and requires a 240-pin slot and 2.5 operating voltage.
  • Synchronous dynamic random access memory (SDRAM): Only use DDR type SDRAM memory if the computer came with DDR-SDRAM.
  • SO-DIMM modules for the HP computer must meet the following requirements
    • SO-DIMM memory requires a 200-pin slot.
    • DDR2 SO-DIMMs are not compatible with DDR1 DIMM and DDR2 DIMM memory modules.
    • With a computer running at a system bus of 533 MHz or 667 MHz, use a PC2-4200 (DDR2 DIMM 533) type.
    • The following requirements must be met for the DDR memory to function in dual channel mode:
      • Same density (256MB, 512MB, etc.)
      • Same DRAM chip technology (x8 or x16)
      • All either single-sided or dual-sided
      • Matched in both Channel A and Channel B memory channels
Oct 22, 2008 | Compaq Presario 5000 PC Desktop
Prolem with DDR RAM 400
Hello, you might want to check hear http://www.crucial.com/ there is a good chance that you put the wrong type of ram in this computer.And it might need a new motherboard.
Oct 01, 2008 | Compaq Presario 5000 PC Desktop
Diasonic DDR-3000 128MB Handheld Digital Voice Recorder Logo
63 people viewed this question
Top Diasonic Audio Players & Recorders Experts
Joe Simiana
Joe Simiana
Mister Danger
Are you a Diasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
