Question about Technics Audio Players & Recorders
What speakers do i need for a technics amp su-x301, do you know what output of amp is thanks
megatronix
  • 57 Answers
SOURCE: Technics SU-V2 keeps cutting out
An amp will cut out if the output protection circuit kicks in. This circuit compares output power against the preset level. Each channel has it's own, independent protector. There are calculations that can be done, but for a novice the rule of thumb is to "never use a speaker with a power rating less than the amp AND a lower impedance than stated". Typically using a 4 ohm load on a 8 ohm system is inviting disaster. Even if the system does not become a smoke generator, you might notice that though "louder", the sound quality is deteriorated. Many "audiophiles" often hook up some combinations of speakers to have "surround" without really understanding that the collective impedance actually changes (generally lowers).
Posted on Jan 21, 2008
robotek
  • 1512 Answers
SOURCE: TECHNICS SU-V50
Hi max
I have done a followup with Technics Parts agents in the US, they will get back to me and then me to you shortly :) A vote as FixYa would help improve my ratings. Thanks
Graeme
Posted on Feb 09, 2008
SOURCE: Technics SU-X955 amplifier. which speakers ?
Helo you have to use speaker of the same wattage you have now chage crossover to get new clear digital soud
Posted on Feb 11, 2008
SOURCE: amp cuts out
The fan is ageing and putting noise on the protect line. Replace it or put a 100 uf cap across the fan at the plug. Beware polarity is marked wrong on p.c.b.
Posted on Feb 23, 2008
  • 130 Answers
SOURCE: Hello I have a Technics SU-V45A amp, it's about 18
See there is a problem with the volume conroller as it is 18 years old the controller has worn out replace the volume controller with a new one and you will be able to enjoy great sound again
Posted on Dec 05, 2010
Need a manual for su-x301
http://www.hifiengine.com/hfe_downloads/index.php?technics/technics_su-x301_rs-x301.pdf
Mar 30, 2014 | Technics SH-GE70 Home Equalizer
On my Technics SU-G90 where do I connect the subwoofer
Some amps have a single RCA socket for a powered sub. If it has not got one of these then the amp has no output for a powered sub. If so then you can only use a none powered subwoofer, which will connect via the speakers of the amp, see the subwoofer manual for how to do this.
Feb 18, 2014 | Audio Players & Recorders
How do I hook up a stereo reciver to the technics su-g91
I assume you want to use the SU-G91 as a power amplifier to drive your speakers. If your receiver has connections for inserting an equalizer (may be labeled pre-amp output and power amp input), remove the jumpers between the pre-amp and the power amp, then run cables from the pre-amp to the SU-G91 inputs. You can have an equalizer between the receiver and the integrated amplifier.
If this is not available, use the recording output (for a tape recorder on older receivers). Note that the volume control on the receiver will be bypassed with this connection.
Sep 23, 2012 | Audio Players & Recorders
Technics su-z65
Hello
Your Tchnics is too old model and it has power transistors are used in output section. The output power is rated as 50Watts/channel/4Ohms. You can connect extra speakers to this left and right outputs, such a sway that the impedence should not go bellow 4 Ohms. Its repair book informs me that if any of the output transistors has gone out, it will not be available any more, and no substitutions cam be done. So be care when connecting more speakers. OK.
Jan 06, 2012 | Technics Audio Players & Recorders
Technics SU-G95 Amplifier and no sound on left speakers
Usually this is a defect in the output amp IC. If you have no experience with repairs of these types of units, have it checked by a service shop. If the output AMP IChas failed, it will cost about $75 for a replacement. This unit uses an RSN3306P IC .
Dan
Mar 14, 2010 | Technics Audio Players & Recorders
I am playing my stereo with the su-g95 amplifier what can i do to play all 4 speakers at the same time.
first dose your amp have 2 or 4 outputs if 4 outputs you have to have 4 speakers ,and connect them on your amp speaker output is that so hard to do ....
Nov 17, 2009 | Technics SUV500 2-Channel Amplifier
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
Amp not working properly.............
Mke sure that the tape monitor switch is turned off.
Dan
Apr 09, 2008 | Audio Players & Recorders
Jan 21, 2008 | Audio Players & Recorders
230 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
