Question about Maytag Neptune MDE5500AY Electric Dryer
Drum will not operate, neptune MD-3 - Maytag Neptune MDE5500AY Electric Dryer
  • Maytag Master
  • 8,404 Answers
Check your belt.
remove top and front to access
Posted on Sep 28, 2009
  • Jorge Rendon
    Jorge Rendon Apr 06, 2015
    Electric dryer no start does nothing Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING. NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position. If you hear a humming sound from motor area you more than likely have a bad motor. Try this test out to see if u have weak windings on motor. Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings Another thing to check is the belt safety switch. With a multi meter. Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released. Lastly check ut push start button for continuity with a meter when pushed in the on position,
I have a maytag dryer and i need to know if it is electric or gas. model # (P)MDG4000BWW
Gdeli25 --
The Maytag Neptune MD[G]4000BWW is a front-loading [G]as dryer. Parts list and manual are available online from:
[http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47083]
If you are still having problems, write back. -- SWT
Aug 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a neptune dryer. It is making a rhythmic
I normally only comment on Electrical Dryers, but you problem sounds like something that is common to all dryers.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, You will probably have to remove the top of the machine first, then remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Oct 15, 2009 | Maytag Neptune MDG5500AW Gas Dryer
How do I access the drum to replace the screws on one of the agitator fins in my Neptune Dryer MD 7500?
four door screws hinges and other side
top botom both side
take off the door
take off the white cowel around the door
you should se two top dogs remove the bolts and the top will lift open
Sep 26, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Neptune Gas Dryer MD-6 - Moisture Monitor not lighting
Remove the rear vent and run a load. If it dries correctly, repair the vent blockage.
If not, replace the gas valve coils.
May 24, 2009 | Maytag Neptune MDE4000 Electric Dryer
What is the drum capacity size on the orig maytag neptune washer?
Drum size or capacity for the Neptune Model Number MAH4000AWW is 3.4
Jan 03, 2009 | Maytag Neptune Washer
Maytag Dryer squeeling
Drum support rollers. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
We have a maytag neptune dryer md-6 and the dryer squeeks and squeels while drying close. Do I need to replace the belt or the drum wheels? Are all three?
i would replace the belt usually over time the belt streaches due to the weight of the clothes. the screaching ou are hearing is probably the belt going aound the drum instead of turning the drum.
Aug 15, 2008 | Dryers
Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
111 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
